  • MaHa
  • MaHa
30 Nov 2025 20:17 - 30 Nov 2025 21:33
Problem with linear movement was created by MaHa
At the moment i cant run my routines with parameters.
easy to test:
#333 = 20
g0 g54 g43 z#333
Edit:
The error occurs on different ui, so it seems linuxcnc related. If other axis are affected, i dont know, because first z-movement lead to abort.
No matter if numbered or named parameter are used
Preview is working
30 Nov 2025 19:43
Replied by tommylight on topic Wie stabil läuft eigentlich die Linux CNC Sache?
Category: Deutsch
Das Mint Ding ist eine heavy Distribution....wirkt sich das mit der Ethernet Mesa negativ aus oder packt das ein I5 PC mit 8 GB Ram?
Sorry, aber English gehts schneller,
If you ask "the internet" yes, Mint is a heavy distribution, but that has nothing to do with reality as windows is extremely heavy compared to it.
The reality is, Mint works perfectly, it is very reliable, well it is the most reliable distro for sure, and if it works for you, do not worry about what internet says.
Mint will happily work with 4GB of ram, so 8GB are fine, and if it helps, i use Mint on industrial machines in daily use, although i use the Mate edition, and on much older PC's without issues, ever.
  • COFHAL
  • COFHAL
30 Nov 2025 19:40
Replied by COFHAL on topic Physical buttons to 7i96s+7i77
Category: HAL
Could you post your configuration files so we can take a look and see what the problem is?
  • rodw
  • rodw's Avatar
30 Nov 2025 19:33
Replied by rodw on topic Locations of LinuxCNC
Category: Installing LinuxCNC
The latest 2.97 version is also available in Debian Testing. The Debian Trixie release version includes 2.94 but it's a trivial 5 minute job to set up APT pinning to just get LinuxCNC from testing and everything else from Trixie as I show here:
forum.linuxcnc.org/9-installing-linuxcnc...97-and-later-forever
This will support any future LinuxCNC upgrades that are pushed to Debian
  • andypugh
  • andypugh's Avatar
30 Nov 2025 19:10
Replied by andypugh on topic Upgrade advice for ooold system
The CPU is 64-bit so there may be an upgrade path.
Why not try booting from the latest ISO image on a USB stick and see what haoppens?
www.linuxcnc.org/iso/linuxcnc_2.9.7-amd64.hybrid.iso
  • andypugh
  • andypugh's Avatar
30 Nov 2025 18:51
Replied by andypugh on topic 7i84u probably toasted
Category: Driver Boards
Ah well, it was an expensive evening
I have had more expensive ones, and nothing to show afterwards but a hangover :-)
  • andypugh
  • andypugh's Avatar
30 Nov 2025 18:46
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
I generally install avahi + samba on my Linux machine and that gives me a bonjour-style easy networking setup.
(My home system is a mixture of MacOS and Linux, Windows not invited to play but does connect when I am working from home as my job requires a lot of windows-only software.
  • Hexagon
  • Hexagon
30 Nov 2025 18:22
EtherCAT servo as main spindle was created by Hexagon
Category: EtherCAT
Hello, everyone. I have a problem configuring a servo from StepperOnline: A6-1000EC. My goal is to control this servo via the python api. It should be possible to position it between 0 and 360° as well as rotation with different speeds.
My first attempt was to configure the servo as an angular axis. Then I wrote a simple python program to control the axis via JOG_INCREMENT and JOG_CONTINOUS. For absolute positioning I switch to MDI mode and send my target position. This works totally fine, but I can't run gcode with this solution, because I can't turn the servo continuous in one direction.
So I tried setting up this as a spindle instead. At first I changed my xml so I can process target-velocity and control-mode. Then I used a mux2 to change the control-mode depending on the use of M3/M4/M5 or M19. This works fine and my frequency drive changes between mode8 and mode9. The spindle control with M3/M4/M5 also works fine, but when I enter a command like M19 R180 Q2 P0 the servo drive throws a fault. When the target position is near the actual position this works, so I assume it is some sort of following error. My bigger problem is, that the actual position of the motor after using M3 for some time is very large, cause it is not restricted to one revolution. Is there a way to change that? At my first attempt using it as an axis I used wrapped_rotary, but that only affected the display, not the actual value.
Does anyone know what I could do, or if there is a better way for the use of an servo as position and continuous motion?
Many thanks in advance
  • andypugh
  • andypugh's Avatar
30 Nov 2025 18:12
Replied by andypugh on topic 7C80 on RPI5
7C80 on RPI5
Someone should ask Mesa why the firmware is in the "Specifications" tab and not, for example, a "support" tab :-)
  • abs32
  • abs32
  • andypugh
  • andypugh's Avatar
  • abs32
  • abs32
30 Nov 2025 17:56
Replied by abs32 on topic Issue with G38.5
Issue with G38.5
If you insert M66 P0 L0 between the probe moves then the queue might be cleared as a side effect.
Great news, thanks for the idea. I'll check it out tomorrow with version 2.9.7 and let you know the results.
  • andypugh
  • andypugh's Avatar
30 Nov 2025 17:55
Replied by andypugh on topic stepgen maxvel too big and SRO problem
Category: Gmoccapy
The GUI's don't always "know" that you have changed an override.
Which GUI are you using? And how are you overriding (ie, which HAL pins are the counts going to?)
  • andypugh
  • andypugh's Avatar
30 Nov 2025 17:20
Replied by andypugh on topic The Current Bread & Butter Setup?
For reproducible hardware the Pi5 is probably a good choice. It's not the absolute best of platforms, but it is a known quantity and that would be useful if you are making multiples of the system.
  • Billy Boy
  • Billy Boy
30 Nov 2025 17:13
The Current Bread & Butter Setup? was created by Billy Boy
I'm looking for suggestions for a simple bread & butter Linux CNC install.
It seems like an Raspberry Pi 5 + Mesa 7i96S might be the current standard, but it's not super clear? A while back it seemed like the Beaglebone was a good option, but it seems things have not gone that way?
Background...
I've built/retrofitted a number of machines with Linux CNC, but not for perhaps 10 years.  I've done a lot of machining and I'm fully competent with Linux.
I've got a new project that wants to integrate 2 Sherline CNC chucker lathes with some additional widgets.  Each lathe would get its own LinuxCNC hardware & software and the integration would be via ssh/linux command line.
If I can get the system working well, I might get orders for 10 or 50 of these systems over the next few years, so I would really like to use a stable, easy to get, standardized off-the-shelf parts, that can be expected to remain available for the next 5 years. I'm *not* looking to cobble something together out of 10 year old PCs, and I'd prefer not to build on some wierd/cheapo/legacy PC off Amazon which may go away in 3 months.
I'm looking for a simple reliable bread & butter LinuxCNC platform.
Suggestions?
BB
Displaying 6106 - 6120 out of 16956 results.
Time to create page: 0.880 seconds
