24 Oct 2024 19:08
Replied by tommylight on topic Spindle servo step/dir Problems
How does a wrong scale invert the direction for m3/m4?
It does not, uless a - sign is in front of it.
So, add a - to scale
Or
Invert the direction pin in hal.
24 Oct 2024 19:06
Replied by tommylight on topic Fanuc Servos Single Phase
Are the drives rated for 200V AC?
It may be possible to run from a single phase, but it is not advisable and should never be run at max power due to risk of blowing the rectifier. Rarely happens, though.
You have a bigger hill to climb, your country has 240V AC grid with +-10% tolerance, meaning it can go to 264V, rectified inside the drive that will be over 300V DC (on the phone, what is 264X1.41? ) and can easily blow the capacitors.
In short, i would not risk it.
A big 240 to 200V tranformer would be safe, but still single phase.
  • bkt
  • bkt's Avatar
24 Oct 2024 18:59
Replied by bkt on topic linuxcnc trajectory planner
he Grotius ... sorry for stupid question ... not read all post of these thread .... but is possible to install these project or only rip-install? can damage somethings if try on little scara your code? custom kins is the same as 2.10?
24 Oct 2024 18:58
Unexpected realtime delay on task 0 with period 1000000
Category: QtPyVCP
Latency related issue, so did you dissble all the power saving features in the BIOS?
Also disable hyperthrrading, TPM, turbo, etc.
  • bkt
  • bkt's Avatar
24 Oct 2024 18:55
Replied by bkt on topic c++ compiling error
c++ compiling error
 Same here, been over 3 years since i went for a ride on any of the bikes! :(
really when not rayn ..... so almost from 2 month not for sure .... go at workshop with my electric bycycle  ......    ..... quite a byke!!! .... I see every morning my motorbike on the garage .... and I dreams a lon trip .....
  • Lcvette
  • Lcvette's Avatar
24 Oct 2024 18:51
Replied by Lcvette on topic Probe Basic Buttons Missing
Category: QtPyVCP
run from line was moved above to the mdi line, if you are upgrading from an older version you need to make sure the new sunroutine folder is used and also add the new probe basic variables to the .var file in your config. the updates are up in the new docs here:
kcjengr.github.io/probe_basic/machine_config.html
parameters required in the var are shown here:
kcjengr.github.io/probe_basic/probe_basic_parameters.html
  • PCW
  • PCW's Avatar
24 Oct 2024 18:50
Category: QtPyVCP
@PCW who would be the person group best suited to fixing it, and do they know about it? is this a linuxcnc thing or a debian thing?
Honestly its a Linux thing (broken driver) but would be easier to fix in a non debian compliant ISO
Ultimately it should get fixed in the kernel driver so the proprietary Realtek driver is not needed.
  • bkt
  • bkt's Avatar
24 Oct 2024 18:50
c++ compiling error
Hi Bkt,
Could be missing a header include path.
But can also have other reason's. Some times hard to say what the cause is.
really is because if use mdi command or other trajectory command using rip-install path for rs274 is  not a good idea if you have Lcnc istalled too.... tomorrow or day after i publish here the right cmakelist.txt with opcua too .... now all work and robot moove perfectly.
Thanks again.
  • PCW
  • PCW's Avatar
24 Oct 2024 18:44
Category: QtPyVCP
2.531 is still way too large (even though its ~4x better)
Are all power saving option disabled in the BIOS? (Turbo modes,C state > C1 etc)
Other options are shown in the:
forum.linuxcnc.org/38-general-linuxcnc-q...nity?start=40#300434
thread
A simple thing to try is to run this script that sets the irq affinity
File Name: pinirq_2024-10-24.txt
File Size:1 KB
you first need to make the script executable with
chmod +x pinirq.txt
and then run it with:
sudo ./pinirq.txt  [ethernet_device_name]
Where [Ethernet_device_name] is something like eno1 or enp0s5
(the device name can be determined with the "ip a" command)
You can check that it worked with this script:
File Name: checkmask_...0-24.txt
File Size:1 KB
chmod +x checkmask.txt
./checkmask.txt  [ethernet_device_name]
checkmask also shows the kernel command line
  • scotth
  • scotth
24 Oct 2024 18:42
Category: QtPyVCP
Go to your Synaptic Package Manager.
Search (in my case) R8168-dkms
select and install package.
Reboot
There are several devices and other drivers for them. Search DKMS in package and look for the proper device.
  • tsaG
  • tsaG
24 Oct 2024 18:30 - 24 Oct 2024 18:40
Replied by tsaG on topic Probe Basic Buttons Missing
Category: QtPyVCP
That was the issue! Thanks
However, I now have the button "reload PGM" and "clear PGM" instead of "run from line". Is there a way to add it back in?
Another point. I tried to use the touch off on my tool probe (which worked before) but I get three errors:
1: invalid params in linear command
2: Linear move on line 50 would exceed joint 0's positive limit
3: Linear move on line 50 would exceed X's positive limit
  • Stran_ge
  • Stran_ge
24 Oct 2024 18:26
Replied by Stran_ge on topic Spindle servo step/dir Problems
Hello PCW,
thank you for the fast answer.
I checked the parameter of the servo with the manufacturer and he told me that the motor resolution per revolution is 1024 which is then *4 4096.
4096/60 = 68.26667 = pulse per second.
  • freemoore
  • freemoore
24 Oct 2024 18:24
Replied by freemoore on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
Ah great! I'll have a look.
  • Grotius
  • Grotius's Avatar
24 Oct 2024 18:20
Replied by Grotius on topic linuxcnc trajectory planner
Thanks TiaUnderGround for testing the script.
Glad that is run's.
I hope Arciera's install will also run now.
In the cmake dir, i changed the tinyspline source code to be libtinyspline.
It now compiles to libtinyspline.so and is installed in ~/rtlib
motmod.so uses libtinyspline to create fillets. This is temponairy.
Next will create libfilletizer wich then can be used by the trajectory planner "tpmod.so".
Then the edited motion component "motmod.so" wich we used for displaying the filletizer algoritme can be
left in the project as is. This edited component can be used to verify filletizer outputs when source code
has changed.
We can load the original "motmod.so" once again and can now focus
on the trajectory planner "tpmod.so" code.
We have soon the ingredients complete.
  • PCW
  • PCW's Avatar
24 Oct 2024 18:19
Replied by PCW on topic Spindle servo step/dir Problems
Sounds like either the encoder scale or the step/dir scale (or both) are wrong.
Displaying 19306 - 19320 out of 24145 results.
Time to create page: 1.565 seconds
