  • JanCNC
  • JanCNC
07 Oct 2025 18:22
Pncconf Wizard with MESA 7i92TM and one 7i77 - struggle
Category: PnCConf Wizard
Thanks tommy! After i changed the local language to en_US it worked.
  • mark-v-d
  • mark-v-d
07 Oct 2025 18:13
Replied by mark-v-d on topic Fanuc encoders
Fanuc encoders
Category: Driver Boards
I have the incremental encoders in my lathe, they are the beta versions
however. On these encoders the 10-bit absolute position is there and
accurate enough to use for commutation right from the start. There is
a step in this data however once the encoder passes the index.
The control computer had a backup battery, the battery connection of
the encoders was not used. So I assume the computer was responsible
for remembering the position. There are no homing sensors on the lathe,
so I guess they ran the lathe to its endstops when the battery failed.
For me the hard part was to get the encoder to respond. It wants a
positive pulse on the REQ line, and initially I was trying a negative
pulse. After that, verifying the encoder position was simple enough with
a scope indeed.
The nice part about the CRC is that there are only 32 possible
polynomials, so bruteforcing works like a charm :-)
I hope my information helps someone, but if not... nothing is lost.
I doubt reading the VHDL and C code of hostmot2 would have been faster
than what I did, but I certainly would have tried it, if had known about
it. On the other hand, the microcontroller I use can only capture frames
up to 64 bits, so knowing the padding are actually start and stop bits
was crucial.
  • Hakan
  • Hakan
07 Oct 2025 18:03
Ethercat drives not responding, mesa error finishing read
Category: EtherCAT
With that kernel version it may not be the same.
In any case, it sounds like it's something with the network, latency, etc. that PCW also points to.
  • PCW
  • PCW's Avatar
07 Oct 2025 17:48
Category: EtherCAT
I have installed r8168-dkms, and the realtek interface is using that driver. The other interface is supposedly an Intel card, using the igb driver, but it came from China, so there's no guarantee. Naturally the r8169 driver gave the same problems. I have tried other ethernet cards, but they all have realtek silicon.
Have you tried pinning the Realtek interface interrupt to last processor?
(also with using isolcpus=last_processor in the kernel command line)
This has helped in many cases.
This script allows you to test this:
File Name: pinirq_2025-10-07.txt
File Size:1 KB
  • laurentl38
  • laurentl38
07 Oct 2025 17:23
Replied by laurentl38 on topic orient spindle with ethercat EL5101
Category: EtherCAT
Victory!! I finally have something working.
The spindle orients normally (all that's left is to set the orientation PID values ​​correctly...) in both directions, without using the M19's P1 or P2 prefixes.
I added an ABS for the analog control voltage of the driver command and
net spindle-fwdd abs.spindle.is-positive => lcec.0.D3.dout-0
net spindle-revv abs.spindle.is-negative => lcec.0.D3.dout-1
It was hard and laborious, but anyway... the rest will seem almost easy to me :-)
  • Moutomation
  • Moutomation
07 Oct 2025 17:12
Replied by Moutomation on topic found an error
found an error
Category: Gmoccapy
Thanks for your reply. I guess I'll have to wait until a bug-free version is released.
  • Moutomation
  • Moutomation
07 Oct 2025 17:11
found an error
Category: Gmoccapy
self.logofile = str(args_passed[ index + 1 ]) gave an error on this line gmoccapy was not opened probably not a suitable solution for pi5
  • nanowhat
  • nanowhat
07 Oct 2025 17:04
Category: EtherCAT
Debian 13 didn't work: apt-key isn't allowed any more, and I don't know what to do to work around that. Without that, I can't install linuxcnc.
Debian 12 doesn't work either: I can install linuxcnc and ethercat, but I can't start ethercat. I see the error "modprobe: FATAL: Module ec_master not found in directory /lib/modules/6.1.0-40-rt-amd64"
  • Marko6
  • Marko6
07 Oct 2025 17:00
Replied by Marko6 on topic Ethercat, EL6751 and CANOpen
Category: EtherCAT
Greetings from the Czech Republic!
I'm working on a spindle (IMT 40kRPM) and the drive only has CAN, so I decided to use the EL6751, because everything else on my machine is on Ethercat. That's the problem.
There is a possibility that the CAN is running from TwinCAT and I can spin motor, etc. If I then connect the EK1100 to the LinuxCNC network, both cards start up (OP), but the CAN is red (flashing in the attached configuration, otherwise still red). Any idea what's wrong with that? Did I miss something?
Thank you. Best regards,
Pavel.
  • Twitchy88
  • Twitchy88
07 Oct 2025 16:53 - 07 Oct 2025 17:34
User interface was created by Twitchy88
User interface
Hello Everyone
Almost done the electrical end of my Fadal CNC retrofit. Im looking into the GUI for it now.
I see the LINUXCNC install comes with a few GUI already, is there an advantage to using those over lets say probe basic?
Right now Im leaning towards QTDragon because it comes with the install.
Thanks In advance for any help.
  • Aciera
  • Aciera's Avatar
07 Oct 2025 16:52 - 07 Oct 2025 17:01
Replied by Aciera on topic found an error
found an error
Category: Gmoccapy
I'm not familiar with pi installations but you could try these modifications to gmoccapy which also fixed the problem for me:
github.com/LinuxCNC/linuxcnc/pull/3511/files
[edit]
Without rebuilding you will need to modify 'gmoccapy' in the /bin folder.
  • Moutomation
  • Moutomation
07 Oct 2025 16:43
found an error
Category: Gmoccapy
I am using pi5, I could not find this file python_plugin.cc
  • jmelson
  • jmelson
07 Oct 2025 16:33
Replied by jmelson on topic Fanuc encoders
Fanuc encoders
It could very well be the same, but I'm not sure. This is for the beta and not the alpha series of Fanuc. Like I said, I could not find the details of the protocol anywhere, but that could also mean I did not look in the right place.
I never found any document on the data format, but I managed to insert a pulse and get the encoder to send data.  Then, I looked at it on a scope, and created an FPGA to read the data and send it to a computer via the parallel port.  I then spun the encoder by hand and wrote programs to extract the data.  The hardest thing to crack was the CRC.  I took some of the extracted data, and ran it through a program that tried many different CRC polynomials until I got a zero result from every data pattern.  Then, I coded that up in VHDL and put it into my converter product.
Your description looks JUST like what I deciphered.
One note,  There are absolute and incremental versions of these encoders, at least on the older Alpha series.  The absolute ones have extra data at the end that provides a 10-bit resolution absolute position immediately at power-on.  The incremental encoders power-up assuming rotary position zero, and then the position count jumps when they pass the index position.  So, you can't get any reliable commutation out of them without battery backup.
Jon
  • Moutomation
  • Moutomation
07 Oct 2025 16:24
found an error
Category: Gmoccapy
I use ethercat
  • partec
  • partec
07 Oct 2025 16:18
Very small 4 axis mill for cutting plastic materials
Category: Show Your Stuff
I do believe that a simplified milling procedure can be implemented.
The C-axis must be adjusted so that the milling spindle is approximately perpendicular to the cutting contour in every small section.
A fully converted X-Y-Z-C point file is required.
You write:
-pretty sure this needs TCP as the cut line is always 1mm under the material (also 1mm thick roughly)
What exactly do you mean by that TCP?
You also write:
-having a look through the included TRT configs
What exactly do you mean by that TRT?
Surely you also have an envelope file (stp or similar)?
Displaying 9091 - 9105 out of 16967 results.
Time to create page: 0.411 seconds
