  • grandixximo
  • grandixximo's Avatar
30 Jan 2026 13:05
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I've not noticed this behavior, but I'm not omniscient, I'd need more information, your pictures are lacking context...
  • BertaA
  • BertaA
30 Jan 2026 12:57 - 30 Jan 2026 17:46
Adding a GO/RUN physical button to run the MDI command typed in the command line
Category: Gmoccapy
Hello,
I'm new to Linuxcnc, I've been studying it for a month and I'm very happy with it.
I'm retrofitting a Cortini mill (a very small industrial-grade italian cnc mill) and thanks to this forum I could get a Ethercat system working with Beckhoff hardware and I could add a lot of external hardware buttons to my system.
For example I can have a program run, pause physical button in auto mode.
I cannot have a physical button for the go/run mdi command line.
Please note: this has nothing to do with custom MDI macro buttons.
To be clear: I put the system in MDI mode, type  "G0X10" then I must use the mouse to have it run.
The keyboard enter button is not the same becouse if i recall a previous mdi command from the list touching it on a touchscreen (or selecting with the mouse) the Enter key doesn't work.
I could not find a halui connection to this go button.
The goal would be to connect it to the start program physical button that is already  working in auto mode but this could be a further step. It would just be great to connect it to a new physical button.
Is this in any way possible?
I hope to have been clear despite my bad english.
Many thanks
Alberto
  • ruediger123
  • ruediger123
30 Jan 2026 12:22
Replied by ruediger123 on topic LinuxCNC S-Curve Accelerations
@grandixximo
Is it possible that if the maximum speed is not reached (without t3/s3), the jerking exceeds the limits?
gruß
Rüdiger
  • hhscott
  • hhscott
30 Jan 2026 12:15
Replied by hhscott on topic Python Probe Screen
Python Probe Screen
Here is a link to download everything I used to create the touch-off side panel. No installation needed as it just a python script and some support files. I am NOT a developer and this is totally ad hoc software. Also, some functionality is incomplete and if used you should consider it as a template to your specific needs. No instructions are included but the code is well commented and if you are even a novice in python you will have no issue editing it to your particular needs. This was tested on a pi5 8GB running Debian Trixie from the official downloads.
You will need Inkscape to Edit the GUI. I wrote a function in the script that opens and parses an Inkscape file and maps tkinter widgets to the named objects. The Inkscpape objects contain the X and Y position data and the width and height information for the tkinter widget. Doing this allows for super easy GUI creation and edits. The script comments explain this in more detail.
I am not offering support if you decide to use this, hopefully the community can make it better and share with everyone. I am SURE that my mdi commands and general code structure can and should be improved before considering this as a stable and good addition to LinuxCNC.
drive.google.com/drive/folders/1mLqdm_YS...5YEtc?usp=drive_link
  • Marcos DC
  • Marcos DC's Avatar
30 Jan 2026 11:16
PLC + LinuxCNC for industrial machine with simple HMI (non-G-code operators)
To add some more technical context to our use case:
This is a large-format gantry-style machine for laser cleaning and automated spray painting of heavy equipment and large structures. The focus is on robustness, safety, and simple, repeatable operator workflows rather than traditional CNC part programming.
Our current concept is roughly:
• PLC: machine sequencing, state machine, safety logic, interlocks, recipe management, part dimensions, operator interface (HMI), and maintaining machine state independently of the PC
• LinuxCNC: motion control, path execution, coordinated axes, and low-level servo/stepper control
The PLC would command LinuxCNC at a higher level (start cycle, select program, pass parameters, etc.), while LinuxCNC would not be responsible for overall machine state or safety sequencing.
We are particularly interested in hearing from anyone who has implemented a similar architecture with a real industrial PLC + HMI, and how you structured communication, parameter passing, and responsibility boundaries between the PLC and LinuxCNC in production machines.
Any concrete examples or lessons learned from industrial environments would be very valuable.
  • Marcos DC
30 Jan 2026 11:15 - 30 Jan 2026 11:25
Thanks for the detailed explanation — that is a very interesting architecture and I appreciate you taking the time to describe it.Thanks for the clarification regarding Beckhoff I/O. Just to be clear, in your setup you are using Beckhoff EtherCAT I/O as remote I/O, but without a Beckhoff PLC runtime (e.g. TwinCAT PLC), correct? In our case, we are specifically looking for architectures where a real PLC runtime (IEC 61131, ladder/ST, etc.) is responsible for machine sequencing and state, and LinuxCNC is used primarily for motion and interpolation.
