  • PCW
  • PCW's Avatar
30 Dec 2025 01:30
Replied by PCW on topic 7i97t Mesaflash Problem
Also note that the pre-installed firmware on a 7I97T fully supports the standard analog and digital I/O
You typically only need different firmware if you have an added parallel daughtercard
Analog output problems are most likely a hal file or tuning/polarity issue
  • grandixximo
  • grandixximo's Avatar
30 Dec 2025 01:10 - 30 Dec 2025 01:10
  • grandixximo
30 Dec 2025 00:30
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
my s-curve blending is comparable to the current TP, there is some loss, but it is unavoidable, but not in mills or more range.
  • NWE
  • NWE's Avatar
30 Dec 2025 00:28
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
I think a custom hal component will be the ticket for this ram control. I envision a glade user interface, separate reusable custom components for each backstop axis, and a custom component for the Y axis (upper beam height control.)
Different brands of press brakes would get their own  Y axis component, due to complicated variations in hydraulic configurations among the different makes and models.
Bend programs will be loaded in the python userspace gui app as a list of dictionaries containing positions for every single axis for the machine.
Stage two of my dream will be to write a python based app allowing the user to enter dimensions and angles, then create the bends file that the press gui can load.
Attached preliminary work, don't try running this one, it is incomplete yet.
  • hhscott
  • hhscott
29 Dec 2025 22:19 - 30 Dec 2025 07:07
Python LinuxCNC module was created by hhscott
I am wanting to write a couple of simple python3 scripts to automate some functions in LinuxCNC using the python linuxcnc module to send NML messages. I did this several years ago for another project and it was very successful. In this new application I am using a pi5 8GB with a Mesa 7i96s running Trixie 2.9.7. The basic installation is working well and the CNC is operating great so far (without any python automation).
I am a little confused about using python on Debian Trixie. When I try to install a package I get errors and the terminal prompts that I should use a virtual environment for python and packages. If I do this, will my python scripts still connect to the running instance of LinuxCNC? Please help me understand the basic structure for using python on the Trixie OS with LinuxCNC.
Thank you,
HH
  • endian
  • endian's Avatar
29 Dec 2025 21:55
Replied by endian on topic Ethercat random jitter fix
Category: EtherCAT
If you will test it .. please share some visual results before and after{for example scope printscreen) .. We are all interested in your pr I think !
thanks
  • endian
  • endian's Avatar
29 Dec 2025 21:50
Replied by endian on topic LinuxCNC S-Curve Accelerations
I think there is much more to do and to finish because there are great jitters during running cloud of point... it can not approximate it and the computations last too much time(sometime mills and more) to finish ...
for signle G2 G3 it is working well ...
I have talked with Michel, he said, he ends with lcnc and tp at all ...
Now it is on us ...
  • grandixximo
29 Dec 2025 21:48
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
The PR has been merged to linuxcnc-ethercat I have some testing modifications which I have not been able to test yet, will update here after I test myself, might be another PR before everything is proper.
  • Routercnc
  • Routercnc
29 Dec 2025 21:48
Replied by Routercnc on topic EasyProbe
EasyProbe
Category: AXIS
I run M130 in the terminal every time and the error persists.
  • ContinenteCNC
  • ContinenteCNC's Avatar
29 Dec 2025 21:47 - 01 Jan 2026 21:30
PID Windup on the way down was created by ContinenteCNC
Category: HAL
Hi folks!
The current PID hal module has a maxoutput pin to avoid integrator windup, but wasn't it supposed to have also a minoutput pin?
I am currently setting up a basic spindle control for a lathe and I am experiencing windup when I have to go from a higher spindle speed to a lower speed. On the way up it works just fine (well tuned)
Then I noticed that the PID output goes negative for a while during the ramp down, so the integrator is winding up to the negative side. This doesn't make sense from the DAC/VFD point of view, once the lower voltage they can handle is 0V. (I am using 0-10v analog control)
What I've just wrote make sense? Or am I just shaming myself publicly again?
