  • rodw
  • rodw's Avatar
21 Aug 2024 23:42
is there some basic list to build the net ?
Category: EtherCAT
I would be very happy if someone could point me to a list of standard net to build stuff from ...
like : net x-home or net x-limit or net torch-on .... stuff like this
OR I don't have to care and i can just create whatever i want?
I want to use most of the IO on my card that has 16 inputs and 16 outputs ...
before i had a usb-bob for mach3 and had 4 inputs and 4 outputs
I think that is the biggest difference between Linuxcnc and Mach3,  Here, you start with a blank canvas, Mach has some structure about its setup.
Linuxcnc does not care and you can use whatever you want.
Over time you will build your own style that works for you.
With ethercat, I like to put the drives at the top of the list so they get numbered the same as th ejoints but you can set a name j0.j1 etc.
  • PCW
  • PCW's Avatar
21 Aug 2024 23:36 - 21 Aug 2024 23:38
Replied by PCW on topic PID Servo Loop rates
The required PID rate also depends on what you are controlling.
 If you are controlling torque, you need a higher PID rate
than if you are controlling velocity (with the drive controlling the
lower level, higher frequency loops)
A typical position mode servo drive may have 3 nested PID (or similar)
loops, from fastest to slowest:
torque command to PWM out
velocity command to torque out
position command to velocity out
21 Aug 2024 23:19
Replied by Cant do this anymore bye all on topic is there some basic list to build the net ?
Category: EtherCAT
"did read almost half of the linuxcnc documentation"
That's the issue.
It's there you just need to look.
  • PCW
  • PCW's Avatar
21 Aug 2024 22:35
Replied by PCW on topic Digital input to float
Category: HAL
conv_bit_float will just turn a bit to 0.0 or 1.0
Normally  the way jog increments are selected are with a mux
component, say mux4
man mux4
  • Hauligali22
  • Hauligali22
21 Aug 2024 22:00
Replied by Hauligali22 on topic Closed Loop Computer Vision Enabled CNC
Category: QtPyVCP
Thank you. Without your incredible help, I would still be searching for how to implement this project. My current CNC machine is a 5axismaker with Mach4 software and Pokeys57U hardware. After reaching out to the vendor, they confirmed it can be converted to run LinuxCNC and suggested I follow this post: forum.linuxcnc.org/24-hal-components/29816-pokeys-ethernet. My first step will be converting the machine to LinuxCNC as well as figuring out LinuxCNC. Then, I'll create a custom HAL to apply external offsets to the original g-code using data from the camera using OpenCV. I feel like I've done adequate research beforehand but the actual implementation is where I will see how difficult this gets. While I'm not as experienced with CNC control, I'm more comfortable with programming but we will see. Hopefully, I can show the completed project as soon as possible  !
  • slowpoke
  • slowpoke
21 Aug 2024 21:41 - 21 Aug 2024 21:42
Digital input to float was created by slowpoke
Category: HAL
I have external push buttons for jog increment and I'm trying for example to update halui.axis.x.increment with the value 0.001
conv_bit_float seems like it should work for this?
It's not obvious how I get the float value of 0.001, assigned to the float value?
Error is postgui.hal:202: Pin '0.001' does not exist
The external button is updating net jog-inc-1 when I push the button (observed in Hal show)
Excerpt from postgui is as follows:
loadrt conv_bit_float count=1
addf conv-bit-float.0 servo-thread
net jog-inc-1 <= arduino.keypad.Jog-Inc-1
net jog-inc-1 => conv-bit-float.0.in
net jog-inc-1f  conv-bit-float.0.out 0.001
  • mark-v-d
  • mark-v-d
21 Aug 2024 21:41
Replied by mark-v-d on topic PID Servo Loop rates
You lose bandwidth by going to a lower servo PID rate. If that doesn't
matter because the system you're controlling is slow, there is no price
in going for a lower control speed.
With a sampling rate of 250Hz, you can actually measure up to 125Hz. In reality
the limit is usually between 1/5 and 1/3 that frequency before difference between
a sampled and a time continuous system become apparent.
So with 250Hz you're approximately limited to 50Hz of control
bandwidth. To me that seems terribly low. On my own lathe I have a
resonance at approximately 300Hz. Since I have the servo thread running
at 4500Hz (because that's the maximum rate the encoders I use support)
I was able to eliminate that resonance.
