  • PCW
  • PCW's Avatar
23 Dec 2025 16:17
Bitfile for Mesa 7i96s + 7i85 (+Modbus (PKT-Pin))
Category: Driver Boards
I would probably renumber the sserial channels so the 7I85 sserial channels start at 0 rather than 1
Flashing is safe as long as you have a recent mesaflash that supports the 7I96S
  • PCW
  • PCW's Avatar
23 Dec 2025 15:57
7i84 doesn't fault LInxuCNC when SSerial is interrupted
You could also use some threshold (> 200?) on  the fault count pin
You should also find out why you are getting sserial faults, in general these should never happen
I also think it's actually a bug if run is not cleared when all communication is lost and LinuxCNC
gives up
  • zippoffs
  • zippoffs's Avatar
23 Dec 2025 15:51
DIY CNC Mill - Random Limit Switch Errors
Category: Milling Machines
Hello, I'm new to the forum. I have spent the past year and a half building my own CNC mill that runs on LinuxCNC, and it is mostly done now. Except that I can't get it to finish a program because it keeps thinking that the limit switches have been triggered even though they haven't.
I built this mill from scratch. It is made entirely of aluminum plate and extrusions. It has NEMA23 closed loop steppers, SFU1204 ballscrews, HGH20CA linear rails, a 2.2kw 220v 3 phase spindle and 2.2kw VFD, a "5 axis" parallel port breakout board, a Dell OptiPlex 990 with a parallel port card and running LinuxCNC (obviously). For limit/home switches I have it set up to where one limit switch doubles as a home switch, and all six switches are normally closed and in series all going to one input pin. The limit switches are generic micro switches, and the limit/home switches are Metrol CS067B. I have 24V running through the switches, so I'm using a 24v to 5v optocoupler board to bring the signal down to 5v for the breakout board. The Metrol switch wires are not shielded, but because they cost $67 a piece, I don't want to mess with that. The wires for the other switches are shielded.
This is what happens when I try to run a program: I home the machine, import the program into Axis, hit run, and it could be 1, 5, or 60 seconds later that it suddenly stops the machine because a limit switch was supposedly hit. It doesn't seem to happen consistently. I originally had the VFD next to the other electronics in a copper mesh cage, but ended up making a sheet metal box for it and moving it away (and took the spindle cable out of the cable chain that also held other wires). I thought that would prevent any EMI from interfering with the other electronics. But that didn't fix it. I have narrowed it down to an issue between the spindle/VFD and the breakout board. I can run a program perfectly fine with everything on except for the spindle/VFD, so it can't be the steppers or drivers. I have tried running 24v directly to the optocoupler board, bypassing the switches, but it still triggers. I have tried completely bypassing the limit switch circuit by jumping the input pin on the breakout board to ground, and it still triggers. I have spent hours researching this, and I have tried almost everything. I have my VFD in a Faraday cage. I'm using a shielded spindle cable with the shielding grounded at both ends. I have the signal wires shielded and grounded. I don't know what I'm doing wrong.
I have spent weeks trying to diagnose this, and now I am only more confused. Part of the problem is that I'm only 18 and I'm not an electrical engineer (I'm not even a mechanical engineer yet!), and I'm learning a lot of this for the first time. I have run out of things to try, and I would really appreciate any help I can get. Thank you in advance!
  • NWE
  • NWE's Avatar
23 Dec 2025 15:43
Replied by NWE on topic Linuxcnc Image for Raspberry Pi 3
Got LinuxCNC built. Running latency test. Tried running Axis and QtDragon, gui just crashes, need to spend a little more time on it, maybe tomorrow. I think I got some missing dependencies going on.
  • Sekai
  • Sekai
23 Dec 2025 15:02 - 23 Dec 2025 16:07
Replied by Sekai on topic Arduino IO Expansion
Category: Show Your Stuff
Hi.
I copied the arduino-connector.py to the usr/bin/ as arduino-connector
Run the terminal with halrun and then with loadusr arduino-connector, it load next i try show pin, all good.
I run linuxcnc and go to Halshow and input loadusr arduino-connector and it loads.
I can see the pins, and net signals to a external encoder or input pins, works great.
The problem is when i put the command loadusr arduino-connector in custom.hal but i get the error  pin arduino.din.4 is not found. (the pin is active in show pin command)
I did try loadusr python3 arduino-connector or loadusr python3 /usr/bin/arduino-connector but no change.
