  • kb58
  • kb58
28 Sep 2025 17:42 - 28 Sep 2025 19:15
(Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
Category: Driver Boards
I checked the link you provided and find the note on page 16 interesting: "... This index 0x2001 only works on ECR60. If you change it on ECT60, please find index 0x2020..."
The developer of my code intended it to be loaded into an ECT60 (closed loop) driver and configured it for an open loop stepper. Given the above statement (if true), it's odd that he sets up register 2001 but not register 2020.
<sdoConfig idx="2001" subIdx="0"> <!-- segmentation/resolution for open loop -->
            <sdoDataRaw data="40 9C" /> <!-- 40000 counts/rev -->
"For fun", I tried adding this back into ethercat-config.xml, but the error condition remains.
I looked into downloading the package onto my Windows PC but it's unclear which download to use. They have quite a few and the link just goes to their front page, not to a specific download screen. To be honest, I don't hold out much hope that dropping it in place of my config file will make it work, but as you alluded to, perhaps it contains something the manual left out. Anyway, their comment above makes me wonder all the more whether there is key documentation missing from the User Manual regarding differences between the ECR and ECT drivers... sigh.
  • andypugh
  • andypugh's Avatar
28 Sep 2025 17:36
toggle2nist hangs when pressing an other button at the same time
Category: HAL
Another possibility is that pressing two buttons means that the button-release event is not seen. So check the output pin from hal_input too.
  • andypugh
  • andypugh's Avatar
28 Sep 2025 17:11
Replied by andypugh on topic Weiler DZ26 Millturn Conversion
Category: Turning
The logic for setting that HAL pin is here, it just reports the system state:
github.com/LinuxCNC/linuxcnc/blob/master..._intf/halui.cc#L2167
Is halui.estop.activate being driven at all? Is it false?
  • andypugh
  • andypugh's Avatar
28 Sep 2025 16:49
Replied by andypugh on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
I was upbraided earlier by a friend from the Motor Club about this, as he watched your video and thought that I should have defaulted to a 55 degree angle as anything other than Whitworth is an abomination.
Adding the compound angle wouldn't be too hard, but I doubt that cutting buttress threads is that common, and you can always MDI the G76 directly if you need to.
I think that 29.5 is "not terrible" for Whitworth, but I would need to sketch a diagram to be sure. It's probably not ideal for BA threads (47.5 degree) or Panzergewinde (80 degree)
I also suspect that the macro takes many more passes than strictly necessary,
  • andypugh
  • andypugh's Avatar
28 Sep 2025 16:40 - 28 Sep 2025 16:41
Replied by andypugh on topic Python pendant logic problems
As a first step, get the encoder counting so that you can see a "counts" pin incrementing when you turn the encoder.
There are a few ways to do this mentioned above, and there is always the possibility of using the software encoder counter too, connected to GPIO pins,
Once you have the counts HAL pin working, that then needs connecting to all the axis (and joint) jog-counts pins. You then wire the switches to set the jog-enable pins of the axes/joints as required,
For the actual pin names see:
linuxcnc.org/docs/stable/html/man/man9/m...n.9.html#AXIS%20PINS
linuxcnc.org/docs/stable/html/man/man9/m....9.html#JOINT%20PINS
And possibly linuxcnc.org/docs/stable/html/man/man1/h...html#Joint%20jogging
But prefer the pins in "motion" to those in "halui" as the former run in realtime and so are more dependable.
  • andypugh
  • andypugh's Avatar
28 Sep 2025 16:07
Replied by andypugh on topic Rerunning a tool in qt_dragon_hd
Category: Qtvcp
I think that this is a consequence of the system trying to get into the same state after a run-from-line request.
But it does rather assume a toolchanger and/or repeatable length tools.
Rather than re-post the toolpath, you should be able to to comment-out the preceding tool changes in the G-code file. (Just don't forget to un-comment them, or save the modified file under a new name)
Which LinuxCNC version are you running? I think that there have been various attempts to improve run-from-line over the years.
There is discussion, but no conclusion, here: github.com/LinuxCNC/linuxcnc/issues/246#issuecomment-423049528
  • kb58
  • kb58
28 Sep 2025 15:03 - 28 Sep 2025 19:04
  • MacKaye
  • MacKaye
28 Sep 2025 13:59
Replied by MacKaye on topic Weiler DZ26 Millturn Conversion
Category: Turning
I have already asked in another estop related chat but maybe that was too old of a thread.
I have been trying to incorporate the rather complicated estop relais functionality from the original machine setup and have messed up my estop logic along the way and can not recover from all changes i have made in the meantime.