On the other hand, what do you lose when going for a higher sampling
rate? The only thing I can come up with is processor time, but that
seems hardly an issue on a modern PC. And I'm doing this on an RT_PREEMPT
kernel, so it's not even Xenomai or RTAI.
  • captain-panda
  • captain-panda's Avatar
21 Aug 2024 21:27 - 21 Aug 2024 21:33
Replied by captain-panda on topic 3 Achs Fräse mit MESA 7C80 und Raspi 4
Category: Deutsch
I got the smallest Gravograph machine (UNICA) up and running.
Thanks once again for your input and this amazing forum in general :)
Now, the larger machines have 1-phase AC motors and a separate speed control PCB that's actually a single-phase frequency converter. So far so good, there's also an encoder and a potentiometer to set speed, BUT:
The potentiometer is 500 kOhm and voltage across the potentiometer is merely 0,22 V.
Is there any way to get this to work with LinuxCNC?
[EDIT]
I'd like to apologize for crashing Hans Peter - HPWs thread.
Would it be better to move my issues to a new topic instead?
Hans Peter, verzeih mir bitte, dass ich mich hier hineingedrängt habe
  • zmrdko
  • zmrdko's Avatar
21 Aug 2024 21:19
Replied by zmrdko on topic New LinuxCNC-Ethercat git tree
Category: EtherCAT
looks like golang did it. Thanks a lot Scott!!
  • scotta
  • scotta's Avatar
21 Aug 2024 20:37
In fact, it is that exact work that has got me started. A great starting point to build from.
  • m456arcus
  • m456arcus
21 Aug 2024 20:36 - 21 Aug 2024 20:42
Help Wanted for creating new UI with Qt and EtherCAT
Category: Qtvcp
Hi folks,
I'd like to create a new interface and am in need of some help. I'd like to create something like the attached mockup, and overall it is fairly ambitious. I've installed and messed around a bit with LinuxCNC, a few existing interfaces, and Qt Designer, but haven't been able to completely figure it out. I have some programming experience in C# but not in Linux. Trying to sort out all the pieces of LinuxCNC is not easy, so I'd be happy to pay for someone's time to help get me started with a bit of tutoring or coding work. Once I get started off right I should be able to take it from there.
The end goal is to create a modern looking and user-friendly interface, with a lot of common sense features built in. I am a mechanical engineer and own a small machine shop, and I've got some designs for a CNC machine I'd like to build and possibly sell. If we can create an interface that is also customizable and open source so others can make use of it, that would be a bonus. I would like to avoid any dependencies on existing interfaces, not sure how reasonable that is but I know it will definitely be much more work.
I would like to use EtherCAT and have seen some posts regarding it, but not sure how well it is supported, or if there are any issues with implementing it. The system ideally would be a small PC connected directly to EtherCAT servos drives, I/O modules, etc.
The interface design is based on  www.openbridge.no/.
Any advice, cautions, referrals, etc. would be greatly appreciated!
  • PCW
  • PCW's Avatar
21 Aug 2024 20:29
Replied by PCW on topic 9 axis jog
9 axis jog
The GUI has no direct connections to the hardware,
so the GUI is basically hardware independent.
That is, parallel port, EtherCAT, Remora, Mesa
etc are all the same GUI wise.
You _do_ need hardware specific hal/ini support for all axis
  • RLA
  • RLA
21 Aug 2024 20:12
Replied by RLA on topic 9 axis jog
9 axis jog
I saw something like that in the linuxcnc...but I do not see how to connect to mesa 7i96s board ....is it possible?
Thanks!!
  • PCW
  • PCW's Avatar
21 Aug 2024 19:42 - 21 Aug 2024 19:43
Replied by PCW on topic Mesa 7I92TM Parallel port pin mapping
Category: PnCConf Wizard
After flashing, you need to power cycle  the 7I92 or use mesaflash's  --reload option
You should not need to use any kind of cable adapter
If you have a unique breakout, firmware can be built for this in a few minutes
  • anfänger
  • anfänger's Avatar
21 Aug 2024 19:08
Replied by anfänger on topic probe_basic read jog increments
Category: QtPyVCP
I found my old entry and it looks that there is no Hal pins for the jog increments.
I made a user tab doing what I want.
Is there a way to suppress the original jog tab?
Displaying 22741 - 22755 out of 24951 results.
Time to create page: 0.478 seconds