If i try loadusr -W arduino-connector it loads but after that its waiting for something.
I use Debian 10 with kernel 4.19.195 RTAI with python 3.7.3
Edit: well the pins are not loaded. i put a show pin in the custom.hal after the loadusr arduino-connector and it shows no pin.
  • Aciera
  • Aciera's Avatar
23 Dec 2025 14:32
Replied by Aciera on topic Linuxcnc 2.9.x and Glade GTK3 display issue
Category: Gmoccapy
might help to post your 'motion_control_test.ui'
  • mmt
  • mmt
  • Sirfrimfram
  • Sirfrimfram
23 Dec 2025 13:37
Hello PCW,
LinuxCNC does report an error as a popup, but I was wondering if there is a way to force a fault. There doesn't seem to be any pins that can easily be used.
The main way to do it that I see is checking the state of the hm2_7i96s.0.sserial.port-0.port_state pin and generating a misc fault if it is no longer in the run state (which appears to be 0x3).
Is there a cleaner way of doing that? The only 7i84 pins in HAL that show up are just I/O.
I've attached a txt file listing all of the mesa pins.
  • andypugh
  • andypugh's Avatar
23 Dec 2025 12:58 - 23 Dec 2025 12:59
Altaros tool changer driver was created by andypugh
Category: Turning
Altaros make a relatively inexpensive 8-station tool changer for CNC lathes. www.altaros.cz/accessories/157-automatic...ead-for-8-tools.html  I don't have one to test with, but I have written a driver for it (as a user space Python HAL component).
I needed to add .py to the end of the filename to upload it. This should be removed to install the file
loadusr -W ./altaros_ath
# pre-selecting a tool isn't applicable on a lathe
net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
# tool change loop is handled in the altaros_ath component
net tool-change iocontrol.0.tool-change => altaros_ath.tool-change
net tool-changed altaros_ath.tool-changed => iocontrol.0.tool-changed
net pocket iocontrol.0.tool-prep-pocket => altaros_ath.pocket-num
net oddeven sim_toolchanger.strobe => altaros_ath.strobe
net tool-step altaros_ath.actuate => sim_toolchanger.actuate
To install the component, place the "altaros_ath" file in the same directory as the INI file of the LinuxCNC config being run, and make it executable. (chmod +x altaros_ath)
  • Mr1576
  • Mr1576
23 Dec 2025 10:24
Replied by Mr1576 on topic qtdragon_hd updated handler issue
Category: Qtvcp
Thanks for the reply.
To be perfectly honest I wasn't using the on screen buttons, just the arrow keys on my keyboard which I assumed would do the same thing once keyboard shortcuts were enabled
Having tried the on screen buttons they actually work fine in jogging increments. So the issue appears to be with my keyboard?
I tried updating to 2.9.7 but I am getting all sorts of errors downloading from the repository. Perhaps I should start another thread in a different section for that.
  • Hakan
  • Hakan
23 Dec 2025 08:47
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
Ran into a Yaskawa Servo with EoE that needs that have EoE disabled.
Time to open an issue github.com/linuxcnc-ethercat/linuxcnc-ethercat/issues/458
  • TripleM
  • TripleM
23 Dec 2025 08:40 - 23 Dec 2025 08:46
ok, I will put the 7i85 on the Serialport from 7i84 and I modify the 7I96S_7I85D_51 Bitfile.
If I plug it in serial_0 i don´t have to change the hal-file?!
sserial_port_0=2xxxxxxx
The bit file workflow was completed without errors, and the bit file was created. Can anything go wrong during flashing, other than it not working?
library IEEE;
use IEEE.std_logic_1164.all;  -- defines std_logic types
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Copyright (C) 2007, Peter C. Wallace, Mesa Electronics
-- http://www.mesanet.com
-- This program is is licensed under a disjunctive dual license giving you
-- the choice of one of the two following sets of free software/open source
-- licensing terms:
--    * GNU General Public License (GPL), version 2.0 or later
--    * 3-clause BSD License
-- The GNU GPL License:
--     This program is free software; you can redistribute it and/or modify
--     it under the terms of the GNU General Public License as published by
--     the Free Software Foundation; either version 2 of the License, or
--     (at your option) any later version.
--     This program is distributed in the hope that it will be useful,
--     but WITHOUT ANY WARRANTY; without even the implied warranty of
--     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
--     GNU General Public License for more details.
