  • grandixximo
  • grandixximo's Avatar
01 Jan 2026 06:53 - 01 Jan 2026 09:43
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
github.com/grandixximo/linuxcnc
I have not build it yet, but it should work, test and let me know
Edit:
There were build errors, should all be fixed, built on debian 13 no issues, have a simple xyz test configuration, it works with more joints/axis no problem, xyz just quick and simple.
  • NWE
  • NWE's Avatar
01 Jan 2026 06:17 - 01 Jan 2026 06:54
Replied by NWE on topic screen blanking
screen blanking
Category: Gmoccapy
Quoting from the Xfce tour:
"Screen Locking
There is no dedicated "security" tab anymore. Lock screen management was massively simplified and "Light Locker" was dropped. "lock-on-sleep" is now synchronized with xfce4-session and xfce4-screensaver.
Screen locking settings are now only handled by xfce4-screensaver to avoid conflicts. A button to open xfce4-screensaver-preferences was added"
That gave me the idea "Power Manager" does nothing anymore. So I installed xfce4-screensaver and set the screensaver to blank and lock after one minute. I watched it for 6 minutes and it stayed lit and didn't lock.
Next I set "Power Manager" from "never" to blank and lock after 1 minute. It blanked and locked after 1 minute. I set it back to 'never'.
We'll see how it behaves over the next couple days, but it appears installing xfce4-screensaver allowed my power manager settings to work but the screensaver settings didn't work. Go figure.
I do get the idea xfce4 is experiencing a major rewrite and expect over time there will be updates that make it behave.
Edit: It appears this is the associated bug report:
bugs.debian.org/cgi-bin/bugreport.cgi?bug=1034607
  • my1987toyota
  • my1987toyota's Avatar
01 Jan 2026 05:11
Replied by my1987toyota on topic Fusion 360 Win 10 EOL
Category: CAD CAM
Ok it is officially January 1 2026 in my area and fusion 360 is still working on my Windows 10 machine.
Will it stay that way through out 2026? Don't know. However given the bad press of
Windows 11 Autodesk would do well to let fusion 360 run on Win 10 for a while longer.
So we will see.
With that said Have a Happy New year every one.
  • NWE
  • NWE's Avatar
01 Jan 2026 05:05
screen blanking
Category: Gmoccapy
Disabled screen lock in power manager, also sleep = never. This is on Debian Trixie  with XFCE 4.20 on x11 without LinuxCNC. I don't touch the mouse and keyboard for 5 minutes and it blanks and locks. Totally locks me out if I was accessing it via vnc, it has to be locally unlocked before vnc can reconnect to the display but ssh still works.
I don't have screensaver installed at all. I installed screensaver on a friend's Trixie machine and screensaver's sleep settings seemed to work as advertised. My previous Bookworm install didn't have screensaver either but screen lock settings worked. I read something on Debian forums about more people with similar problems. I think it was here:
forums.debian.net/viewtopic.php?p=814969
xfce.org/about/tour
Enabled user autologin in /etc/lightdm/lightdm.conf so it logs me right to the desktop upon boot. That didn't seem to change anything with the screen blanking problem.
I can put up with it on the workstation for now, it would be a real problem on a cnc machine.
Even so, XFCE is my favorite desktop. It is similar to what Gnome was the first time I used Linux. Some years ago Gnome changed and completely lost my interest.
  • rodw
  • rodw's Avatar
01 Jan 2026 04:07
Freelancer wanted to get tool sensor working (software)
Category: User Exchange
Mr.Rodw big fan of your work! I wouldnt disagree with that however if there is solution to continue to use ER16 tooling (I should have mentioned that in the og post) then I would rather do that then invest in a TTS spindle and TTS collets. I know there is a solution to this
Thanks. I think the framework is there in qtdragon aleady but be prepared to read the docs and play. Conceptually not that hard. probe towards surface, then probe away until contact breaks then set Z0. You can also do it manually until you can roll a cylinder (eg drill or milling cutter) until it just fits under than set Z10 (if it is a 10mm dia cylinder).
  • my1987toyota
01 Jan 2026 03:27
Category: CAD CAM
Sounds like a good way end the day / year to me rodw. I am about to break the seal on a bottle of
a Single Malt Irish Whiskey.
  • rodw
  • rodw's Avatar
01 Jan 2026 03:13
Replied by rodw on topic Fusion 360 Win 10 EOL
Category: CAD CAM
Forgot to mention ( in case of incoherency) that I am working my way through the last of a bottle of Canadian Whiskey before I fly home tomorrow
  • rodw
  • rodw's Avatar
01 Jan 2026 03:10
Category: CAD CAM
Well they could charge your credit card like they did for me! Took a bit to get that reversed...
Also cancelled my adobe subscription.
Unfortunately, I have to boot Windows to run the Anycubic Slicer for my 3d printer so I am not shuffling gcode and USB drives.
There was a time I knew Windows backwards, now I am a bit bamboozled by it!
  • Thllll
  • Thllll
01 Jan 2026 02:55
QtDragon M6 Remap Tool Measurement - Inconsistent/Wrong Offsets with VersaProbe
Category: Qtvcp
Same thing happening to me, nearly the same setup too, did you ever find a solution?
  • my1987toyota
01 Jan 2026 02:36
Category: CAD CAM
rodw detesting Windows? No, that's not possible  .  Unfortunately I am stuck with both Windows and Fusion 360
at least for a little while longer anyway. But it does give me a unique opportunity to see what exactly Autodesk
does when the clock rolls over. Well I guess I will see in a few hours. LOL
  • rodw
  • rodw's Avatar
01 Jan 2026 02:33
Replied by rodw on topic Ethercat random jitter fix
Category: EtherCAT
This is really awesome work. I would stick to the igc driver which is real time when generic isn't
But from what I am hearing, optimising for system and network latency will probably avoid the issue.
I have a video about that and one user reports he got latency down to about 6 usec following my tutorial.
I suspect by running a latency optimised system has meant I have never experienced this.
01 Jan 2026 02:23
Replied by tommylight on topic screen blanking
screen blanking
Category: Gmoccapy
You CAN disable completely screen saver and still have the monitor go off after a while, use "power options", they are not the same thing.
  • rodw
  • rodw's Avatar
01 Jan 2026 02:20
Category: CAD CAM
Sorry not much help as I am in British Columbia, Canada ATM so  similar time zone to the OP (not 2026 yet!). I cancelled my F360 subscription and have been using Onshape to create STL files for 3D printing. I think when I get back  to needing CAD, I will try Freecad on Linux (Did I tell you I detest Windows?) There is collaboration between our devs and theirs starting with their tool handling API so I think it will be worth playing with.
  • rodw
  • rodw's Avatar
01 Jan 2026 02:09
Replied by rodw on topic screen blanking
screen blanking
Category: Gmoccapy
So the issue is the screensaver is doing what it is designed to do ?
I think so
  • my1987toyota
01 Jan 2026 01:00 - 01 Jan 2026 01:05
Category: CAD CAM
Well it's almost 8:00pm  or 20:00 here in Florida. Just 4 hours to go. Some sporadic fireworks here and there. Though tonight
I think I will have a drink, not that I see much to celebrate. It just seems fitting given what 2025 has been.
Displaying 4876 - 4890 out of 16966 results.
Time to create page: 0.294 seconds
