  • Aciera
  • Aciera's Avatar
16 Oct 2024 12:16
Unterstützung bei der Automatisierung einer Simulation
Category: Deutsch
Funktioniert bei mir. Zur Fehlersuche kannst du deine Konfiguration im terminal starten und nach den Start nach Errormeldungen suchen.
linuxcnc -l
Alternativ kann der Logger auch mittels einem custom Mcode aus dem MDI fenster oder über einen Gui button gestartet werden.
siehe:
forum.linuxcnc.org/21-axis/30986-axis-po...gger?start=60#294514
  • Lcvette
  • Lcvette's Avatar
16 Oct 2024 12:11
  • rodw
  • rodw's Avatar
16 Oct 2024 12:05
Replied by rodw on topic 7i76E any updates?
7i76E any updates?
Category: Driver Boards
They're here. They're here. the 7i76EU is now available. Thank you PCW, JT and MESA for making these boards available once again.
Now I just have to scrounge up some money to buy one. LOL. Hurricane prep wasn't cheap. Thanks Helene and Milton.
Great to know you survived. In the end, as far as hurricanes go, Milton's Category 3 was a bit of a Fizzer. Shame about the storm surges and flooding though!
  • Muecke
  • Muecke's Avatar
16 Oct 2024 11:56
Category: Deutsch
Auch so wird es nicht mit gestartet :-(
ist nicht weiter tragisch, da ich mir eine extra Datei gemacht habe, um das Tool zu starten.
  • mehdidadash
  • mehdidadash's Avatar
16 Oct 2024 11:45
Replied by mehdidadash on topic asd-a2 e delta homing
Category: EtherCAT
when i click on home these joints, their cia402.1.stat-homing becomes high and remains high
joint.1.homing becomes high and then low and joint.1.homed becomes high
  • mehdidadash
16 Oct 2024 11:41
Category: EtherCAT
i had to add that all their sdo's and register are like my other drives. xml of them are just a copy&paste of other axeses.
drives manufactoring date are different.
  • mehdidadash
16 Oct 2024 11:39
asd-a2 e delta homing was created by mehdidadash
Category: EtherCAT
hi guys
i have a machine with 5 asd-a2-E servos for over a year
two of my servos(Z &W axis) had problem in homing since begining. each time that a started machine and clicked on home all, all servos start homing as the order in ini file but this two drives shows as it is homed but they does not start homing. i had to click on home joint 1 and joint 4 several times in order for them to do homing . sometimes i had to do it ten times and some time just once .
today , this drives did not do homing even after 100 times of clicking on home.
i reseted their parameters but it did not solve the problem.
do you guys know how to fix this problem ?
  • my1987toyota
  • my1987toyota's Avatar
16 Oct 2024 11:33
Replied by my1987toyota on topic 7i76E any updates?
7i76E any updates?
  • my1987toyota
16 Oct 2024 11:21
Replied by my1987toyota on topic Flex GUI version 1.0.0
Category: Other User Interfaces
Now that I don't have a hurricane to prep for I will give these a look.
  • timo
  • timo
16 Oct 2024 11:17
Replied by timo on topic No of I/O pins available on Pi 5
The Pi seems to have become cheaper after beeing unrealistic expensive. Small mini PCs with N100 CPU cost in the same ballpark. Is there any downside to them?
(assuming they work at all)
7i95 connected to IntelNuc was not working at all. I could not get the thing to install the Linux.
Then there was a new release (I think it was 2.9.1) with this updated ISOimage all went smooth. (O.K. O.K: Yes, No, skip... done!)
Real Endconsumer Style Install.
I bought some uptech Parallel adapters a while ago. They worked sort of.
Trying to get a "high" ppr (100 ppr) Encoder to work was not going to happen and frustration. (with 6i25 it was self-solving)
  • Aciera
  • Aciera's Avatar
16 Oct 2024 11:11 - 16 Oct 2024 11:35
Category: Deutsch
1. 'python3' gehört VOR den Pfad
2. dein absoluter Pfad zum 'lcnc_logger.py' script ist:
'/home/cnc/linuxcnc/configs/demo2023/linuxcnc_logger/lcnc_logger.py'
[APPLICATIONS]
APP = python3 /home/cnc/linuxcnc/configs/demo2023/linuxcnc_logger/lcnc_logger.py
  • JT
  • JT's Avatar
16 Oct 2024 10:25
Customization of the icon for the LinuxCNC website
Category: Forum Questions
The forum has 2GB of memory and 80GB of disk space. The backup was 14GB and shot our disk usage up to 95% so it has to be deleted.
Just to be clear I am one of the three owners at Digital Ocean for the linuxcnc.org group which hosts the forum. The owner of the linuxcnc.org is someone else.
JT
  • nartburg
  • nartburg
16 Oct 2024 09:38
Replied by nartburg on topic Mesa 7i96s --USB error finishing read
Got the optical isolated rs485 adapter.
Works!
But it was quite a pain.
  • BaxEDM
  • BaxEDM's Avatar
16 Oct 2024 09:28 - 16 Oct 2024 09:37
Performance issues after switching from LCNC 2.8.4 Buster to 2.9.3 Bookworm
Category: EtherCAT
Just switched from LCNC 2.8.4 Buster to 2.9.3 Bookworm and am running into what seems to be a performance issue. Occasionally I get a random servo following error, which is impossible since I run my steppers open loop. I use EtherCAT stepper drives. These errors stop G-code execution at random moments and turn the machine off, making it unusable.
I remember when I first tried out LCNC on a really old laptop I got this as well, I then switched to a dedicated mini PC and never saw those errors again, until now. Now I'm running the same stuff on the same PC, but instead with LCNC 2.9.3 and Bookworm, the occasional servo errors have returned.
The mini-PC is a 8GB memory, 4-core Intel celeron 2-2.7GHz (The Minisforum GK41).
My initial thought was to replace the PC with something faster, but that might not be the right approach since the hardware is probably already fast enough. It works like a charm on 2.8.4 + Buster. Could it be that Bookworm is so much more demanding? I would like to hear what the experts on the forum recommend.
  • Muecke
  • Muecke's Avatar
16 Oct 2024 09:20
Category: Deutsch
Hmm, das mit dem Pfad mache ich wahrscheinlich falsch :-(
Displaying 20041 - 20055 out of 24222 results.
Time to create page: 0.887 seconds