--     You should have received a copy of the GNU General Public License
--     along with this program; if not, write to the Free Software
--     Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301 USA
-- The 3-clause BSD License:
--     Redistribution and use in source and binary forms, with or without
--     modification, are permitted provided that the following conditions
--     are met:
--   * Redistributions of source code must retain the above copyright
--     notice, this list of conditions and the following disclaimer.
--   * Redistributions in binary form must reproduce the above
--     copyright notice, this list of conditions and the following
--     disclaimer in the documentation and/or other materials
--     provided with the distribution.
--   * Neither the name of Mesa Electronics nor the names of its
--     contributors may be used to endorse or promote products
--     derived from this software without specific prior written
--     permission.
-- Disclaimer:
--     THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
--     "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
--     LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
--     FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
--     COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
--     INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
--     BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
--     LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
--     CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
--     LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
--     ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
--     POSSIBILITY OF SUCH DAMAGE.
use work.IDROMConst.all;
package PIN_7I96S_7I85D_51_pkt is
	constant ModuleID : ModuleIDType :=(
		(HM2DPLLTag,	x"00",	ClockLowTag,	x"01",	HM2DPLLBaseRateAddr&PadT,	HM2DPLLNumRegs,		x"00",	HM2DPLLMPBitMask),
		(WatchDogTag,	x"00",	ClockLowTag,	x"01",	WatchDogTimeAddr&PadT,		WatchDogNumRegs,		x"00",	WatchDogMPBitMask),
		(IOPortTag,		x"00",	ClockLowTag,	x"03",	PortAddr&PadT,					IOPortNumRegs,			x"00",	IOPortMPBitMask),
		(OutMTag,				x"00",	ClockLowTag,	x"01",	OutMDataAddr&PadT,		   OutMNumRegs,			x"00",	OutMMPBitMask),
		(PWMTag,			x"00",	ClockHighTag,	x"01",	PWMValAddr&PadT,				PWMNumRegs,				x"00",	PWMMPBitMask),
		(StepGenTag,	x"02",	ClockLowTag,	x"05",	StepGenRateAddr&PadT,		StepGenNumRegs,		x"00",	StepGenMPBitMask),
		(MuxedQcountTag,		MQCRev,	ClockLowTag,	x"06",	MuxedQcounterAddr&PadT,		MuxedQCounterNumRegs,x"00",	MuxedQCounterMPBitMask),
		(MuxedQCountSelTag,	x"00",	ClockLowTag,	x"01",	NullAddr&PadT,					x"00",					x"00",	x"00000000"),
		(SSerialTag,	x"00",	ClockLowTag,	x"01",	SSerialCommandAddr&PadT,	SSerialNumRegs,		x"10",	SSerialMPBitMask),
		(XFrmrOutTag,	x"00",	ClockLowTag,	x"01",	XFrmrDataAddr&PadT,			XFrmrNumRegs,			x"00",	XFrmrMPBitMask ),
		(InMTag,					x"00",	ClockLowTag,	x"01",	InMControlAddr&PadT,			InMNumRegs,				x"00",	InMMPBitMask),
		(LEDTag,			x"00",	ClockLowTag,	x"01",	LEDAddr&PadT,					LEDNumRegs,				x"00",	LEDMPBitMask),
		--(NullTag,				x"00",	NullTag,			x"00",	NullAddr&PadT,					x"00",					x"00",	x"00000000"),
		(PktUARTTTag,			x"02",	ClockLowTag,	    x"01",	PktUARTTDataAddr&PadT,		    PktUARTTNumRegs,		x"00",	PktUARTTMPBitMask),  	--+++add
		(PktUARTRTag,			x"02",	ClockLowTag,	    x"01",	PktUARTRDataAddr&PadT,		    PktUARTRNumRegs,		x"00",	PktUARTRMPBitMask),		--+++add
		(InMWidth0Tag,			x"00",	NullTag,			x"00",	NullAddr&PadT,					x"00",					x"00",	x"0000000B") -- hide this tag here until we find a better way