Even the easy setup i am running right now is unable to recover GUI estop from True status. I have checked behaviour in halscope and everything seems to work correctly, except somethings holding on to halui.estop.is-activated. I can find nothing about what kernel nets exist, linking internal pins to ...is-activated. What problem could be the source of that behaviour?
Thank you all
net not_aus_fault     => halui.estop.activate
setp oneshot.0.width 0.1
setp edge.0.in-edge FALSE
setp timedelay.0.on-delay 0.05
setp timedelay.0.off-delay 0
net not_aus_ok         => iocontrol.0.emc-enable-in
net not_aus_ok         => edge.0.in
net estop-ok-rising    <= edge.0.out => oneshot.0.in
net estop-reset-raw    <= oneshot.0.out => timedelay.0.in
net estop-reset-pulse  <= timedelay.0.out => halui.estop.reset
  • Aciera
  • Aciera's Avatar
28 Sep 2025 13:44
Category: HAL
'toggle2nist.comp' up to and including 2.9.x has issues:
github.com/LinuxCNC/linuxcnc/pull/3193
A new version is available in master:
github.com/LinuxCNC/linuxcnc/blob/0bc97e...nts/toggle2nist.comp
which you could install into your version by downloading the new version and using
(sudo) halcompile --install toggle2nist.comp
Note that 'halcompile' requires the 'linuxcnc-dev' package to be installed
Also note that people used to work around some of the problematic 'toggle2nist' behavior by adding hal components between the momentary switch and 'toggle2nist.in'. Looking at your .in pin signal in the halscope sreenshot makes me think that you might have done that. If you use the new version make sure to directly connect the momentary switch to the .in pin.
  • juergen-home
  • juergen-home
28 Sep 2025 11:01 - 28 Sep 2025 11:17
Category: HAL
I have this gamepad.hal as an example for my problem.
This is used with the button of a gamepad.I start a program by a button, then I can pause/resume it by another button.The third button is to stop the program.
The problem I have: If the program is started and I press pause/resume and stop at the same time, sometimes the toggle2nist_on get stucked in on state and the pause/resume will not work until I quit linuxcnc and start again. Is this a known behavior, or is something wrong in my gamepad.hal
# test for linuxcnc 2.9 2025-09-28 work
# generic china Gamepad
loadusr -W hal_input -KRAL USB Gamepad
# Program Stop
#halui.program.stop (bit, in) - pin for stopping a program
net button13  input.0.btn-base5 => halui.program.stop
# Program Start
net button16  input.0.btn-base4 => halui.program.run
# Program Pause on/ Pause off
# known bugs: if you stop  while in pause, than swich on and start program again, pause will not work.
# sometimes tog2nist_1.on stays on !
loadrt toggle names=tog_1
addf tog_1 servo-thread 1
loadrt toggle2nist names=tog2nist_1
addf tog2nist_1 servo-thread 2
net net-button-pause-trigger input.0.btn-base6 => tog_1.in  # this is the pause button
net net-button-pause tog2nist_1.in <= tog_1.out
net net-pause-is-on tog2nist_1.is-on <= halui.program.is-paused
net net-pause-off tog2nist_1.off => halui.program.resume
net net-pause-on tog2nist_1.on => halui.program.pause
  • Hakan
  • Hakan
28 Sep 2025 08:23 - 28 Sep 2025 09:54
Do you have the errors from syslog?
I would like to see the 60fe and 60fd sdos and pdos out specifically and only the 6 mentioned PDOs in there.
Here is a document on how to use the drive in TwinCAT.
shopcdnpro.grainajz.com/category/409767/...%8D%97-%E8%8B%B1.pdf
I guess it is worthwhile to check it works there.
  • rene-dev
  • rene-dev
27 Sep 2025 21:38
Linuxcnc meeting Stuttgart was created by rene-dev
Category: Deutsch
there will be a meeting in Stuttgart again.
nuudel.digitalcourage.de/dGtDlt4Tzw9tZ3Hn
  • GDTH
  • GDTH's Avatar
27 Sep 2025 18:34
Carousel with counts move x amount of pockets
i have copied the carousel component and removed the align_pin if statement from state 8. I think this is ment for dc motors. So far it seems to work fine.
  • kb58
  • kb58
27 Sep 2025 17:44 - 27 Sep 2025 17:52
FWIW, here are the files in question as of now, with the requested lines commented out or removed. I must still be missing something - or the manual leaves out critical information...
  • kb58
  • kb58
27 Sep 2025 17:38 - 27 Sep 2025 17:39
Understood. I tried the above - no change, status light still blinking, still in "PREOP".
Regarding a factory reset, I'm not sure how to apply it. See attached screenshot:
Displaying 9481 - 9495 out of 17020 results.
Time to create page: 0.379 seconds
