Latency Test OK, dennoch Fehlermeldung
- Muftijaja
- Thank you received: 4
14 Aug 2024 12:17 #307722
by Muftijaja
Replied by Muftijaja on topic Latency Test OK, dennoch Fehlermeldung
Hello tommylight! I know, you said this somewhere at the beginning of this thread. I must say, I did not know anything about the fickleness of this theme. I am (now as before) absolute newbie to Linux and Linuxcnc, I made my config with the wizard and afaik, I did not touch the /etc/network files at any time until someone in this thread told me to do this. I did not play around with settings but tried to consolidate the network with the help of the guys here. If I have done sth. wrong, I apologize.
Any help with my latest questions (bash) is welcome.
Cheers, Hanno
Cheers, Hanno
- Thank you received: 7505
14 Aug 2024 12:49 #307724
Replied by tommylight on topic Latency Test OK, dennoch Fehlermeldung
Sorry but i can not help you with stuff i have no clue about, the bash is trying to run an executable file that i do not know what it contains, etc, etc.
I do admire your will to try and fix it and you being hell bent on learning new stuff, but at some point you have to cut the losses and move on.
Find another hard drive, cheap used one, install everything you need, and if this succeeds, then get rid of the old one. This way you still have a backup.
Moderators: Muecke
Time to create page: 0.404 seconds
