31 Aug 2024 16:02
Replied by tommylight on topic help to connect alarm signal driver hbs86h
Category: Driver Boards
No need, it should work as is.
Do you have enable wired to your drives?
  • Moutomation
  • Moutomation
31 Aug 2024 15:52
Raspberry pi 5 password was created by Moutomation
I use Raspery on Pi5, there are no problems, it starts automatically without a password when the first power comes on. While the CNC is running and processing materials, a password login screen appears occasionally, but the CNC does not stop and continues to work. What causes this encrypted login screen to appear?
  • Aciera
  • Aciera's Avatar
31 Aug 2024 15:51
Replied by Aciera on topic Sliders for overrides in gmoccapy
You could try using the 'hal_input' component and see what keys your keyboard offers. These can then be connected in hal to the .increse/.decrease pins of gmoccapy.
linuxcnc.org/docs/html/gui/gmoccapy.html#_hal_pins
example:
1. open a terminal and type:
lsusb
2. find your keyboard in the output
example: 'Bus 003 Device 002: ID 17ef:608c Lenovo Lenovo Calliope USB Keyboard'
3. Add this to the [HAL] section of your ini file using one of the words from the keyboard identification from above to identify the device (for our example we use 'Keyboard')
HALCMD = loadusr -W hal_input -K +Keyboard:0
4. Start your config, enter the settings page and click on the 'Halshow' button in the lower right corner
5. Navigate to pins/input/0/ and check if any function keys have been recognized:
6. In our example there are some function keys we can use (eg 'input.0.key-volumeup', 'input.0.key-volumedown')
7. Connect these pins to the relevant gmoccapy halpins in the POSTGUI_HALFILE (eg to control the linear jog velocity):
net jog_speed_plus <= input.0.key-volumeup => gmoccapy.spc_lin_jog_vel.increase
net jog_speed_minus <= input.0.key-volumedown => gmoccapy.spc_lin_jog_vel.decrease
possible pins can also be found in pins/gmoccpy.
linuxcnc.org/docs/html/man/man1/hal_input.1.html
  • Ismacr63
  • Ismacr63
31 Aug 2024 15:50
Replied by Ismacr63 on topic help to connect alarm signal driver hbs86h
Connect to input on BOB, then in hal connect that input to joint.N.amp-fault.
Or in your case if you have them with e-stop, in hal connect to estop-ext.
Apart from the cable connection, do I have to modify anything in my HAL file so that the alarm works with the emergency stop?
  • Ismacr63
  • Ismacr63
31 Aug 2024 15:16
The problem I have is that I don't know how to connect the cables from the driver to the bob. I also don't know if alarm+ needs voltage.....
  • aDm1N
  • aDm1N's Avatar
31 Aug 2024 15:09
Somewhere here I read something about the pins for encoders, but I can't find it again. I think there was talk of only one possible encoder. Either for the spindle signal, or MPG, which would be a shame if you have to decide on one. I saw the pinmapping in this post.
forum.linuxcnc.org/18-computer/44828-rem...rd?start=1750#303975
  • arijitdutta
  • arijitdutta
31 Aug 2024 15:07
Replied by arijitdutta on topic Sliders for overrides in gmoccapy
Yes, axis supports 1-0 for feed overrides. Sadly it doesn't work on gmoccapy. I can see in some videos over youtube that there used to be sliders at sometime. As a beginner in CNC the sliders and shortcuts are very very useful for me
  • OT-CNC
  • OT-CNC
31 Aug 2024 15:05
Replied by OT-CNC on topic I don't think it's a hardware problem
I'm glad that was an easy fix.
31 Aug 2024 14:40
Replied by tommylight on topic Sliders for overrides in gmoccapy
In Axis, number keys from ` to 0 (yes the first is the tidle key under ESC and to the left of 1) are feed overrides so you can press them at any time to set the feed speed, meaning the ` is 0 feed rate so the machine will not move, 1 is 10%, 2 is 20% and so on.