In our case, one of the main drivers for using a PLC is to keep machine sequencing, state management, and operator workflow independent of the LinuxCNC PC. The goal is that the PLC maintains the machine state and basic operation even if the LinuxCNC PC or software needs to be restarted or serviced.
We are also targeting a more traditional industrial maintenance environment, where ladder/IEC PLC logic and a dedicated industrial HMI are preferred for long-term support by technicians who are not Linux or software specialists.
For that reason, we are specifically interested in experiences using a real PLC (e.g. Mitsubishi, Omron, Siemens, Keyence, Beckhoff, etc.) alongside LinuxCNC, and how people typically split responsibilities between PLC and LinuxCNC in that type of architecture.
Still, your approach with Node-RED, distributed I/O, and web-based HMI is useful as a reference for alternative architectures — thanks again for sharing your experience
  • Troff
  • Troff
30 Jan 2026 11:05
OMRON Yaskawa controllers, what I/O board would you choose
Category: Driver Boards
I guess an important information is, i plan to run the drives in position control.
I plan to use the Yaskawa in closed loop.
So the drives would receive STEP and DIRECTION signal. According to manual i also has a completion signal called COIN. And obviously some alarm and enable signals as well.
Hope this clarifies a bit.
  • suraj9735
  • suraj9735's Avatar
30 Jan 2026 10:54
How to do wiring to generate quadrature encoder signal in Mesa 7i95 board
Dear LinuxCNC User,
I am using Mesa 7i95 board to run a single axis AC Servo motor. I want to control feed override externally using LabVIEW while the LinuxCNC G-code is running at programmed feed rate. This is my part of PhD research work to control the feed override of a running G-Code based on some unstable/chatter vibration in the process.
As I now aware that, there is no analog input pin available in Mesa 7i95 board such that I feed analog voltage and bind that pin with mpg feed override inbuilt pin of LinuxCNC software. From the forum, I got suggestions that is it possible to use encoder pwm pin for the same purpose. The idea is, generate a digital  signal A and B of 90 phase lag with LabVIEW and send it to encoder pin of 7i95 using LabVIEW cDAQ module NI-9401. So, I have generated two digital signal called A and B and create logic as following
A-0, B-0;  A1, B0;  A1, B1; A0, B1. This logic clearly generated two A and B digital pwm type signal with 90 degree phase lag. I checked that in oscilloscope and it shows perfect squrae signal of 5 volt in high and 0 volt in low with 400 mV noise.
Now the following wiring I have done from NI-9401 to 7i95 encoder 2 slot.
A signal or digital output 1 of NI-9401 to A+ or pin 1 of 7i95
B signal or digital output 2 of NI-9401 to B+  or pin 4 of 7i95
GND of NI-9401 to GND or pin 3 of 7i95
After this connection, I checked the encoder count of encoder 2 in Hal show configuration. I observed that, the count is increasing, then decreaseing, and then again increasing, but overall it increases. I see it randomly increasing or decreasing. I played with loop timing of digital signal generator from 1 second to 1 mili-second but no improvement. I was expecting that if I set 1 sec loop time the counter of encoder will increase by 4 times because it is in quadrature mode. But again important point is I have not used the other encoder pin of encoder 2 slot. There are 8 pin available in encoder slot, A+, A-, GND, B+, B-, 5 Volt output, Z+, Z- respectively from pin 1 to pin 8. Out of the eight pin I am using only 3 pin.
Truly speaking, I don't understand how the mesa driver actually counts the quadrature pulses and how the motor encoder generate those pulses. At what frequency motor encoder generate those pulses and what frequency mesa drive read those pulses.
I believe either I am doing wrong wiring or setting wrong frequency to generate the signal.
I request expert to please guide me in doing proper wiring, frequency setting of loop in LabVIEW, HAL code setting in .hal and .ini file to get stable counter in encoder 2. After I get stable counter and full control on number of pulses, I will bind that pin with feed override pin and control the feed override externally using LabVIEW. From LabVIEW I will send fix number pulses either to increase or decrease the feed override. I will scale those pulses to match the feed override required value.
If this is possible let me know, else suggest me a different approach to do the same task either by buying new most suitable daughter board that supports with 7i95 and has analog input and output pin or any other way.
Suraj Kumar
  • Troff
  • Troff
30 Jan 2026 09:55 - 30 Jan 2026 10:40
Newbie here! Be gentle :-)
I have recently acquired a bunch of Omron Yaskawa servos and SGDH drives from a running machine.
