  • mariusl
  • mariusl's Avatar
09 Aug 2024 10:17
Replied by mariusl on topic Jog keys for A axis
Jog keys for A axis
Category: Gmoccapy
I used Home and End for the A axis on a regular 4 axis machine and then I used Home and End for B axis and "[" and "]" for C axis on a five axis machine.
I think Norbert's suggestion of looking at the keys in Axis is probably the right way.
  • meister
  • meister
09 Aug 2024 10:17
if you are playing around anyway, you can also set the enable bits of the stepdir instances to 1 in rio.v
    assign PINOUT_STEPDIR11_STEP = PINOUT_STEPDIR11_STEP_RAW;
    assign PINOUT_STEPDIR11_DIR = PINOUT_STEPDIR11_DIR_RAW;
    wire PINOUT_STEPDIR11_STEP_RAW;
    wire PINOUT_STEPDIR11_DIR_RAW;
    wire UNUSED_PIN_STEPDIR11_EN;
    stepdir stepdir11 (
        .clk(sysclk),
        .step(PINOUT_STEPDIR11_STEP_RAW),
        .dir(PINOUT_STEPDIR11_DIR_RAW),
        .en(UNUSED_PIN_STEPDIR11_EN),
        .velocity(VAROUT32_STEPDIR11_VELOCITY),
        .enable(1),
        .position(VARIN32_STEPDIR11_POSITION)
but if that works, something is wrong with the connection and the board is in ERROR state
  • Mecanix
  • Mecanix
09 Aug 2024 10:16
PIN 13 (x_pulse) is NOT working on my FPGA. w t f
If I swap pins and place the step on PIN 14, I'm getting steps (!!). Told you the problem was at my end, but I'll have to keep you responsible for this one - guilty!! You picked those random pins ;)
In all seriousness, something's not right with PIN13. Let's hope it's just hardware (bad soldering) and not gowin's internals or their place/routing compiler. Yikes. See? That's why I wanted to test ALL PINS on that thing before sending out some PCB work... don't trust - verify!
  • Grotius
  • Grotius's Avatar
09 Aug 2024 10:09
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
You maybe used the sai as "external interpreter", this sai i made some modifications, like read current plane, etc.
I had the same issue. Not reading in as should. But now it worked quite nice.
As an example original lcnc sai code for arc feed :
saicanon.cc
And edited code :
saicanon.cc
As a result i edited code in the sai to get it functional in different planes, retrieve more info etc.
I could draw the most of lcnc gcode files, also the 3d test file with circles in different planes.
Here you see how i startup the sai, read info and close it when gcode file is done.
This worked good. I had no issue's anymore. But it took a while to get everything done.
interpreter.cpp
but without spindle sync, I would make my lathe not functional.
Depending on your current distance from the centerline of your lathe, the spindle speed is adjusted.
This could be done by a component. Or is it more complex?
  • meister
  • meister
09 Aug 2024 10:00
i had done a major update, but i just compared one with an old version and everything looks good.
Unfortunately I can't tell you what the problem might be at the moment :(
  • rodw
  • rodw's Avatar
09 Aug 2024 10:00
Replied by rodw on topic Trajectory Planner using Ruckig Lib
I know I was reading a while ago that the solution for having jerk control in linuxcnc was to use some sort of mathlab algortithm to do some complex calculations, but there was a licensing problem between linuxcnc and mathlab. Since the guys from OpenCN have behind an university, they had the mathlab with an expensive license on which they were able to generate that c/c++ algorithm.
I'm not convinced there was really a licensing problem when I reviewed OpenCN but I can't remember the detail.
The university is obligated to release the code as open source. I could not see where Mathlab's rights were infringed if the Universities code was actually used! Anyway, we can just wait for Grotius now! :) What I find amazing is that he has taught himself how to Code in C as well as mastering the maths!
  • Mecanix
  • Mecanix
09 Aug 2024 09:55
Ah man no rush, you're too kind for real. I'm so not making thousand-dollar parts, just testing this gowin pinouts and timings, and so nothing to worry about.