No idea if that works for GmoccaPy.
  • arijitdutta
  • arijitdutta
31 Aug 2024 14:27
Sliders for overrides in gmoccapy was created by arijitdutta
I am using Axis for my lathe currently. I was recently looking at the gmoccapy GUI in sim mode, everything is much better here. But one thing is keeping me off from using it is the sliders for the Rapid/feed/spindle/jog override. In axis, one can just move the sliders from 0 to 100 in half a second, but you have to press the '+' or '-" to adjust them. Are there any shortcuts for this or any way to get adjustable sliders in gmoccapy like axisui? Thanks in advance.
  • PCW
  • PCW's Avatar
31 Aug 2024 14:19
Replied by PCW on topic Problems Spindle Synchronisation
Category: Basic Configuration
One way to check the index/encoder  is to:
1. Disable the drive so the spindle can be turned by hand
2. Verify that the spindle position from the encoder increases by 1.00 for each forward turn.
3. With halcmd (in a terminal) set the index enable:
halcmd sets spindle-index-enable true
now, when you rotate the spindle. at the index position:
the spindle position should be reset to 0
spindle-index-enable should go false
You can watch the spindle position (spindle.0.revs) and spindle-index-enable
with halshows watch tab
  • PCW
  • PCW's Avatar
31 Aug 2024 13:57
Spindle Step/Dir and as C axis one the same Servo
position feedback must be unconnected in spindle mode
  • fest
  • fest
31 Aug 2024 13:42
i knew you were working on something modular but you exceeded all my expectations, respect !
WOW !!!!!
Thanks! It really did turn out to be more complicated than I first imagined (the more I thought about using the colorlight modules the less I liked the idea, so in the end I just decided to go for FPGA onboard).
I'm also not fully certain if the non-opto-isolated encoder and stepdir modules will be a good idea- at least the motor drives I'm using all have opto-isolated stepdir inputs, and the PC side is isolated via Ethernet- so should be good enough for my uses.
Time will also tell if 12 bits per module is enough or too limiting. Probably the only use case I can see is something that needs a lot of IOs wired directly- the shift-register based module should be enough for general purpose CNC use (buttons, endstops, relays etc).
  • fest
  • fest
31 Aug 2024 13:35
Looks good. Lots of hard work. Lots of thought gone into it.
Generally when I've been designing my boards I've followed the mesa example where all the signals from the FPGA that will be controller something go through a FET bus switch with a pullup resistor to 5v on the "world side"(I'm a cruddy old guy lol, I like 5v). Gives you bi directional voltage translation, and works fine even with the 2.5MHz SmartSerial signals (when I use mesa firmware tho my design also can run rio with no issues). To drive outputs I add a buffer or just connect directly to a simple Parallel Port breakout board.
Have you thought about screw terminals for the outputs ?
With regards to the differential outputs for the stepper drivers, it would take some serious noise to have any affect when driving an opto. I've used plain old 74 series 540/541 powered by 5 volts with no issues for years, plenty of drive there. And generally the cable length isn't all that great from between the step\dir source & destination.
Tommy linked a video to a guy that experiments with noise & shielded cables, very interesting.
For 5v to 3.3v translation 74lvc is a good candidate.
Thanks for the suggestions. The digital input module has spring-type wiring terminals (though now when I looked at it, my choice of two row 3.5mm pitch may have gone a bit too tiny). Regarding the stepdir/encoder- I really don't like how messy does the differential signal wiring becomes, so I'll be trying out the off-the-shelf cables + specific breakout boards (for encoder, for particular servo drives). Of course, there is also the generic RJ45->wiring terminal breakout for those unforseen circumstances.
  • meister
  • meister
31 Aug 2024 12:24
Hi Russell,
good idea, thank you very much,
I would prefer riocore
it is no longer worth doing new things with the old version
Cheers.
Olli
Displaying 22126 - 22140 out of 24893 results.
Time to create page: 0.419 seconds
