  • alexandrap
  • alexandrap
04 Jun 2025 12:55 - 04 Jun 2025 12:56
Replied by alexandrap on topic Updating pncconf for 7i95t
Category: PnCConf Wizard
I resigned.
Can you tell me what lines you would put in the fictitious .hal and .ini files to make the step-dir spindle work?
for lathe config XZ(C?)
Or a link to an example.
thanks
  • cmorley
  • cmorley
04 Jun 2025 12:47
Replied by cmorley on topic indicatorPushButton led hal pin
Category: Qtvcp
The led name will be the button name with '-led' on the end.
in the above example the pin name would be 'SCREENNAME.mybutton-led'
  • andypugh
  • andypugh's Avatar
04 Jun 2025 12:34
Replied by andypugh on topic Index homing Heidenhain ls 403/exe602
Category: Basic Configuration
I checked my randomly-purchased liner scale (found at EMFCamp) and that is an LS 903 (no C) so is probably no help.
  • andypugh
  • andypugh's Avatar
04 Jun 2025 10:22
Replied by andypugh on topic LinuxCNC compatible industrial PC
Late to the party, but I have recently switched both my machines to run from the Asrock N100DC-ITX board.
Latency is "fair" rather than good. But they are avaialble, run from 12V DC and can be booted from an M2 SSD for a neat installation in the machine cabinet.
www.mini-itx.com/~N100DC-ITX
(Unhelpfully, out of stock, maybe because I bought three of them from there.)
Apparently they are picky about memory, especially at 12V rather than 19V, so maybe buy memory at the same time.
  • andypugh
  • andypugh's Avatar
04 Jun 2025 10:13
Replied by andypugh on topic Toyota embroidery machine - retrofit
Category: CNC Machines
You might want to set feed-hold when the needle is down, and release it when the needle is up...
  • andypugh
  • andypugh's Avatar
04 Jun 2025 10:12
I think that if you scale the potentiometer voltage to position, and latch it in HAL (you can do this with a mux component, with the output wired to the input, and triggered by machine-is-on) and add that to the scaled encoder position from the motor encoder, then you would have a "good enough" absolute encoder emulator.
Then configure HOME_ABSOLUTE_ENCODER in the INI
  • andypugh
  • andypugh's Avatar
04 Jun 2025 09:22
LinuxCNC Norway Meetup - 4th to 6th July 2025
Category: LinuxCNC Announcements
A month to go to the LinuxCNC developer meetup in Norway.
Original announcment:
As last year Petter and I would like to invite you all to small
LinuxCNCand free software fabricationworkshop/gathering
in Norway this summer for the weekend starting July 4th 2024.
We would again suggest to organize it as an unconference, <URL:
en.wikipedia.org/wiki/Unconference >,
where the participants create the program upon arrival.
The location is a metal workshop 15 minutes drive away from to the
Gardermoen airport (OSL), where there is a lot of space and a hotel only
5 minutes away by car. We plan to fire up the barbeque in the evenings.
Please let us know if you would like to join.  We track the list of
participants on <URL:  pad.efn.no/p/linuxcnc-2025-norway >.
The NUUG Foundation, <URL:  www.nuug
< www.nuugfoundation.no/ >foundation
< www.nuugfoundation.no/ >.no/ < www.nuugfoundation.no/ >>
has on our
request offered to handle any money involved with this gathering, in
other words holding any sponsor funds and paying any bills.
NUUG Foundation is a spinnoff from the NUUGmember organisation here in
Norway with long ties to the free softwareand open standards communities.
As usual we hope to find sponsorsto pay for food, lodgingand travel.
Best regards,
Asle Næss
Previous instances have been informal, with discussion of LinuxCNC and tinkering with the machine tools in Petter's cathederal-like workshop (including a crypt). Norway is famously expensive but the hotel we use (Best Western Leto Arena) is surprisingly affordable at NOK790/€68/£57/$78 per night.
  • SwitchWitch
  • SwitchWitch
04 Jun 2025 09:18
Replied by SwitchWitch on topic xml and hal - I am lost
Category: EtherCAT
One major issue of understanding/misunderstanding for me ist that when I try out example files for hal and xml i always get the error that lcec can`t be loaded. Perhaps this is lost/replaced/ereased in the version 2.94? How could I adress hal pins without lcec loaded?
  • SwitchWitch
  • SwitchWitch
04 Jun 2025 08:58
Category: EtherCAT
It would be so nice if anybody could share a 2.94 compatible setup for the i-o modules and servos drives. I always stuck in error I can`t resolve by myself for now.
A reliable starting point would be genious.
I would realla appreciate any help or hints.
  • BlownCorona
  • BlownCorona
04 Jun 2025 08:50
Replied by BlownCorona on topic Mesa 7i97T & LinuxCNC setup struggles
Category: Installing LinuxCNC
Good evening again all.