	constant PinDesc : PinDescType :=(
-- 	Base func  sec unit sec func 	sec pin
		IOPortTag & x"00" & InMTag & InMData0Pin,     			  		-- I/O 00 	embedded 7I96 Simple I/O
		IOPortTag & x"00" & InMTag & InMData1Pin,   			  		-- I/O 01
		IOPortTag & x"00" & InMTag & InMData2Pin,   			  		-- I/O 02
		IOPortTag & x"00" & InMTag & InMData3Pin,  			  	   	    -- I/O 03
		IOPortTag & x"00" & InMTag & InMData4Pin,   			   	 	-- I/O 04
		IOPortTag & x"00" & InMTag & InMData5Pin,  			      	    -- I/O 05
		IOPortTag & x"00" & InMTag & InMData6Pin,  			     		-- I/O 06
		IOPortTag & x"00" & InMTag & InMData7Pin,       				-- I/O 07
		IOPortTag & x"00" & InMTag & InMData8Pin,    					-- I/O 08
		IOPortTag & x"00" & InMTag & InMData9Pin,       				-- I/O 09
		IOPortTag & x"00" & InMTag & InMDataAPin,       				-- I/O 10
		IOPortTag & x"00" & XfrmrOutTag & XfrmrOut0Pin, 			  	-- I/O 11
		IOPortTag & x"00" & XfrmrOutTag & XfrmrOut1Pin,  			 	-- I/O 12
		IOPortTag & x"00" & XfrmrOutTag & XfrmrOut2Pin,  			 	-- I/O 13
		IOPortTag & x"00" & XfrmrOutTag & XfrmrOut3Pin,  			 	-- I/O 14
		IOPortTag & x"00" & OutMTag & OutMData4Pin,   		            -- I/O 15
		IOPortTag & x"00" & OutMTag & OutMData5Pin,   		            -- I/O 16
		IOPortTag & x"00" & StepGenTag & StepGenStepPin,				-- I/O 17	embedded 7I96 Step/Dir/Enc/Serial
		IOPortTag & x"00" & StepGenTag & StepGenDirPin,					-- I/O 18
		IOPortTag & x"01" & StepGenTag & StepGenStepPin,				-- I/O 19
		IOPortTag & x"01" & StepGenTag & StepGenDirPin,					-- I/O 20
		IOPortTag & x"02" & StepGenTag & StepGenStepPin,				-- I/O 21
		IOPortTag & x"02" & StepGenTag & StepGenDirPin,					-- I/O 22
		IOPortTag & x"03" & StepGenTag & StepGenStepPin,				-- I/O 23
		IOPortTag & x"03" & StepGenTag & StepGenDirPin,					-- I/O 24
		IOPortTag & x"04" & StepGenTag & StepGenStepPin,				-- I/O 25
		IOPortTag & x"04" & StepGenTag & StepGenDirPin,					-- I/O 26
		IOPortTag & x"02" & MuxedQCountTag & MuxedQCountQAPin,		    -- I/O 27
		IOPortTag & x"02" & MuxedQCountTag & MuxedQCountQBPin,		    -- I/O 28
		IOPortTag & x"02" & MuxedQCountTag & MuxedQCountIDXPin,		    -- I/O 29
		IOPortTag & x"00" & PktUARTRTag & PktURDataPin, 				-- I/O 30   +++add
		IOPortTag & x"00" & PktUARTTTag & PktUTDataPin,  				-- I/O 31   +++add
		IOPortTag & x"00" & PktUARTTTag & PktUTDrvEnPin,				-- I/O 32   +++add
		IOPortTag & x"00" & XfrmrOutTag & XfrmrRefPin,    				-- I/O 33
																		--		Expansion port
																		-- GPIO     DB25		HDR26
		IOPortTag & x"00" & SSerialTag & SSerialRX5Pin, 				-- I/O 34	PIN 1    PIN 1
		IOPortTag & x"00" & SSerialTag & SSerialTX5Pin, 				-- I/O 35	PIN 14   PIN 2
		IOPortTag & x"00" & SSerialTag & SSerialRX4Pin, 				-- I/O 36	PIN 2    PIN 3
		IOPortTag & x"00" & SSerialTag & SSerialTX4Pin, 				-- I/O 37	PIN 15   PIN 4
		IOPortTag & x"00" & SSerialTag & SSerialRX3Pin, 				-- I/O 38	PIN 3    PIN 5
		IOPortTag & x"00" & SSerialTag & SSerialTX3Pin, 				-- I/O 39	PIN 16   PIN 6
		IOPortTag & x"00" & SSerialTag & SSerialRX2Pin, 				-- I/O 40	PIN 4    PIN 7
		IOPortTag & x"00" & SSerialTag & SSerialTX2Pin, 				-- I/O 41	PIN 17   PIN 8
		IOPortTag & x"00" & SSerialTag & SSerialRX1Pin, 				-- I/O 42	PIN 5    PIN 9
		IOPortTag & x"00" & SSerialTag & SSerialTX1Pin, 				-- I/O 43	PIN 6    PIN 11
		IOPortTag & x"00" & MuxedQCountSelTag & MuxedQCountSel0Pin, 	-- I/O 44	PIN 7    PIN 13
		IOPortTag & x"00" & MuxedQCountTag & MuxedQCountQAPin,		    -- I/O 45	PIN 8    PIN 15
		IOPortTag & x"00" & MuxedQCountTag & MuxedQCountQBPin,		    -- I/O 46	PIN 9    PIN 17
		IOPortTag & x"00" & MuxedQCountTag & MuxedQCountIDXPin,		    -- I/O 47	PIN 10   PIN 19