Read the LinuxCNC documentation a while ago planning for a CNC setup for my minor lathe.
Searched the forum for experience with the Omron Yaskawa SGDH controllers. One guy doing mesa to control the SGDH.
First of all i would like to do x-y axis operations to do threads etc. Long term perspective i would like to do 3 axis machining, making the spindle A-axis servo controlled - and mounting a spindle on the x-y axis.
I have not settled on a PC platform yet. But concidering making it simple and cheap as a start. And I can upgrade if i find myself in a situation where it is meaningful to throw more money at the platform.
Questions:
1. What are my simple I/O options, a RPI5 and a basic I/O card, a BeagleBone with a cape ? Any recommendations ?
2. If i later on do the A axis i plan on installing the Sevo drive with a gearing that will get up to max 600rpm. . It is a small hobby lathe and  currently is has a 700W motor. Anyone with experience running servo on an A-axis - the servo motor i have is a 1200W type?
Hope this is meaningful, if not let me know and i will try to elaborate.
Thanks in advance!
  • endian
  • endian's Avatar
30 Jan 2026 08:41 - 30 Jan 2026 08:44
Replied by endian on topic LinuxCNC S-Curve Accelerations
there is added filtering and influence of real active ferror from feedback but I am not using it because it creating frequencies ...
  • endian
  • endian's Avatar
30 Jan 2026 08:40 - 30 Jan 2026 08:50
Very good stuff! I made a start today forum.linuxcnc.org/ethercat/58260-lichua...r-need-help?start=20
is dt = Delta time = servo period?
I'll have to follow you guys a bit more closely!
yes interpolation servo period.. Rod please check this repo  codeberg.org/endian/Beckhoff_AX5ZYZZ_lcec_driver here it is solved at all ... there is a .hal file example and everything needed
  • rodw
  • rodw's Avatar
30 Jan 2026 08:27
Replied by rodw on topic LinuxCNC S-Curve Accelerations
  • Unlogic
  • Unlogic
30 Jan 2026 08:10
Replied by Unlogic on topic Optimum Optimill MH50V CNC conversion
Category: Milling Machines
There hasn't been any updates to this thread for a while. But the machine has worked great this autumn and I've created some nice billet aluminum car parts.
However it's finally timed for a much awaited spindle upgrade. I bought this 8000 rpm, liquid cooled BT40 spindle from FUKA/Swift. It seems like a very nice unit but it's gonna be a while before I can test it as I now need to design and manufacture a new head for the milling machine along with a much larger pneumatic tool release cylinder.
  • grandixximo
30 Jan 2026 07:57
0x60B1 (velocity feedforward) can use joint.N.vel-cmd directly - is equal of FF1 of PID which already exist and its widely used to compensaty cycle delay ... this stuff is from my point of view useless for now
but I am still taking just about pin which allready read position from allredy presented 50ms buffer .. you are providing us from sTP posCmd(t), velCmd(t) (command speed is compensated cycle with PID FF1 and we do no use 60B1 for now), accCmd(t) and jerkCmd(t) and we need for ethercat posExtraCmd(t+2) for ethercat devices which is running in Constant Synchronized Position mode because of absention PID and therefore FF1 absention too (2 cycle lag present of ethercat) - this is just array position value which allready exist in buffer because of time(you notice 50ms) precalculation ...
and I know this is topic connected with ethercat but it is directly connected to trajectory planner ... Beckhoff, Codesys, Deltaww it has implemented as I said because their native bus is ethercat ...
 The lookahead buffer stores velocities and segment data, not pre-calculated positions. Positions are computed at RT execution time through interpolation based on progress values that depend on velocity integration each cycle. The future position you want doesn't exist in a buffer waiting to be exposed.Your HAL component using
vel_cmd * dt + 0.5 * acc_cmd * dt²
is actually the correct approach given the architecture. It's not a workaround, it's the right way to predict future position from the data that exists.The TP gives you accurate vel-cmd and acc-cmd every cycle. With S-curve planning these will be even smoother and more predictable than with trapezoidal, so your compensation should work better not worse.
  • Aciera
  • Aciera's Avatar
30 Jan 2026 07:41
Replied by Aciera on topic Strange preview for circular arc (G2/G3)
Category: G&M Codes
Seems to work for me, but maybe you could provide a complete gcode example:
Displaying 3181 - 3195 out of 17264 results.
Time to create page: 0.489 seconds
