  • Masiwood123
  • Masiwood123's Avatar
  • MaHa
  • MaHa
12 Dec 2025 22:24 - 13 Dec 2025 01:21
freelancer needed to create a routine for ATC tool change (rackchange)
I see you got replys already, while preparing this.  My idea to solve that, by adding the gap value for tool 4 to 6. Extend the ini entry for [TOOL_SLOT_DELTA] by y_gap, then apply that value for tool 4 to 6
in o<rack_change> sub
  o300 if [#<_current_tool> GT 0 ]
    (print, idem da ostavim alat)
  o302 if [#<_current_tool> GE 4 ]
       #<y_gap> = #<_ini[tool_slot_delta]y_gap>]
  o302 else
       #<y_gap> = 0
  o302 endif
    o301 if [EXISTS[#<_ini[change_position]x>]]
     G53 G0 Y [#<_ini[change_position]y> + #<y_gap> + #<_current_tool> * #<_ini[tool_slot_delta]y>] X [#<_ini[change_position]x>]
     G53 G0 Z #<_ini[change_position]z>
    o301 endif
in .ini
[TOOL_SLOT_DELTA]
X = 0
Y = -111
Z = 0
y_gap = 317
Edit:
AS the 'tool_slot_delta' is always added, the 'y_gap' should be reduced by 111 to 206
  • Fastfred
  • Fastfred
12 Dec 2025 21:34
Replied by Fastfred on topic Clearpath HLFB amp.joint.delay
Category: HAL
I think I need (joint.X.amp-fault-in) but not sure correct spot to insert.
  • Masiwood123
12 Dec 2025 20:59
thanks Rodw, I can try ``it in the air'' but that would also be ok if I get a change for slot 4, but since slot 5 and 6 are also bigger than GT3, then I will get some other distance for 5 and 6, unless I make additional lines again, ``if GT4`` is bigger than 4, then again only delta y will work, which is 111mm?
  • rodw
  • rodw's Avatar
12 Dec 2025 20:43
The distance between 3&4 = 317 and its therefore 206mm  more than the delta. (111_206 - 306)
I think I would save this gap in the ini file as a seperate variable and calculate the tool position and do something like
#tool_pos = #<_current_tool> * #<_ini[tool_slot_delta]y>]
if #<current_tool GT 3>
  #tool_pos = #tool_pos + 206
G53 G0 Y [#<_ini[change_position]y> + #tool_pos X [#<_ini[change_position]x>]
I'll leave it to you to sort out the syntax as gcode is not my strong point. We have postprocessors for that!
  • vibram
  • vibram
12 Dec 2025 20:29
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
Thank you,
some little progress made, everything compile, run LED is blinking in the LAN9252 board, but I-m not in OP mode yet:
What worries me is that I can still see the original configuration with available switches in Twincat
This means the EEPROM is not flashed correctly I guess?
  • rodw
  • rodw's Avatar
12 Dec 2025 20:10 - 12 Dec 2025 20:15
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
I want over to etherlab's gitlab to request EoE could be disabled in the Ethercat.conf file but I then found that this was already a bug scheduled to be fixed in their next release (1.7) Issues 176 and 157 refer with the latter referring to linuxcnc and this exact drive.
gitlab.com/etherlab.org/ethercat/-/issue...MTY3MDcyMTkwfQ%3D%3D
It still seems wrong to me that disabling a feature requires recompiling...
  • NWE
  • NWE's Avatar
12 Dec 2025 19:52 - 12 Dec 2025 21:34
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
I might start a separate thread for the project of writing up a complete reusable custom single axis hal component. I think it would have a lot of uses.
At the moment I am preparing to drive Y axis up/down with the footpedal. This is what I've been able to learn so far:
1: The proportional valve sets the tonnage, and also provides the open-center? flow from the fixed displacement pump back to the tank. If there was any tonnage feedback originally, it had to be measured from the coil's armature position by analyzing the a.c. component of the coil drive pwm, I think. I see no other electronic connection to that hydraulic circuit. If I end up needing tonnage feedback, I will use a pressure sensor.
2: The servo valves provide directional variable speed control of the left and right side independently
3: 4.0 and 5.0 are labeled 'servo valve', 8.4 is labeled 'proportional valve' The valve bank also has 6 spool valves (listed in the order shown in the manual.  They are only numbered but appear to be common spool valves with 24VDC coils.) I label the servo valves with polarity markings. The book displays up and down pointers instead, so I'm guessing at polarity.
