  • Kieran
  • Kieran
03 Jun 2025 16:33
GUI that somewhat resembles haas or fanuc workflow.
Im thinking I can send-cut-send a panel, with switches as desired, and use a keyboard USB "brain" to read them. then basically map them however needed at that point. that's the easier part for me. Learning the computer/software GUI stuff is gonna be a learning curve.
  • juliankoenig87
  • juliankoenig87
03 Jun 2025 16:30
Replied by juliankoenig87 on topic EasyProbe + PGFUN 3D probe
The drives are 33 years old and the machine was in service till this year on a nearly daily basis. And again. The drives are known for having problems with the tantals. I dont want to have problems later on which I could had easily avoided.
  • langdons
  • langdons
03 Jun 2025 15:25
Replied by langdons on topic Ohmic sensing with IPTM-60
Category: Show Your Stuff
Unique inventions went extinct long, long ago.
All new inventions/creations are a remix or a knockoff.
New "Music" is all remixes and knockoffs too.
  • langdons
  • langdons
03 Jun 2025 15:22
Replied by langdons on topic EasyProbe + PGFUN 3D probe
But why replace them at all?
If it ain't broke, don't fix it.
  • Hakan
  • Hakan
03 Jun 2025 15:20 - 03 Jun 2025 20:16
Replied by Hakan on topic Ohmic sensing with IPTM-60
Schema here
  • PCW
  • PCW's Avatar
03 Jun 2025 15:03
Replied by PCW on topic Cant get spindle RPM to display
Category: QtPyVCP
One way:
in the main hal file add:
net spindle-vel-rpm hm2_[MESA](BOARD).0.encoder.00.velocity-rpm
in the gui hal file delete:
net spindle.0.revs  => qtpyvcp.spindle-encoder-rpm.in
and add:
net spindle-vel-rpm  => qtpyvcp.spindle-encoder-rpm.in
  • Sternfox
  • Sternfox
03 Jun 2025 14:28
Cant get spindle RPM to display was created by Sternfox
Category: QtPyVCP
Hi guys, can't get spindle RPM to display, i have noticed a few different examples in the postgui.hal but non seem to work, i just get a -0 in my rpm display, I will attach my postgui.hal and my main.hal and a screenshot of halshow. Hopefully it's something very basic.thanks in advance
File Name: main_2025-06-03.hal
File Size:12 KB
File Name: probe_basi...tgui.hal
File Size:2 KB
  • PCW
  • PCW's Avatar
03 Jun 2025 14:24
Servo Oscillation Issue at ±6.6V 5i25 + 7i77, Analog Control
Category: Basic Configuration
Yes, looks like an encoder issue of some kind (especially the sudden drop to 0 velocity)
I would try lowering  the emulated encoder output scale, as
maybe the drive has an issue with quadrature generation at high
speeds and high  resolutions.
  • PCW
  • PCW's Avatar
03 Jun 2025 14:10
Replied by PCW on topic Updating pncconf for 7i95t
Category: PnCConf Wizard
Its probably easier to add the step/dir spindle to a MesaCT created configuration.
Can you post your MesaCT created hal/ini/io files?
No more than handful of lines need to be added.
  • SwitchWitch
  • SwitchWitch
03 Jun 2025 13:53
xml and hal - I am lost was created by SwitchWitch
Category: EtherCAT
I know - it is very unusual as a linuxcnc noob to start with an ethercat setup especially when you are en ethercat noob as well...
but I was so fascinated that I just wanted to give it a try.
Now I am at the point where Linuxcnc is installed, my ethercat is running and I get this terminal output:
0  0:0  OP      +  EK1100 EtherCAT-Koppler (2A E-Bus)
1  0:1  OP      +  EL1088 8Ch. Dig. Input 24V, 3ms, negative
2  0:2  OP      +  EL1008 8K. Dig. Eingang 24V, 3ms
3  0:3  OP      +  EL2008 8K. Dig. Ausgang 24V, 0.5A
4  0:4  OP      +  EL1008 8K. Dig. Eingang 24V, 3ms
5  0:5  OP      +  EL2008 8K. Dig. Ausgang 24V, 0.5A
6  0:6  SAFEOP  E  AS715N_sAxis_V0.10
7  0:7  SAFEOP  E  AS715N_sAxis_V0.10
8  0:8  SAFEOP  E  AS715N_sAxis_V0.10
As servos I use 3x Stepperonline OMC a6 400W
Now I tried to figure out how to build a working xml and a corresponding hal file.
After several hours of reading try`ll and error my last hope is that somebody of you would be so kind to share its xml and hal (best with running a6 servos) file so that I have a starting point for my setup.
Any help or hint is highly appreciated!
best
Kai
  • juliankoenig87
  • juliankoenig87
03 Jun 2025 13:40
One: as you said... puff
Two: smd caps is faster to replace. I have to change nearly 30 caps each driver. So 90 in total.
When clipping the old one and soldering the smd on the other side directly on/over the drilled holes its a damn fast way. Cleaning the holes, soldering tantals in, clipping the wires taked more time...
So mainly cause I am lazy. And tantals costs (in comparable quality at my normal suppliers) round about 15 to 20 euros more than smd ceramics.
  • langdons
  • langdons
03 Jun 2025 13:19
Tantalum caps are good.
Why the anti-tantalum mentality?
They do explode tho.
I once plugged in a tantalum cap the wrong way and it exploded shards into my fingers.
I'm fine tho.
It didn't break the skin.
  • jtrantow
  • jtrantow
03 Jun 2025 13:17
Problem: Analog jog via gamepad does not move axis in LinuxCNC
You will want to qualify the analog jog with another button press. Both selected speed and analog stick need to be active for jog to occur.
Without this the machine will jog if the analog stick gets stuck at non-zero, which will happen when chips or dust get into the stick.  When this happens I take the joypad apart and blow it out with air. After 4-5 years of using joypads on three machines, I should probably ebay a spare.
  • jtrantow
  • jtrantow
03 Jun 2025 13:04
yes that's it. Not sure why the .jpg nor .zip download doesn't work anymore.
If you add these two of these files to your postgui list, you don't need to make any changes to your main configuration .hal. The first file is joystick_jog_speed.hal. Next add _xz or _xyz for a xz lathe or xyz mill configuration.  You will also want _extras.hal as it lets you use btn-base and btn-top to go between manual and auto mode. Keeping all your joypad .hal in separate files helps keep track of changes and allows you to simply remove the joypad from a configuration is it's not available. These files have been used on many 2.9.x machines. (Small changes to several names with 2.8.x machines.)
Displaying 2401 - 2415 out of 24993 results.
Time to create page: 0.501 seconds
