  • BoMadsen
  • BoMadsen
22 Nov 2025 20:27
Replied by BoMadsen on topic 7i76eu steppers don't move
Category: Driver Boards
PCW you are impressive! I checked the original wiring of the Mach3 board the mill came with, and it used single ended wiring using only the negative wires for STEP and DIR, so I tried to change that.
No change when using the UI, it still shows following error. But then I tried the servo tuning test in pncconf, and the steppers are now moving :)
Now I just need to figure out the following error, but at least now I know that the hardware is working.
Thank you very much, your help is much appreciated!
  • Sekai
  • Sekai
22 Nov 2025 19:08
Replied by Sekai on topic Chinese Mesa 7I92 from aliexpress NEW
I think the max value is to high.
Maybe the cpu needs to tweak?
  • abs32
  • abs32
22 Nov 2025 18:37 - 22 Nov 2025 18:42
Probe tripped during non-probe move deadlock
I installed version 2.9.4 and 2.9.7 and they work worse, replacing this error with another one - Queue is not empty after probing.
In this regard, I ask you to publish a complete road map on what is quoted here forum.linuxcnc.org/38-general-linuxcnc-q...obing?start=0#333528"
a solution to this topic.
It says about "Great HAL": www.forum.linuxcnc.org/38-general-linuxc...dlock?start=0#332412
Now I have such entries in hal -
net probe-in <= parport.0.pin-13-in-not
net probe-in => motion.probe-input
By analogy with "Great HAL" I assume this -
loadrt flipflop count=0
loadrt flipflop count=1
addf flipflop.0                 servo-thread
addf flipflop.1                    servo-thread
setp   flipflop.0.set FALSE
setp   flipflop.0.data  TRUE
net probep-in        parport.0.pin-13-in-not  => flipflop.0.clk #при этом отключить базовый вариант
net probere-set      motion.digital-out-00    => flipflop.0.reset
net probefiltered   flipflop.0.out           => motion.probe-input  parport.0.pin-01-out
However, how can this be related to the M64 P0 + M65 P0 call?
It is not clear why the Greet HAL example contains addf flipflop.1 (in addition to addf flipflop.0) if flipflop.1 is not used in any way according to the example?
  • 1911ut
  • 1911ut
22 Nov 2025 18:37
Replied by 1911ut on topic Is something up with 2.9.7 (joint errors)
Thanks for you help.
I found the problem, I guess I am getting too old. (72)
It was a new install and I copied the wrong hal configuration.
I do regular backups and name folders by date (2025-11-11)
I must have read the folder wrong.
Culprit was
setp pid.x.maxerror 0.0005
Every thing is back to normal
  • PCW
  • PCW's Avatar
22 Nov 2025 18:35 - 22 Nov 2025 18:49
Replied by PCW on topic 7i76eu steppers don't move
If you get a following error, no further movement will be possible so a configuration
issue the causes a following error is s show-stopper.
Other possible reasons for no motion are wrong scaling, too short step lengths
high drive requirement (try single  ended wiring rather than differential)
Single ended wiring:
DRIVE STEP+  --> 7I76EU STEP+
DRIVE STEP-  --> 7I76EU GND
etc
  • Lcvette
  • Lcvette's Avatar
22 Nov 2025 18:31
probe_basic_postgui.hal conflicts with my gamepad*.hal
Category: QtPyVCP
yeah, think that is all machines, but could be wrong
  • BoMadsen
  • BoMadsen
22 Nov 2025 18:25
I think you are spot on with the "enable" output comment, the motors where not locked. I disconnected "EN+ -> TB2 pin 6 +5VP" and bingo, the motors where locked. So far so good, thank you :) I have measured Dir+/- and the voltage here change when I jog the axis.
But alas, the motors will still not move. How ever, now I get the "Joint 0 following error" immediately when I try to move the X axis, so I suspect this is why nothing is moving. I have tried to read up on the error, and it seems to point at a misconfiguration in the PID/Acelleration/etc part of the config. But I can't really see it being SO wrong, that the motor won't start at all?