They operate in combinations to produce these hydraulic 'modes':
| Motion                   | Valves Active                                  |
| high speed down   | 9.1, 10.1, 6.1, 7.1, -4.0, -5.0           |
| press speed down | 8.5, 8.1, 8.4, -4.0, -5.0                    |
| pressure holding   | 8.5, 8.1, 8.4, -4.0, +4.0, -5.0, +5.0 |
| pressure relief       | 8.1, +4.0, +5.0                               |
| creep up                | 8.1, 8.4, +4.0, +5.0                        |
| high speed up       | 9.1, 10.1, 8.4, +4.0, +5.0               |
I see I do not need to individually power every single solenoid; some are connected to the same control relays; I list only the 24VDC solenoids here with their relays; the pwm controlled valves do not have relays, they have a power disconnect (e-stop circuit) contactor right after the 24VDC power supply unit:
| Relay | Solenoids |
| 200   | 9.1, 10.1  |
| 201   | 6.1, 7.1    |
| 202   | 8.5           |
| 203   | 8.1           |
For the pwm driving the coils, after some studying, it appears all three need essentially the same kind of power to activate them. (except the proportional is not reversible) PWM is listed as 300HZ, but from what I found so far, higher is totally fine. The important gotcha is for accurate control, it needs to dither by nn% at maybe 30Hz. So I think instead of superimposing a slow pwm on the fast hardware pwmgens, I will use a software siggen running at 30HZ and the offset component to superimpose dither upon my hardware pwmgen.value command.
  • Masiwood123
12 Dec 2025 19:45
Replied by Masiwood123 on topic Physical buttons to 7i96s+7i77
Category: HAL
I tried it just now, sorry for the late response, now there are no errors, however, whichever scale I put, both do not work smoothly, only on 4 sections in terms of feed type, it goes 30,60,90,120%
  • Fastfred
  • Fastfred
12 Dec 2025 19:22
Category: HAL
Just got back to it, have screen shots showing HLFB input pins inactive and active with machine enable ( think I did this correct) Two things only have the x axis active everything else commented out. Wasn't sure how to configure the output portion at the moment i have one output to enable the drives and the second thing was should the x axis fault with this config when i disconnect it at the moment it does not.
File Name: custom_2025-12-12.hal
File Size:1 KB
  • T_D
  • T_D
12 Dec 2025 19:13
Replied by T_D on topic Mesa konfiguration Maho 500 W4
Category: Driver Boards
Thank you for this answer , that means i can use the 7i97t and connect as much cards that i need together or does something like limit exist for this combination ? Or is it better to wait for the 7i77 to get available ?
  • Masiwood123
12 Dec 2025 18:36
File Name: beta1_2025-12-12.ini
File Size:5 KB
File Name: beta1_2025-12-12.hal
File Size:13 KB
File Name: rack_chang...2-12.ngc
File Size:2 KB
if someone know to edit ini and rack_change.ngc files according to my y positions for tool 4,5,6 here are my files.thank you
  • gravedigger
  • gravedigger
12 Dec 2025 18:31
Replied by gravedigger on topic stepgen maxvel too big and SRO problem
Category: Gmoccapy
I tested with gmoccapy and dragon.
The MOV doesn't work. The spindle and the normal feed work with enc3.
# ---Überschreibung von Signalen zum Mesa-Geber - mpg (feed override signals to mesa encoder - mpg)---
net fo-count <= [HMOT](CARD0).7i73.0.0.enc1.count
# Vorschub-Override-Schritte verbinden - MPG (connect feed override increments - MPG)
setp halui.feed-override.direct-value false
setp halui.feed-override.scale .01
setp halui.feed-override.count-enable true
net fo-count => halui.feed-override.counts
# ---max Geschwindigkeit Neufestsetzungs-Signale an Mesa Encoder - mpg (max velocity override signals to mesa encoder - mpg)---
net mvo-count <= [HMOT](CARD0).7i73.0.0.enc3.count
# verbinde max Geschwindigkeit Neufestetzung Inkrement - MPG (connect max velocity override increments - MPG)
setp halui.max-velocity.direct-value false
setp halui.max-velocity.scale 0.666667
setp halui.max-velocity.count-enable true
net mvo-count => halui.max-velocity.counts
  • Ismacr63
  • Ismacr63
12 Dec 2025 18:25
Replied by Ismacr63 on topic VFD configuration help
Category: Turning
That's true, but I'd like to have the buttons because that's the configuration I've had until now.
What kind of relay do I need?
  • Masiwood123
12 Dec 2025 17:14 - 12 Dec 2025 17:29
The space between 3 and 4 do not agree to say that it is possible to divide by 111I would like all 6 tools to work, the delta between 1,2,3 is 111mm, so there is a gap, so the same delta raster between 4,5,6 is also 111mm, so the distance between 3 and 4 is 317mm...I will post the script for the first 3 tools later...if I copy and put an additional [change position delta 2]' in the ini file with ``if<current_tool GT 3>`` it doesn't work
Displaying 5656 - 5670 out of 16961 results.
Time to create page: 0.317 seconds
