  • unknown
  • unknown
13 Dec 2025 14:40
Replied by unknown on topic Linuxcnc Rpi4/5 Images
Category: Installing LinuxCNC
langdons as these are release candidates I would prefer if these are only available from the links on my github page. If you have any images with rcX in the file name on your server could you please kindly remove them.
13 Dec 2025 14:40
Replied by tommylight on topic 6i25 and 7i77 config
Category: Driver Boards
No, not really, you will need another PC at least.
Lets clear something up first, does the PC reboot when turning ON the Mesa cards, or, when running LinuxCNC ?
13 Dec 2025 14:37
Replied by tommylight on topic Clearpath HLFB amp.joint.delay
Category: HAL
@Spumco,
Thank you for reminding me, now i know why i can not recall what was going on as i am used to ignoring everything having to do with clearpath since back when they were selling stepper motors and labeling them as "revolutionary servo motors" for a lot more $, and i think they still do, but now with encoder feedback.
  • spumco
  • spumco
13 Dec 2025 14:26
Replied by spumco on topic Clearpath HLFB amp.joint.delay
Category: HAL
Thank You for that looks like the .hal file is correct now I am assuming I dont have correct settings in the motors thought it would fault if power/loss of com .
or am I missing a config for that?
This is why I suggested the FIRST thing was to verify/edit the motor programming using the Clearpath software.
You cannot successfully edit/adjust HAL unless you know exactly what the motor(s) HLFB output is doing under various conditions.
Power up the motors - no need to enable in LCNC - connect a Windows computer to the motors and open the Clearpath software.  Verify that all motors' HLFB output is set to 'Servo On.'
Check your LCNC input pins are working correctly.  You can enable/disable the motors using the Clearpath software (overriding LCNC's output).
While you enable/disable the motors via Clearpath software, two things should happen:
  • The Clearpath software display should show 'servo on' in the output monitor
  • LCNC halshow input pins should be high/yellow when enable is true, and low/dark when the motor is not enabled
@tommylight - Clearpath motors have no separate drives.  The motors are supplied with DC power and all programming/control stuff is mounted internally in the motor itself.  They have three inputs (enable + A + B), and a single output (HLFB) that can be programmed to do different things.
  • vibram
  • vibram
13 Dec 2025 13:54
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
some little progress made, I managed to flash the EEPROM, the name of the device changed and I don't see the input/output anymore.
However, I m not able to pass the INIT step
  • vibram
  • vibram
13 Dec 2025 12:53 - 13 Dec 2025 13:06
  • cdamm11
  • cdamm11
13 Dec 2025 12:38
Replied by cdamm11 on topic 6i25 and 7i77 config
Hi Tommy!
The PC only has 1 PCIE X16 so that is problematic :(
I can see this in terminal:
mesaflash --device --5i25
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort SSerial 0 TXEn2 (Out)
14 1 IOPort SSerial 0 TXData2 (Out)
2 2 IOPort SSerial 0 RXData2 (In)
15 3 IOPort SSerial 0 TXData1 (Out)
3 4 IOPort SSerial 0 RXData1 (In)
16 5 IOPort SSerial 0 TXData0 (Out)
4 6 IOPort SSerial 0 RXData0 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort SSerial 0 TXEn5 (Out)
14 18 IOPort SSerial 0 TXData5 (Out)
2 19 IOPort SSerial 0 RXData5 (In)
15 20 IOPort SSerial 0 TXData4 (Out)
3 21 IOPort SSerial 0 RXData4 (In)
16 22 IOPort SSerial 0 TXData3 (Out)
4 23 IOPort SSerial 0 RXData3 (In)
17 24 IOPort MuxedQCountSel 6 MuxSel0 (Out)
5 25 IOPort MuxedQCount 3 MuxQ-A (In)
6 26 IOPort MuxedQCount 3 MuxQ-B (In)
7 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 28 IOPort MuxedQCount 4 MuxQ-A (In)
9 29 IOPort MuxedQCount 4 MuxQ-B (In)
10 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 5 MuxQ-A (In)
12 32 IOPort MuxedQCount 5 MuxQ-B (In)
13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
is there anything else i can test in software / firmware / drivers?
13 Dec 2025 12:04
When i load the program my pc just reboots.
That is most certainly a PC issue, not Mesa/LinuxCNC issue, so the first thing to try is insert the 6i25 into another PCI-E slot, even the long 16X one will work, and so will 8X and 4X ones.
  • Hakan
  • Hakan
13 Dec 2025 11:52
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
I guess it is not obvious what to do, and one needs a drive with EoE to test with as well.
I looked around a bit and it's not so common with EoE in the drive especially the cheap ones
don't have it.
I did find an opening though, it's in the SOEM and SOES ethercat master and slave libraries I use for embedded things.
They actually support EoE both master and slave.
I have a bit extra time now when I'm waiting for the hip to grow out again and will read up on that and try to understand the steps.
Then it should be possible to adopt this to IgH and lcec. Maybe.
  • cdamm11
  • cdamm11
13 Dec 2025 11:51
6i25 and 7i77 config was created by cdamm11
Hello LinuxCNC experts!
I am having a hard time setting up my LinuxCNC configuration. I have a 6i25 and 7i77. I have confirmed 5V to the P1 connector and jumper is in right hand. I have 26V on TB2. All others connector i have removed from the 7i77.
I have installed: linuxcnc_2.9.4 amd64.hybrid iso file. My Jitter is good.
I did not buy the 6i25 and 7i77 as a kit. i tried to load the firmware this way;
sudo mesaflash --device 5i25 --write (my directory)/5i25_7i77x2.bit
sudo mesaflash --device 5i25 --reload
i used the files from mesa website. And it seems to flash without problems.
Than i tried to use pnconf. i setup the encoders XYZ and PWM XYZ and the correct scaling.
When i load the program my pc just reboots. I get no errors. I tried to alot of things from these forums but i cant get any sucess.
Best regards Christian
13 Dec 2025 11:40
Category: HAL
Remove everything except timedelay and fault inputs.
I still have no idea what your issue is, i am replying to your queries as they come.
Such errors should not be triggered when drives are enabled, so that might well be drive issue.
  • rodw
  • rodw's Avatar
13 Dec 2025 10:07
7i92 cnc motion controller from aliexpress?
Thanks also from me  and to Rod for his AI free help  youtubes.
You are welcome!
I have sometimes used AI to research the topics but when AI starts quoting my forum posts I know I am on my own! :)
  • rodw
  • rodw's Avatar
13 Dec 2025 10:00
Category: EtherCAT
I wonder if you raised an issue for lcec if Scott might become motivated to enhance the hal driver?
Its odd its taken so long before the issue was raised......
  • SrLange61
  • SrLange61's Avatar
13 Dec 2025 08:35
Replied by SrLange61 on topic 7i92 cnc motion controller from aliexpress?
After 15 years of lunuxcnc software steping I now have a mesa. Every time I've looked into buying one the postage has been the killer. I'm still waiting for the other parts. After I add a wifi usb the old  config I guess can stay as I will only have to change the plug going into the  Geckodrive. VDF control uses VDFmod from the computer USB.Its had a bit of use this year cuting out about 20 foamboard RC planes. Thanks also from me  and to Rod for his AI free help  youtubes.
srl
Displaying 5626 - 5640 out of 16961 results.
Time to create page: 0.305 seconds