  • MaHa
  • MaHa
29 Dec 2025 21:35
Replied by MaHa on topic EasyProbe
EasyProbe
Category: AXIS
On my system I get this error, when i forgot to set M-code executable
  • RotarySMP
  • RotarySMP's Avatar
29 Dec 2025 21:34 - 29 Dec 2025 21:49
Escalation of a Maho MH400E Retrofit (LinuxCNC + EtherCAT)
Category: Milling Machines
Very nicely laid out. My only advice would be to provision 20% extra terminals, especially grounds and 24VDC than you calculate you need.
I don't see a pendant. I am not familiar with that layout style from Solidworks, but you will certainly want a pendant. :)
And a fourth axis.
Cheers,
Mark
  • JT
  • JT's Avatar
29 Dec 2025 21:28
Replied by JT on topic 7i97t Mesaflash Problem
Did you install the required libraries with
sudo apt install libpci-dev libmd-dev pkg-config build-essential git
Typically you use sudo make install to build and install mesaflash.
gnipsel.com/linuxcnc/mesact/index.html
JT
  • JT
  • JT's Avatar
29 Dec 2025 21:25
Using translator
Hello everyone,
First of all, I'm a complete beginner with Linux.
I've converted an old milling machine using a Mesa 7i97t board and, thanks to this forum and other resources, I've managed to get everything working so far.
The original problem was that I couldn't control the analog outputs for the power amplifiers.
My guess was that the wrong firmware was installed on the Mesa board.
I tried to load the correct firmware, but it didn't work. I kept getting a message that it was unknown or something similar.
My guess was that the mesaflash version was too old.
I then tried to download the new version, as someone else here on the forum had success with version 3.5.10.
Then git was missing, and so on... After many, many hours, I've managed to get git and everything else installed again, as far as I can tell.
I now have the current Mesaflash package.
However, when I run the command `make` in the folder, I get the message: `pkg-config can't find libpci`.
When I try to install this, I get a message that cvs, perl-dbdabi-94, perlapi-5.32.0, and libc6 >= 2.38 are missing. (libc6 2.36-9 is installed)...
I'm completely stuck.
It's very possible that I've done several things wrong; I simply can't assess the situation properly.
I would be very grateful for any help!
I'm using LinuxCNC 2.8 and Debian 12.
Thank you!
  • dfarnainekl
  • dfarnainekl
29 Dec 2025 20:43 - 29 Dec 2025 20:45
Spindle Encoder: Float Precision Issues was created by dfarnainekl
Category: HAL
Hello,
I have a spindle encoder set up (via EL5151) to output the position/angle as revolutions (float value), which get fed into spindle.0.revs.
I am also using a ddt component to calculate the speed and feed it to spindle.0.speed-in.
This seems to work well enough (the speed needs some filtering for low speeds though, as the time step of the ddt is rather small).
There is one aspect of this though that I don't quite understand, and where I am surprised that I can't seem to find much information about (and people who this causes issues for): float precision.
The raw encoder count gets converted to float revolutions by dividing by a float factor (either in the EL5151 or in the lcec component, I am not sure). If these values are also internally handled as float (which I understand is the case), this should cause issues with the limited float precision, when the spindle has accumulated lots of revolutions:
  • The absolute resolution (i.e. minimum step size) of the position becomes large. This makes the output of the speed ddt increasingly "jumpy", needing more low pass filtering to display steady numbers. This also makes spindle synchronized motion (e.g. threading) less accurate.
  • The small relative position error caused by the limited precision of the encoder factor becomes a large absolute position error. This makes spindle angle synchronized motion (especially those depending on the absolute angle) less accurate.
How are these issues typically dealt with in LinuxCNC? I can think of ways to avoid them using the raw encoder count and integer arithmetic, but I don't know how to properly do it with the mostly float-based components available in the HAL.
Best Ragards
Daniel
Displaying 5011 - 5025 out of 16969 results.
Time to create page: 0.507 seconds