		IOPortTag & x"01" & MuxedQCountTag & MuxedQCountQAPin,		    -- I/O 48	PIN 11   PIN 21
		IOPortTag & x"01" & MuxedQCountTag & MuxedQCountQBPin,		    -- I/O 49	PIN 12   PIN 23
		IOPortTag & x"01" & MuxedQCountTag & MuxedQCountIDXPin,		    -- I/O 50	PIN 13   PIN 25
		LIOPortTag & x"00" & PWMTag  & PWMAOutPin, 						-- 7I96S analog out PWM
		LIOPortTag & x"00" & PWMTag  & PWMBDirPin, 						-- dummy for now
		emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,
		emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,
		emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin, -- added for IDROM v3
		emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin);
end package PIN_7I96S_7I85D_51_pkt;
  • Hakan
  • Hakan
23 Dec 2025 08:16 - 23 Dec 2025 08:17
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
Hello Mr tar_san,
the output of dmesg was very helpful. We need to fix all issues appearing,
the first one is your drive is a EoE-capable drive. Ethernet over Ethercat.
Unfortunately linuxcnc doesn't support that.
The best way is to disable eoe in the ethercat mastyer.
Remove the installed ethercat master.
Then download ethercat master from the official site
Configure using the --disable-eoe=true option
git clone https://gitlab.com/etherlab.org/ethercat
./bootstrap
./configure --sysconfdir=/etc --disable-eoe=true
make all modules
... and so on, continue to build and configure your system. Instructions are here.
gitlab.com/etherlab.org/ethercat/-/blob/stable-1.6/INSTALL.md
There is another possibility to disable EoE, but that disables EoE in the drive, and I would think
you need EoE for communication with some Yaskawa tuning software. Guessing, but not unlikely.
Test with the new ethercat master, the EoE messages should now be gone.
Let's see how many of the other messages are still there and then we act on them.
Referring to my previous post. Please add on the master line
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1" syncToRefClock="true">
If syncToRefClock gives an error because it is not supported (yet), use the following syntax:
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
Note the minus sign.
Let's see how far you come with those modifications. If there are still problems,
please show the output of dmesg again, and any errors from linuxcnc.
  • Nator
  • Nator
23 Dec 2025 08:10
Replied by Nator on topic Mesa Card Basics
Mesa Card Basics
HI PCW,
thank you for your Answer!
But for a better understanding. How is the communication between LinuxCNC and the Card done? With the LPT "communication" the LinuxCNC software gets a command to go 3mm in X direction, so "itself" sends the pulses on the LPT in the (hopefully) correct speed.
Does LinuxCNC still sends "pulses" when it has a mesa card and the card only corrects the jitters? Or is there some kind of communication so that LinuxCNC just sends go 3mm in that speed and the card does the pulses? LinuxCNC then know how long it takes for that movement and after this time it send the next command.
With the second approach it would probably be really hard to do something like probing.
Thanks !
  • cmorley
  • cmorley
23 Dec 2025 05:26
Replied by cmorley on topic qtdragon_hd updated handler issue
Category: Qtvcp
I checked 2.9.7 and 2.9.3. I see no jogging with screen buttons issue.
I'm assuming you mean the screen buttons.
It could be a key repeat issue.
I would suggest updating your whole system to 2.9.7 before I'd suggest updating the handlerfile, but we should see if it's a system problem first.
Displaying 5281 - 5295 out of 16970 results.
Time to create page: 0.610 seconds
