  • f355
  • f355's Avatar
19 Oct 2025 05:41
Proposal RPi Linuxcnc Image Based on Raspi OS All welcome/encoraged to comment
Category: Installing LinuxCNC
I've tried looking for a RT_PREEMPT kernel in the repos, but could only find kernels that were configured for Real time not Preemptive real time (which is what Linuxcnc requires).
the packages are on archive.raspberrypi.org . you want linux-image-6.12.34+rpt-rpi-v8-rt, it works for both RPi 4 and 5. there's a meta package linux-image-rpi-v8-rt that depends on the latest version of the RT kernel, but it gives you auto-updates with apt, which is not necessarily a good idea (e.g. the currently-latest 6.12.47 is hanging my Pi5 sometimes).
it is a proper PREEMPT_RT kernel:
$ uname -a
Linux ratcage 6.12.34+rpt-rpi-v8-rt #1 SMP PREEMPT_RT Debian 1:6.12.34-1+rpt1 (2025-06-26) aarch64 GNU/Linux
in order for bootloader to use it, you need to add kernel=kernel8_rt.img to /boot/firmware/config.txt.
the kernel configs themselves are here .
  • rodw
  • rodw's Avatar
19 Oct 2025 02:44
Replied by rodw on topic WCS Problem with Linuxcnc/qtdragon
Normally you would home the machine and then touch off on the workpiece origin. the buttons are there to do this but you can do it in gcode with G54
Maybe with your machine you always machine a full sheet but you still need to set the part origin.
  • rodw
  • rodw's Avatar
19 Oct 2025 02:30
Sorry, I have no idea about the Pi... but I did get the 4b working years ago.
  • rodw
  • rodw's Avatar
19 Oct 2025 02:29
New Probe Basic install - error during install.
Category: QtPyVCP
probe basic is not part of the linuxCNC project. You could look at qtdragon which is well documented and is part of the project. But as Tommy said, get a working system that uses axis first.
19 Oct 2025 02:05
fixing "raspi firmware" errors on the official amd64 ISO
What am i missing? Seeing you all jump through so much hoops makes me wonder what are you using as a starting point?
Back when i tested Debian BookWorm 12.2 and 12.5, i downloaded the Live ISO with XFCE, remastered it and tested, it worked and did not have raspi issues. Did the same things with 12.2 Mate edition, also no raspi issues.
Granted i used the LinuxCNC version that was on Debian repos, but still, this should not matter.
Sorry, but i feel really bad seeing you go through all the trouble.
Is there something i can help with?
P.S.
Rob, sorry, i did download your ISO but did not get to testing it.
  • DavidR8
  • DavidR8
19 Oct 2025 00:29 - 19 Oct 2025 01:49
Category: QtPyVCP
Well I tried again with a fresh LCNC install and I got almost all the way through the Probe Basic install.
Got this error on the last installation command: sudo dpkg -i python3-probe-basic_0.6.0-118.dev_amd64.deb
I looked for the application and found it but not a debian version.
Surely something is wrong with the instructions if I'm having this many issues.
  • rodw
  • rodw's Avatar
19 Oct 2025 00:14
Building on a system running Debian Trixie raspi-firmware IS NOT installed. (built twice on 2 different machines)
Building on a system running Debian Bookworm raspi-firmware IS installed. (single build only attempted)
This is because they fixed it (it's actually fixed in Debian 12.1)
bugs.debian.org/cgi-bin/bugreport.cgi?bug=1065640
They fixed the Debian release files it never pushed their changes to the Debian builder until Trixie. Very annoying.
  • rodw
  • rodw's Avatar
19 Oct 2025 00:08
Replied by rodw on topic Tutorials
Tutorials
Category: LinuxCNC Documents
Here is an installation tutorial for Debian Trixie fresh off the press today
But yes, the 1500 pages of documentation is my go to guide...
  • unknown
  • unknown
19 Oct 2025 00:05
Hiya Rod ;)
From memory the Debian Rpi kernels lacked support for overlays, which was a show stopper for SPI.
ATM I'm cross compiling a kernel from the 6.12.y branch, I think that was what was used in the January build.
  • rodw
  • rodw's Avatar
18 Oct 2025 23:54
Debian includes a RT kernel for the Pi 4b and it is possible to get a working RT linuxcnc install using the Debian images. But the RT kernel was not installed as a dependency from linuxcnc-uspace and needed installing separately with something like sudo apt install linux-image-rt-$uname -r) (might not have that correct. The only catch is that the images only install a text terminal with a root user. You needed to add a user, add sudo rights and then install xfce to get a working system ut it is quite doable. Sadly it does not appear support continued to the pi5.
  • unknown
  • unknown
18 Oct 2025 23:15
@f355
Debian doesn't have any support for the RPi5 as it doesn't have enough upstream kernel support.
wiki.debian.org/RaspberryPiImages#Overview
and
raspi.debian.net/tested-images/
So to get a full RT_PREEMPT kernel the only solution it would seem is to roll our own. Which would not be a suitable solution for upgrading.
One solution maybe if Linuxcnc could host suitable kernels, but I really don't see the sense in a regular upgrade regarding the kernel in this situation. I'm still running the original kernel that was built whilst building the image in Jan 2025.
BTW running pi-gen builds a couple of flavours of images everything from lite to a fully image. Tho it does use a significant amount of disk space.
  • andypugh
  • andypugh's Avatar
18 Oct 2025 23:08
Replied by andypugh on topic Is there a new Linuxcnc release in the wings ?
I am using the Trixie version of live-build, and building on Trixie.
(I basically did a search-replace for "bookworm" in linuxcnc-live-build and swapped to Trixie. though manually and checking surrounding code.)
So I am puzzled where the splash has gone to..
  • unknown
  • unknown
18 Oct 2025 22:53
Was replying to you on the laptop but didn't have the ISO there so had to swap machines. Well creakily walk upstairs, I swear I've skipped old age and just gone straight to decrepitude......enough banter.
I guess this is what your are referring to. I would say it appears as it should. Mind I haven't had a chance to test on real hardware yet.
Basically I started with a fresh fork from your repo and made the changes I thought would be required.
Me repo and branch can be seen here, I've tried to comment the changes made within the files and within the commits as well. I think I've even mentioned using the live-build version as well.
github.com/ozzyrob/linuxcnc-live-build/tree/ozzyrob-trixie-test
Whilst I was building on my Bookworm machine I did build a live-build package & install using this the below linked codebase, installing the Trixie package on Bookworm didn't give successful results:
If using a Trixie machine to build everything should be ok. I also found using the same source and building a package for Mint 22.1 gave a successful ISO. I think I may have mentioned this before.
salsa.debian.org/live-team/live-build/-/...rixie?ref_type=heads
Which is the code base for the live-build package for Trixie.
I hope this helps.
Cheers Rob
Displaying 8536 - 8550 out of 16967 results.
Time to create page: 0.312 seconds