  • juergen-home
  • juergen-home
22 Nov 2025 18:19
Category: QtPyVCP
Found it out myself: it was: Is it a known problem that in "linuxcnc probe basic sim" jogging is not working after a program was run.
Workaround: clicking the “Manual” button after stop.
  • Lcvette
  • Lcvette's Avatar
22 Nov 2025 18:05
Category: QtPyVCP
great glad you got it sorted out! what thread for the other issue, i do not see it in the qtpyvcp section?
  • PCW
  • PCW's Avatar
22 Nov 2025 17:47
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
The watchdog error is a sign of network latency issues.
I would try:
sudo chrt 99 ping -i .001 -q-c 60000 10.10.10.10
which should run for 1 minute and then print timing statistics
to see if this is the issue.
  • Lcvette
  • Lcvette's Avatar
22 Nov 2025 17:40
problems with Y-Axis, elliptic deviations after several changes -Probe Basic V.5
Category: QtPyVCP
could be lost steps causing some errors. i would set the drive settings to fault for ANY lost steps and tune the system until it is not faulting. this would eliminate that. you don't want to run the system in a state where it is losing steps because of motor sizing and machine mass problems.
also i would make sure that your acceleration calculations for both axes come out to be the same.and ideally give both axis the same reduction. just takes several things out of the equation.
  • Muzzer
  • Muzzer
22 Nov 2025 17:20
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
Progress has been made. I opened up the mini ITX PC and examined the 5i25 assembly. This is a Jetway mobo with a single PCI-E slot. I had fitted an adaptor (PCI-E to full size PCI) and a PCI extension ribbon cable to connect the 5i25 which sits parallel to the mobo. This was the root of the problem, as the adaptor board wasn't seated properly. The mechanical assembly isn't ideal, so I will need to address that to avoid a repetition in the future.
gmoccapy now works as it did previously, so I can now move on to installing a new SSD with the current version of Mint and LCNC. I will then tackle the config files etc. Watch this space.....
  • Sekai
  • Sekai
22 Nov 2025 17:14 - 22 Nov 2025 17:21
You are right.
the firmware that the seller gave me was 7i92_G540x2D_custom.bit
I did upload it but it gave an error when i started linuxcnc
I install Mesa Configuration Tools and download a firmware from there the 7i92_G540x2D without the custom part and it works.
For now i just tested the pin output
The next problem is when i start linuxcnc it gave me an error: Watchdog has bit!
from the post "Mesa 7i97 Watchdog has bit!"  i did latency-histogram --nobase --sbinsize 1000 and its like this:
btw the pc is minipc Fujitsu Esprimo Q920
  • juergen-home
  • juergen-home
22 Nov 2025 17:12 - 22 Nov 2025 18:42
Category: QtPyVCP
Thanks for your help.
I forgott that twopass is not working for POSTGUI_HALFILE.
So I moved the declaration of the "not" function to the core.sim3.hal (which I had to change into the "names=" format) and change the function names accordingly.
in probe_basic_postgui.hal:
comment out:
#loadrt not
#addf not.0 servo-thread
and in core.sim3.hal insert:
loadrt not names=not1
addf not1 servo-thread
comment out:
#net prog-running not.0.in <= halui.program.is-idle
#net cycle-timer time.0.start <= not.0.out
change in:
net prog-running not1.in <= halui.program.is-idle
net cycle-timer time.0.start <= not1.out
# changed due to a conflict
# halui.program.is-paused is used is gamepad-encoder-16.hal and in probe_basic_postgui.hal
#net prog-paused halui.program.is-paused => time.0.pause
net net-halui-program-is-paused => time.0.pause
I have another problem with pb, but in a new thread.
  • abs32
  • abs32
22 Nov 2025 16:57
How to fix "Queue is not empty after probing"
I must admit with bitterness that version 2.8.4 with its errors in the g38.3+g38.5 part (Probe tripped during non-probe move) works more stably than version 2.9.7 with all its fixes and error (Queue is not empty after probing). The same object (on the machine desktop), ode and the same g-code program, but in version 2.8.4 there are about 60,000 continuous measurements, and in version 2.9.7 there are no more than 40,000.
Displaying 6631 - 6645 out of 16715 results.
Time to create page: 0.360 seconds
