10 Nov 2024 21:37
Mesa, Linuxcnc with step direction servo's for axis and analog servo spindle.
Category: Basic Configuration
No worries, we do need correct info to be able to give any help, 7i76 and 7i76E are the same thing but NOT the exact same thing.
Mesa can do step/dir and analog at the same time and so can LinuxCNC, so that is easy, just use mesaflash to check what firmware is already in the 7i76E, then we can decide if a flash is needed.
see in a terminal
man mesaflash
for how to use it.
  • mjones@welfab.ca
  • mjones@welfab.ca
10 Nov 2024 21:06
7i76E is connected to the computer through ethernet, the 7i77 connects to the 7i76e with a ribbon cable and the 7i64 connects to the 7i77 with a modified ethernet cable.
The boards have 5v and 24v field power.
It has been a while since I wired and had time to do the cards but I remember that I did flash one for some reason or another. Does it need different flashing for step direction than for analog?
And sorry again, as I said it has been a while since I had time to get into this again and don't remember where to type readhmid
  • Rkatts
  • Rkatts
10 Nov 2024 20:58
Replied by Rkatts on topic Installing ethercat repositories
Category: EtherCAT
I was able to edit the file by using:
sudo nano science_EtherLab.list
Then it all worked.  Thanks for the notes.
10 Nov 2024 20:49
After switching from wheezy to Debian 12 only X axis runs smooth (sometimes)
No need to install anything, you can do all the testing in Live mode, just have the configs on another USB, or start them from the existing hard drives.
I/O errors are usually from failing hard drives, sometimes from failing memory or memory controller, but over network might be bad connection usually manisefested by very long waits for read/write.
  • denhen89
  • denhen89's Avatar
10 Nov 2024 20:39
Thanks Tommy for your quick reply.
I did not change the servo period, only the Base Period, but i did that after i got some error message at linuxcnc startup (latency... 25000..task 0..) - i did not change anything besides the parport addresses for the other pc i setup first with debian 12.
I will now look for Wheezy ISO and install it on the PC where i first installed Debian 12, but i will connect it to the cnc router on tomorrow and then i will post the result.
PS: On the original PC from the cnc router (that had the ondrive input output error and that was so slow), i had Wheezy and Linux 2.8.4-76 and i copied those original files to the new Debian 12 pc, without converting the files with the auto-converting pop up function, because as i remember correctly, this is not necessary if my config was working with Linux 2.8? (i remember i had to do it when i updated from 2.7 i believe - i had to change some command etc.)
10 Nov 2024 20:22
It would be much better to give us correct info about your setup, like what is attached to 7i76 and 7i77?
Or is it a 7i76E with 7i77?
Did you flash the correct firmware for whatever is in use?
What does readhmid return?
Do the boards have 5V and Field (12-24V) power?
  • Ismacr63
  • Ismacr63
10 Nov 2024 20:19
Replied by Ismacr63 on topic Use z probe and 3d probe in the same input?
Category: QtPyVCP
I've been testing these days and finally I have both probes working via OR2 (I don't know if it's the best option), each one in a different input, I can have both connected at the same time without problems. I've decided to do without the estop input and connect the z probe there. The spindle of the machine works through its original board and has its emergency stop and I use the linuxcnc emergency stop with a mini wireless keyboard if necessary...
I want to buy a 7i96s board soon, but I'm a bit scared of all the configuration it has...
10 Nov 2024 20:17
Replied by tommylight on topic New basic setup recommendations
1. No.
2. Yes bit to complicated, and do not buy those ebay stuff at over 80$ as that is Mesa price and Mesa is much, much better.
3. 2.9.3 but i would stick with Wheezy and 2.7 for parallel port.
4. Yes, rarely might need editing. Granted no special comps/features were in use.
10 Nov 2024 20:11
Do not change the servo period. Ever. Except in some strange cases, never.
Download the Wheezy ISO, boot the PC from it, copy the existing (non converted to 2.8 or 2.9) config, open the folder, right click on the .ini file, select "open with other ..." on the next window near the bottom type linuxcnc and press OK.
Does everything work?
10 Nov 2024 20:02
Replied by tommylight on topic General Questions about using ethercat
Category: EtherCAT
LinuxCNC IS the motion controller, so EtherCAT should work without any additional controllers.
10 Nov 2024 19:58
How to configure pause/resume over pin 10 of parallel port?
Category: HAL
It all should be possible to configure using the included wizards, did you try them?
Use StepConf for parallel port or PncConf for Mesa boards.
Also, pin 17 is output, so what input are you reffering to?
  • mjones@welfab.ca
  • mjones@welfab.ca
10 Nov 2024 19:54
Hi Guys, I am having trouble getting my lathe to work.
It is an Old Superslant Hardinge.  It has 4 axis, 2 turrets each with an x and z and each with 8 tool changer.
The problem I have is that I have a working hal that connects to the boards, and all the io's are working.  But the drives both axis and spindle don't do anything.  The axis I know the problem is that im wired for step and direction and the configurator doesn't give a setup for that, and using the step configurator and blending the file is giving me a major headache.as its difficult to see what parts of one I need and what parts I can't have.
I am running 7i76-7i77 and 7i64.
Any suggestions as to how I can make or blend a hal file that will do what I want would be appreciated.
File Name: superslant...1-10.hal
File Size:32 KB
File Name: superslant...1-10.ini
File Size:5 KB
File Size:32 KB
File Size:5 KB
  • langdons
  • langdons
10 Nov 2024 19:38
Replied by langdons on topic New basic setup recommendations
Perhaps the old PSU is broken.
  • langdons
  • langdons
10 Nov 2024 19:37
If you get a new computer working with a parallel port, the old HAL config should be fine.
However, you will probably need to update the port address.
You can find the port address with lspci -v
Ethernet adapters almost certainly add a little latency.
Did you try a different monitor?
Does the old computer make a startup beep?
Displaying 18346 - 18360 out of 24129 results.
Time to create page: 0.442 seconds
