  • skipper
  • skipper
13 Jan 2026 02:22
code G71 was created by skipper
code G71
Category: O Codes (subroutines) and NGCGUI
Need help using G71,
 lenux cnc will not recognize U or W commands.
Thank you
  • nhof
  • nhof
13 Jan 2026 01:57
Replied by nhof on topic Network Interface Card Recommendation
Category: EtherCAT
I just put an intel i226-V PCIe card in on igc driver.  It seems silly to get a 2.5G card to run at 100M but it is cheap and works so far with no problems.  You can check the driver list here:  IgH EtherCAT Master: Device Drivers  for supported drivers.
I am also curious if TSN has any effect, I have not seen how this integrates into ethercat or linuxcnc.
  • cnbbom
  • cnbbom
12 Jan 2026 23:31
Replied by cnbbom on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
Is this also the case with the 5.4.279 kernel?
Can you try commenting out the "addf pwmgen...." in the HAL file?
(this will prevent the spindle PWM working, but will give some indication where the problem might be)
I commented out a # in this line:
#addf pwm gen.make-pulsos base-thread
The spindle doesn't spin, but at least the inverter turns on now.
  • cnbbom
  • cnbbom
12 Jan 2026 21:35
The error consists of: creating a machine in linuxcnc, I follow these options that allow me to use automatic spindle control. But after completing the configuration and opening linuxcnc, the PC shuts down, and I need to reset the PC.
Yes, it happens with kernel 5.4.279.
And perhaps it's a detail that some have overlooked with this "return to login screen and black screen" freezing factor. But without a doubt, on this same PC that I tried several times with Debian 12 RTAI without success, it finally ran the Linux RTAI that you modified. The PWM and spindle issue is another task that will eventually lead to a solution. In the meantime, I'll keep testing and posting the results if you discover any clues.
  • deckname
  • deckname
12 Jan 2026 21:21
Replied by deckname on topic Mesa 7i96s problem, only one stepgen works
Category: Driver Boards
Turns out it was a stepper driver.
Apparently I mixed them up while swapping back and forth for testing.
I´m sorry, but thank you for the help!
  • PCW
  • PCW's Avatar
12 Jan 2026 21:01
"Another one has 4.9V to 0.04V and doesn´t work."
Sounds like a wiring issue as it seems there is  no load on that 7I96S output.
Are the outputs wired differentially? (STEP+and STEP- both used)
  • andypugh
  • andypugh's Avatar
12 Jan 2026 20:40
Replied by andypugh on topic New and Working RTAI debs for 2.9
  • deckname
  • deckname
12 Jan 2026 20:36
The voltage changes a bit with load.
The one with the lower voltage has 0.4V at low state, but this one works.
  • PCW
  • PCW's Avatar
12 Jan 2026 20:28
Is that 4.1V under load?
4.1V and no load indicates either a damaged output or low 5V supply
What were the low state voltages of the DIR outputs?
  • Sirfrimfram
  • Sirfrimfram
12 Jan 2026 20:25 - 12 Jan 2026 20:28
M6 Remap Issues - Weird Queue Buster Problem
I currently have a custom M6 remap that intermittently gets stuck on a line with an M66 (M66 P7 L3 Q10
I am assuming it's an issue with queue busters in my gcode, and I have a rough understanding of how queue busters work, and why they can cause problems, but I would have thought an M66 is exactly one of the ways to prevent a remapped code or gcode program from getting stuck, as explained here:
linuxcnc.org/docs/html/remap/remap.html#..._position_prediction
The tool change also gets stuck occasionally within the second half of an if statement on a G53 G1 move.
Any general advice around queue busters (or other causes) for a tool change to get intermittently stuck is appreciated!
Edited for clarity
  • Aciera
  • Aciera's Avatar
12 Jan 2026 20:18
Replied by Aciera on topic Linuxcnc 2.9.x and Glade GTK3 display issue
Category: Gmoccapy
You changed nothing but line 24 ?
That's correct
You might want to update to 2.9.8 as there have been some bug fixes since 2.9.3 (not sure if that is why it doesn't work for your though)
  • deckname
  • deckname
12 Jan 2026 20:16
Thank you for the suggestion.
I just measured the DIR signals, they all work fine.
The voltages are between 4.1 and 4.9V which seem a bit low to me, but it should still work with 3.3V.
Any other ideas?
  • cnbbom
  • cnbbom
12 Jan 2026 19:47
The Kernel Headers are not available for download. Is it necessary, or can I use the one I have here?
The ones on the server are the ones you provided, so yes.
But you don't need them unless you are compiling from source.
And this link works for me... www.linuxcnc.org/dists/trixie/base/binar...ai-amd64-1_amd64.deb
Thanks, Tommylight told me it was the same one I already had here.
  • bobwolf
  • bobwolf
12 Jan 2026 19:47
[WIP] IO_decoder: A modular High-Density USB I/O system (up to 128 pins)
Category: Show Your Stuff
Hi!
Thanks for the interest. I'm currently finalizing the cost analysis based on a small production batch.
My target is to offer a Starter Kit for 99€, which includes:
1x Base Board: (USB interface, ATmega core, 4x Encoder inputs, 3x Analog inputs, and DAC outputs).
2x Expansion Modules: Adding 16 Digital I/O (8+8) to the system.
Individual 8-bit expansion modules will be around 20€.
I'm currently refining the 'v2' hardware to eliminate the minor layout issues of the prototypes and optimize for small-scale production (aiming for an initial batch of 30 units). This price point allows me to offer a robust, pre-assembled solution while covering the extensive development of the HAL driver and firmware.
I'll keep you updated on the v2 progress and when I'll be ready to ship!
  • cnbbom
  • cnbbom
12 Jan 2026 19:46
andypugh post=341318 userid=723Qual é o erro? Os eixos são frequentemente uma fonte de ruído elétrico. O erro persiste mesmo com o hardware do eixo desconectado?
This is my configuration in the photo, but if I disable:
spindle pwm,
spindle cw
amplify enable      I can operate the machine.
Displaying 4321 - 4335 out of 17035 results.
Time to create page: 0.711 seconds
