  • MaHa
  • MaHa
30 Jan 2026 17:14
Replied by MaHa on topic Strange preview for circular arc (G2/G3)
Category: G&M Codes
Just in case you want helix milling, you need to set z value for start and end. P is the amount of turns, if z-10 P5, it could look like that, pitch 2
G0 X-52.5 Y0 Z0
F1000
G2 I52.5 J0 Z-10 P5
  • Finngineering
  • Finngineering
30 Jan 2026 16:27
Replied by Finngineering on topic Strange preview for circular arc (G2/G3)
Category: G&M Codes
The complete code was visible in the screenshot, but for clarity I include it here:
G17
F500
G2 I52.5 J0 P1
M2
I made a new test with the code you used, and for that the preview is working properly. But if I comment out the G0 move, then the preview is again strange. See the two situations below.
The complete code, with G0 commented out is below:
G17 G21 G40 G43H0 G54 G64P0.005 G80 G90 G94
(G0 X-52.5 Y0)
F1000
G2 I52.5 J0 P1
M2
Maybe this is expected behavior? It certainly wasn't what I expected, but that doesn't mean much. I use LinuxCNC 2.9.2 by the way.
Thank you for having a look. With that the issue is now pinpointed.
  • dcsilvias13
  • dcsilvias13
30 Jan 2026 15:22
Replied by dcsilvias13 on topic Ethercat Leadshine L6N Gantry XYYZ Config
Category: EtherCAT
I am pretty sure I didn't make any changes to the .coreDC file.  What troubles are you running into? Ill post it anyway in case I did.
File Name: coreDC.hal
File Size:2 KB
  • PCW
  • PCW's Avatar
30 Jan 2026 14:59 - 30 Jan 2026 15:00
OMRON Yaskawa controllers, what I/O board would you choose
Category: Driver Boards
For step/dir, Mesa 7i96S is the right choice, and if you do need more IO add Mesa 7i84 with 32 inputs and 16 outputs and wires to 7i96S with a simple cut down LAN cable.
If need more I/O than a 7I96S can provide, a 7I76EU is a one card solution (basically a 7I96S+7I84U on one card)
  • zz912
  • zz912's Avatar
30 Jan 2026 14:53
Adding a GO/RUN physical button to run the MDI command typed in the command line
Category: Gmoccapy
I would like the same functionality.
I would like the setup page in gmoccapy to toggle the execution of MDI commands either by enter key, double click, button (like now) or by HAL signal.
But I did not have time yet.
This functionality cannot be simply implemented using the HAL pin in HALUI, because the EMC_MDIHistory widget is in Gmoccapy. So a new gmoccapy HAL pin should be created.
EMC_MDIHistory widget is here:
github.com/LinuxCNC/linuxcnc/blob/master...cp/hal_mdihistory.py
The function to confirm the command is here:
github.com/LinuxCNC/linuxcnc/blob/bf71ba...history.py#L151-L200
In gmoccapy.py:
github.com/LinuxCNC/linuxcnc/blob/bf71ba...py/gmoccapy.py#L3444
You can create new HAL pin in Gmoccapy for self.widgets.hal_mdihistory.submit()
linuxcnc.org/docs/devel/html/config/python-hal-interface.html
  • Hakan
  • Hakan
30 Jan 2026 14:52 - 30 Jan 2026 14:53
Replied by Hakan on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
FWIW, I thought is was nice that pins are named stat_* in Donomik's version.
My mind was into naming pins after the mode they are used in. Problem being there are overlaps.
For example there are many velocities: Homing velocity fast, homing velocity slow, PV velocity,
CSP velocity, CSV velocity, PP velocity, all using different PDOs, except CSP and CSV velocity which is the same PDO.
I would guess also Probe velocity, probably several versions.
On the other hand, it would be a bit convoluted for the user to use .csp-commanded-velocity when they already selected csp mode and see it as natural to use .commanded-velocity.
  • amanker
  • amanker
30 Jan 2026 14:11
How to update QtDragon_HD to latest version?
Category: Qtvcp
I have installed linuxcnc 2.10pre on raspberry pi4. Now I want to update qtdragonHD to latest GIT version. Can anyone guide me how to do it?
  • ruediger123
  • ruediger123
30 Jan 2026 13:28
Replied by ruediger123 on topic LinuxCNC S-Curve Accelerations
@grandixximo
Attached are the two NC files.
30 Jan 2026 13:17
How to do wiring to generate quadrature encoder signal in Mesa 7i95 board
Set the Mesa board for "single ended" encoder, use only GND, A+ and B+ wiper/pins.
Also, very short wires if the cable is not shielded, otherwise for anything longer than 10-15CM use shielded wire.
  • spumco
  • spumco
30 Jan 2026 13:13
PLC + LinuxCNC for industrial machine with simple HMI (non-G-code operators)
I'm not trying to dissuade you from using LCNC with an external PLC, but if you must have a physical PLC handling IO and similar...have you considered a PLC-only solution?
Some PLC's these days are available with high-speed outputs and built-in motion control (trajectory planner) functions.
I have built two automation machines recently using an Automation Direct ClickPlus PLC that drives three axes of coordinated motion via step/dir servos.  Programming was dirt-simple and the resulting motion met our expectations.
The main PLC has the HS outputs - no need for expensive daughter boards just to get the motion control features.
In my case the motion profiles are very simple; I've not explored the full capabilities of these PLCs... but if your needs are also fairly simple something like this might suffice.  Admittedly, the Click PLCs are fairly 'low-end', so higher-end PLC's likely have more sophisticated onboard motion control features.
30 Jan 2026 13:13
30 Jan 2026 13:11
TLDR
LinuxCNC has it's own PLS named ClasiLadder.
Either way you look at it, it is much easier to do everything in LinuxCNC as you can add VCP panels and tabs to Axis GUI to your hearts content.
Or am i missing something?
  • grandixximo
  • grandixximo's Avatar
30 Jan 2026 13:05
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I've not noticed this behavior, but I'm not omniscient, I'd need more information, your pictures are lacking context...
  • BertaA
  • BertaA
30 Jan 2026 12:57 - 30 Jan 2026 17:46
Category: Gmoccapy
Hello,
I'm new to Linuxcnc, I've been studying it for a month and I'm very happy with it.
I'm retrofitting a Cortini mill (a very small industrial-grade italian cnc mill) and thanks to this forum I could get a Ethercat system working with Beckhoff hardware and I could add a lot of external hardware buttons to my system.
For example I can have a program run, pause physical button in auto mode.
I cannot have a physical button for the go/run mdi command line.
Please note: this has nothing to do with custom MDI macro buttons.
To be clear: I put the system in MDI mode, type  "G0X10" then I must use the mouse to have it run.
The keyboard enter button is not the same becouse if i recall a previous mdi command from the list touching it on a touchscreen (or selecting with the mouse) the Enter key doesn't work.
I could not find a halui connection to this go button.
The goal would be to connect it to the start program physical button that is already  working in auto mode but this could be a further step. It would just be great to connect it to a new physical button.
Is this in any way possible?
I hope to have been clear despite my bad english.
Many thanks
Alberto
  • ruediger123
  • ruediger123
30 Jan 2026 12:22
@grandixximo
Is it possible that if the maximum speed is not reached (without t3/s3), the jerking exceeds the limits?
gruß
Rüdiger
Displaying 3091 - 3105 out of 17272 results.
Time to create page: 0.934 seconds
