  • rajsekhar
  • rajsekhar
27 Sep 2024 04:58
Replied by rajsekhar on topic Error while Running Linuxcnc
Category: Driver Boards
One interesting point I noticed, if, after booting LCNC, I run pinirq script first time and 2nd time, results are different and as follows:
raycnc1@debian:~/Downloads$ sudo ./pinirq_2024-09-26.txt enp4s0
[sudo] password for raycnc1:
Cores: 2
Old CPU Mask: 3
Set device enp4s0 IRQ 32 CPU mask to 2
Cores: 2
Old CPU Mask: 2
the "Old CPU Mask:" is different.
if I run LCNC after pinirq script is run once, interrupts goes to CPU1 as desired.
So what should I do? How to run this script on start-up?
  • cmorley
  • cmorley
27 Sep 2024 04:57
Replied by cmorley on topic pause spindle using USB pendant
Category: Qtvcp
Try this new pause_pin.py file
  • andreabonuc
  • andreabonuc
27 Sep 2024 03:54
Replied by andreabonuc on topic Constant loss of position
exactly which items do you intend to set?
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAAngNWGAAABDUlEQVR4AYXRgUZDYRjH4TegFTKgpEqiFJgoWAoMEQGBgBboChaaAKxLKAhAhQqAdAmpBIQolkCFqp2nITvNKXuA7+/Hhzey5OWjE4Nq3rzY1f9/NGHPB549492+8Ww060iCS2XdctZdI3GsECmb+HJoIX6x6EgDm+lURTH+YB7V9nAqE5WNme4YKuOiY6iMe6PaQxUUIuTbswgFVNJwA8sO3Bn6yR6bWZMSNtJwDtuWfHpQxaPx9C9zadil7jrCigbq6UXceNIVKTWUIqypm2ytJdTiNyNeXclF6GttOVfeDEc7qzjR23r3OMFqZKng1kw0mXGLrfibHTScOZWgGv9TdC6ROFeMTgwYiIxvJzMRWQbeGZUAAAAASUVORK5CYII=[/img]
  • rajsekhar
  • rajsekhar
27 Sep 2024 03:46
Both scripts runs and results as follows:
Cores: 2
Old CPU Mask: 2
raycnc1@debian:~/Downloads$ sudo ./checkmask_2024-09-26.txt enp4s0
Cores: 2
Actual CPU Mask: 2
Desired CPU Mask: 2
IRQ: 32
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-18-rt-amd64 root=UUID=bc617657-6a6c-4afa-9a67-ef553e3b2439 ro initrd=/install/gtk/initrd.gz quiet isolcpus=1
I did not understand the result though. Is it ok?
  • PCW
  • PCW's Avatar
27 Sep 2024 02:34
Replied by PCW on topic Error while Running Linuxcnc
As a test, you can try running this utility to pin the IRQ
File Name: pinirq_2024-09-26.txt
File Size:1 KB
First download  then
chmod +x pinirq.txt
 then
sudo ./pinirq.txt enp4s0
This utility can check the mask:
File Name: checkmask_...9-26.txt
File Size:1 KB
  • PCW
  • PCW's Avatar
27 Sep 2024 02:30
Replied by PCW on topic 8 Spindle Gang Router
Category: Show Your Stuff
So sorry about that Todd.
27 Sep 2024 01:22
Replied by tommylight on topic 8 Spindle Gang Router
At the risk of getting banned:
FUCK!
Sorry Todd.
  • rajsekhar
  • rajsekhar
27 Sep 2024 01:17
But with isolcpu=1, I understand that servothread runs in CPU1 and by irq balance setting, we are aiming the ethernet interrupts in CPU1, not in CPU0.
Am I correct?
  • PCW
  • PCW's Avatar
27 Sep 2024 00:12
Yes, looks like only CPU 0 get interrupts from enp4s0.
  • rajsekhar
  • rajsekhar
26 Sep 2024 23:34
Ok, understood.
But please confirm whether Interrupt in CPU0 is correct or not.
  • spumco
  • spumco
26 Sep 2024 23:32
Replied by spumco on topic Probe cancellation does not move the axes.
Category: QtPyVCP
That would be a great addition to Probe Basic.
I'm not sure it can be done - but I'm no expert.
My initial thought is that the on_abort subroutine is run while LCNC is in auto mode... so there's no way for a program to switch to manual (or MDI) mode.
I'll dig around a little and open a new thread - the issue (or solution) may not be specific to PB.
  • spumco
  • spumco
26 Sep 2024 23:28
Category: QtPyVCP
I don't know why those modes aren't shown in my version. I just downloaded it, followed the installation instructions and it looked like this.
How can I add them?
Sounds like something got messed up in your PB installation.
What Linux distribution are you using, and what version of LCNC?  This might have a bearing - I've had problems in the past with certain combinations/versions of Debian/LCNC/qtpyvcp/PB.  Seems like frequently some dependency or other invisible 'backstage' issue led to weird problems with PB.
I know it'll be a bit painful, but my suggestion is to make a copy of your config and then uninstall and reinstall PB using the instructions here:
forum.linuxcnc.org/qtpyvcp/53871-probe-b...on-start-here#310377
  • PCW
  • PCW's Avatar
26 Sep 2024 23:18
Yes, your Ethernet interface is named enp4s0
Look like ethtool is not included in your linuxcnc distribution
Note that if you have Realtek hardware you will need to load the DKMS driver
(and ethtool in not needed, ethtool is only needed for Intel Ethernet hardware)
  • PCW
  • PCW's Avatar
26 Sep 2024 21:42
Replied by PCW on topic Constant loss of position
So the existing setup/hold times are marginal
I would set them both to 20000 (20 usec) as I
mentioned before.
  • andreabonuc
  • andreabonuc
26 Sep 2024 21:14
This is what indicate the manual for the servomotors jmc
Displaying 20896 - 20910 out of 24484 results.
Time to create page: 0.443 seconds