Everything above has gone well, i greatly appreciate the advice. I'm now working through Tommys servo tuning guide, aswell as the one i found from PCW, same instructions for the most part.
I just have one potentially really dumb question, do the servos need to be fitted to the mill for tuning? thats to say, in order to do any tuning at all? Its cold (New Zealand) and im playing with CNC parts in the lounge in front of the fire, but the servos dont really react how i would expect when reading the guides and it occurs to me that they probably need something to load up against in order to work properly? they arnt very happy turning with any P value above 5-10, but this value provides very little torque. the F error is responding to tweaks nicely at a low P value as expected, but i cant then turn up the power without it getting upset.
While i always intended to fine tune the servos on the machine, i was hoping to continue working through it in the warmth .
Cheers
Josh
  • Traken
  • Traken
04 Jun 2025 08:29
Servo Oscillation Issue at ±6.6V 5i25 + 7i77, Analog Control
I haven't checked, but today I will check the only thing I tried to power the 7i77 with a separate power supply but it didn't help.
  • workshop54
  • workshop54
04 Jun 2025 08:20
Replied by workshop54 on topic LinuxCNC compatible industrial PC
I'm not sure what you mean PCW,
The ip address of the host is 192.168.1.100 as far as I can tell. (The Mesa card is connected to enp3s0)
$ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:01:c0:33:50:2a brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.165/24 brd 192.168.1.255 scope global dynamic noprefixroute enp2s0
       valid_lft 86236sec preferred_lft 86236sec
    inet6 fe80::62f5:a9e5:df33:68d6/64 scope link noprefixroute
3: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:01:c0:33:50:2d brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.100/24 brd 192.168.1.255 scope global noprefixroute enp3s0
    inet6 fe80::868a:991b:a25e:44d0/64 scope link noprefixroute
4: eno1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether 00:01:c0:3a:5b:8e brd ff:ff:ff:ff:ff:ff
    altname enp0s29f1
5: eno2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether 00:01:c0:3a:5b:8f brd ff:ff:ff:ff:ff:ff
    altname enp0s29f2
$ sudo chrt 99 ping -i .001 -q -c 60000 192.168.1.121
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
--- 192.168.1.121 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 60002ms
rtt min/avg/max/mdev = 0.054/0.138/0.686/0.047 ms
$ ip route get 192.168.1.121
192.168.1.121 dev enp3s0 src 192.168.1.100 uid 1000
    cache
  • martin71bay
  • martin71bay
04 Jun 2025 07:54 - 04 Jun 2025 08:02
Replied by martin71bay on topic Planetcnc MK3/4 controller with LinuxCNC?
Category: Driver Boards
Hallo Michael,
wo sind 2 USB Anschlüße? Auf der PlanetCNC Platine ist nur einer(zum PC).
Du hast die 2 USB Stecker gesehen.Nein,das war/ist nur ein anderes USB Kabel zum testen gewesen.
Ich meinte,LinuxCNC mit USB geht/funktioniert nicht.
Schon klar,das das Handrad und die PlanetCNC Platine am PC eingesteckt wird.
du hast wahrscheinlich Recht.Der 26 pin Header ist eine Auswahl an Ausgängen.
Dann muss ich überlegen,was ich jetzt will.
Aber die Planetcnc Software läuft ja auch auf Linux(Mint).Bei mir ja auch.TNGv2 for Linux64Bit.
Da geht es ja auch über USB.......
Grüße-Martin
  • michaeln
  • michaeln
04 Jun 2025 07:34
Replied by michaeln on topic Planetcnc MK3/4 controller with LinuxCNC?
Hallo Martin,
vielleicht liegt ja nur ein Mißverständnis vor.
In deiner ersten Post schreibst du das USB nicht möglich ist. Warum? Ich sehe an der Platine aber 2 USB-Stecker.
Das Handrad WHB04-4 Handrad oder dein selbst gebautes Pendant werden am PC eingesteckt und nicht an der Platine (wie bei LinuxCNC auch). Und diese PlanetCNC Platine wird dann auch am PC eingesteckt.
Siehe cnc.zone/hardware/accesories/acces-whnd der Satz "Connect the USB dongle with your PC's USB port."
Natürlich funktioniert dann aber nur die PlanetCNC Software, nicht LinuxCNC.
Viele Grüße
MIchael
  • Aciera
  • Aciera's Avatar
04 Jun 2025 07:31
Replied by Aciera on topic Toyota embroidery machine - retrofit
Is there another motion axis?
There is and it seems so be using the same potentiometer setup:
Displaying 2311 - 2325 out of 25003 results.
Time to create page: 0.226 seconds