Yeah gateware flashed, LinuxCNC files overwritten and halcomp'd, everything routine after each generate.
I'll play around with it. Obviously something I'm doing wrong. I'll update if I get anywhere.
  • PhilipME
  • PhilipME's Avatar
09 Aug 2024 09:53
Replied by PhilipME on topic Not sure if my parallel port is working
The parallel port is there 0x378
You are right it is working
  • rodw
  • rodw's Avatar
09 Aug 2024 09:49
Replied by rodw on topic ethercat master service
Category: EtherCAT
@Endian,
Can you implement a cycle counting component that counts up  4.
Then read in the canopen values, in other words, open the gate to the canopen every 4 cycles?
@ Rod,
I installed the linuxcnc iso. But udev rules are not working when set, also reload rules.
So bus is not starting after reboot.
I now have to start the bus invoking sudo after reboot.
I don't get it, where it's goes wrong.
I installed it the other day after I built the ISO and had no problems. If you have problems I am speechless because you taught me all I know :)
My Bullseye system that runs the deb you made for me is still running stong!
As you know there are a few steps required after installing the Debs, it is easy to miss one. I think they are all covered in the sticky.
forum.linuxcnc.org/ethercat/45336-etherc...step-by-step?start=0
  • meister
  • meister
09 Aug 2024 09:49
all flashed ? halcompile ?
check it in rio-test gui (do not forget the enable checkbox)
i'm not at home, so i can not test a config and send you, but it should work :(
  • Mecanix
  • Mecanix
09 Aug 2024 09:41 - 09 Aug 2024 09:43
Wow. I didn't get a pulse on any axis with the original config, that's why I tried with the signals. Neither config pulses. Snap, now what.
Pulse PIN is always HIGH. Dir pin works fine though!
Can you show a functional HAL file with a functional step/dir stepper config? I'll compare it to mine and see what's not updating in mine.
  • meister
  • meister
09 Aug 2024 09:34 - 09 Aug 2024 09:36
joints need no signal config
            "type": "stepdir",
            "pins": {
                "step": {
                    "pin": "13"
                "dir": {
                    "pin": "14"
            "is_joint": true,
            "axis": "X"
EDIT: better using the rio-setup tool
even i now have problems doing this in pure json :)
  • vmihalca
  • vmihalca
09 Aug 2024 09:33 - 09 Aug 2024 09:35
Replied by vmihalca on topic Trajectory Planner using Ruckig Lib
If you build that machine gui, and you choose a server type, like lcnc uses nml.
Then you can also connect it to everything.
Halcore can run a server of any type. It's just adding a server and make the connections.
My initial controller app for my lathe was written in kotlin multiplatform.
Starting from a java project called JCNC Screen, I've build the JNI layer to talk nml with linuxcnc then build the rest of the UI on top of that with.
I abandoned that project for now because linuxcnc has an internal interpreter and an external interpreter. I was using the external one to get the cannonical motions, but the external one does not quite match the internal one. So I might end up drawing things that are not what the machine will do in the reality. I found this issue very problematic and this is where I bumped into how spagetti linuxcnc codebase is.
I would love to revive this project, but as I said, I need a good foundation and I was hoping OpenCN to be just that, but without spindle sync, I would make my lathe not functional. And unfortunately, I don't have the knowledge (yet) or time to learn and do it myself.
  • Mecanix
  • Mecanix
09 Aug 2024 09:29
@meister
Similarly, I can't make the stepper work. This is NOT a good start for me man, ouchy lol
The dir works on all axis, however getting no pulse from any of them. Can you also share a stepgen config for an axis? Below is what I've blindly attempted, but getting nowhere (as usual!!).
            "type": "stepdir",
            "pins": {
                "step": {
                    "pin": "13"
                "dir": {
                    "pin": "14"
            "is_joint": true,
            "axis": "X",
            "signals": {
                "velocity": {
                    "net": "joint.0.vel-cmd"
                "position": {
                    "net": "joint.0.motor-pos-fb"
Displaying 24196 - 24210 out of 24509 results.
Time to create page: 0.538 seconds
