  • JT
  • JT's Avatar
29 Nov 2024 12:54
Flex GUI 1.1.0 Released was created by JT
Category: Other User Interfaces
I'm pleased to announce the release of Flex GUI 1.1.0 which can now be installed and updated using the Debian apt command.
JT
  • AD_15
  • AD_15
29 Nov 2024 12:52
Replied by AD_15 on topic Automatic Tool Changer
Hello!!
I have implemented linear ATC. But what limits I have to set so that when file is running machine will not travel the area where Tools are planted. Machine only allows when MDI command for tool change has been given. How to set different working limits? What changes in .ini required?
  • JT
  • JT's Avatar
29 Nov 2024 12:52
Replied by JT on topic Flex GUI Tutorials
Flex GUI Tutorials
Tutorial 24
JT
  • cncmiljc
  • cncmiljc
29 Nov 2024 12:25
Let me be clear, I am referring to the .cpp that was extracted from the STM32F103RCT6.
  • cncmiljc
  • cncmiljc
29 Nov 2024 12:22
Could you leave a copy of the nvmpg cpp on your github? I'm thinking about creating my own mpg but only with buttons and I would like to study the programming that was used in it to be the starting point.
  • machinedude
  • machinedude's Avatar
29 Nov 2024 11:57
Replied by machinedude on topic Black Friday Deal got me :)
Category: Plasma & Laser
i just went out and checked the hand torch that came with the machine and the electrode is spring loaded just like the new straight torch. so i think it is a blow back set up. they don't sell this one anymore and the new ones i think are all HF units. the new ones are not set up with the cnc options built in the units and are much cheaper than this unit. i seen a big price difference. i paid something like $550 for my unit.
  • uvos
  • uvos
29 Nov 2024 11:44 - 29 Nov 2024 11:47
Asrock Q1900M: Unexpected Realtime Delay, but Good Latency Values
Well i figured this out, pretty strange but it turns out that there is a watchdog messege on dmseg that occures exactly every 1 minute and i had dmesg ouput on the serial port. Well apearantly this superio chip stalls when the serial port is used as anytime anything is written to that serial port there is a latency spike. Simply removeing the serial port console= line from the kernels cmdline fixed the issue.
So it would seam that on this machine writeing to the serial port blocks the parallel port for a bit, thats not too bad i can just use netconsole to monitor the system
  • yaska
  • yaska
29 Nov 2024 11:39
Replied by yaska on topic Probe basic tool table setup
Have read lathe user html. Pb has Standard mode and Master tool mode. I have manual tool change and want help with which mode to use and in what order and which touch buttons to use.  With the buttons SET MT X and SET MT Z my master tool (#1) sets the coordinates X and Z in the tool table to X0 and Z0, which is ok. How do I then get the length difference between tool #1 and tool 2 and tool n
-Yaska
29 Nov 2024 11:38
Replied by tommylight on topic Black Friday Deal got me :)
Chances are this has a HF/HV start, not blow back.
But they are manageable for sure.
29 Nov 2024 11:36
linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
In Visual Code/PlatformIO in the upper right corner click on serial monitor, on the bootom part type help, that will show all the available commands, set the wifi mode, SSID and password, connect to that wifi.
  • machinedude
29 Nov 2024 11:31
i thought the air was what worked the torch with a blow back start? i really don't know too much about how the magic works. i just knew high frequency starts are bad from what i learned before. i thought the air flow pushed the contact point so the torch fires with a blow back start torch?
  • NickH
  • NickH
29 Nov 2024 11:03
Replied by NickH on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Ralph, you are a star, thank you. I'll try these a little later.
  • Thayloreing
  • Thayloreing
29 Nov 2024 10:57
Could you give me a step by step? I don't really understand what I should do
  • rodw
  • rodw's Avatar
29 Nov 2024 10:56
Replied by rodw on topic Cant change from develop to stable
Category: QtPyVCP
the dkms drivers require linux-headers for your kernel version. I don't think its installed.
The dkms system compiles the driver for kernels if they are changed or upgraded and the headers are required
  • rodw
  • rodw's Avatar
29 Nov 2024 10:47
Ethercat installation from repositories - how to step by step
Category: EtherCAT
Hello,
is the any way to change the network card driver from default generic to my hardware native e1000e when I install ethercat stuff from responsitories please?
thanks regards
I think only the generic driver is supported in the deb install. If you build Ethercat master from sources I think you can build the Intel driver which will give better performance. Check the docs which outlines the build process. Its pretty easy.
etherlab.org/en_GB/ethercat
Displaying 17191 - 17205 out of 24030 results.
Time to create page: 1.440 seconds
