31 Jul 2024 07:44
Replied by tommylight on topic Is a parport fast enough?
To many things wrong there
-parallel port can NOT do all inputs in any of it's modes
-parallel port has 17 I/O in total, there are inputs 18 and 19 mentioned on the first post
so i agree with Cornholio, it is rubbish and will waste more time than asking humans
Parallel port can do
-mode out = 12 out 5 in
-mode in = 13 in 4 out
-mode X = 8 out 9 in
And LinuxCNC can control multiple at the same time.
  • Lpkkk
  • Lpkkk
31 Jul 2024 07:41 - 31 Jul 2024 08:10
Thank you Scott for verifying. I've tried with 3.1.3 but after flashing I've got an error in rs232 debug (attached). And the board stopped responding to ping. So I've tried 3.1.2 but now board stopped displaying any debug info and I cannot reflash it because of another error from pyocd (attached).
  • RotarySMP
  • RotarySMP's Avatar
31 Jul 2024 07:40 - 31 Jul 2024 07:55
Replied by RotarySMP on topic Verify my Mesa selection
Category: Driver Boards
That is a good board selection for your machine. It is the modern version on the 5i25/7i77/7i84 which is working well for me on the Maho.
You list connecting your three MPG's to the 7i97 using 6 inputs. You could  do that, but will have three unused high speed encoder inputs on the 7i97, which you could use. However, in practice, your MPG's are probably on the user control panel and will be more practically wired into the 7i73, rather than running those three cables back down to the electrical cabinet to the 7i97.
Yes, you can make up a Talla83 board to add a couple of extra SS ports. You will need to edit your bitfile for that, but Peter describes that. This would give you two ports, one for the 7i73, and leaving one for the pendant.
Have you seen "Toms Pendant" which Talla83 made with a guy called Tom? I had already made mine when this came out, but it is way better than mine.
talla83.hier-im-netz.de/hp_inhalte/tshw/TsHW_V3.pdf
www.thingiverse.com/thing:3684937
github.com/talla83/tshw_2022
31 Jul 2024 07:35
Replied by Cant do this anymore bye all on topic Is a parport fast enough?
I'm sorry mate, but that is what it is.
To begin with the ini has the make up of a hal file.
The "config" file is more like a driver file (linuxcnc uses ini & hal files). If it was to be a driver, it's not loaded, it's not added to any threads, so it wont do anything.
The timing for writing for writing to the "DAC" is unlikely to be met. You'll need two Parallel Port interfaces, and it's very rare to find a computer with 2 on board interfaces. The last time I saw a machine with Parallel Ports at 0x378 & 0x278 was old an old ISA bus machine where the cards needed to be configured by jumpers.
Now there are ways to control analogue servo drives, but the parallel port is not the way route to choose.
Now what I would suggest is to start a new topic asking the best way to control analogue servo drives. And lets leave this whole ChatGPT nonense behind us.
I would also recommend reading the documentation to get a feel of the basics.
  • pietxs
  • pietxs
31 Jul 2024 07:34
Mesa 7i77 remote error = (27) over current
Hello, I have the following problem with my 7i77 card.
I take the card's field voltage from my Maho machine, it's around 29V. I connected the machine's original relays to the outputs. Unfortunately I get the following error: hm2/hm2_7i77.0: Smart serial card hm2/hm2_7i777,0.7i77.0.0 remote error = (27) Over Current
I have already removed all outputs and inputs, unfortunately the error still persists. I completely disconnected the power supply and switched off the PC. Unfortunately the same error always occurs when restarting and output 08-11 is permanently "on".
Can I reset the card somehow? Can I fix the error by rewriting the firmware?
Surely the outputs should be able to withstand the switching loads of the relays?
I hope someone has a helpful idea for me
  • Basti189
  • Basti189's Avatar
31 Jul 2024 07:30
Lathe turret tool changer with absolute encoder
Hello, sorry to bring up the old thread again, I have read through everything with enthusiasm because I have the same problem with the encoder,
my revolver is almost exactly the same only with 12 places and a brake on the motor .... My question did you solve the problem ? And if so how ?
  • JamesHoward
  • JamesHoward
31 Jul 2024 07:14
Replied by JamesHoward on topic Is a parport fast enough?
well... thanks for your help
  • AD_15
  • AD_15
31 Jul 2024 06:44
SPINDLE USING GPIO was created by AD_15
SPINDLE USING GPIO
Hello!!
I have designed my own board for 3 axis motion control using spartan 6 FPGA. Here we have tested our board using stepper and we have successfully done with homing but while we try to run a design file we are getting errors of joint 0, joint 1, joint 2. But in servo we are getting error of joint 0, joint 1, joint 2 as I start linuxcnc. So what should be the reason behind joint 0 following error?
Can Someone please help me regarding this issue?
31 Jul 2024 06:19
It's not even a base, its mumbo jumbo.
  • IronManDylan
  • IronManDylan
31 Jul 2024 06:02
Simultaneous 4th Axis Cut Moving Too Slow was created by IronManDylan
I haven't asked a question in a while but I am machining something new on my mill with my 4th axis and it is requiring me to do a simultaneous 4th axis cut which I have not done before. I had some issues simply getting to tool path to post correctly.  I finally figured that out but now the cut is going extremely slow.  The velocity is supposed to be cutting at 46  in/min.  The post processor is indeed posting this velocity with "F46", however the cut is going extremely slow. Since the post processor is outputting the correct velocity I do not think it is the post processor that is at fault but something going on with linuxcnc. The endmill is taking such a small cut that the aluminum is coming off as fine dust.  The "vel" on the display is showing around "2" (I am not sure if this is in inches/min or not).
In my INI folder the max angular velocity is set to "33" and I can jog the 4th axis faster than what is going on in the cut.  So I do not think this is the problem.. I have outputted code in both the normal velocity profile and in the inverse profile and neither seem to help.
The cut is just a circular arc but the center of the arc is not centered with the rotational axis.  The tool path is just a contour where I need the tool to remain perpendicular to the arc.
I appreciate any help or words of wisdom!
Best,
-Dylan
  • JamesHoward
  • JamesHoward
31 Jul 2024 05:06 - 31 Jul 2024 05:08
I know Chats algo's arent perfect.. Its like a highschooler still. It is a good base to start from tho. I actually have a seperate encoder card for the computer. I just had it throw it in there... But I sure like not having not to type all that out! Especially for something that might not even be good enough! Yes I would like to have real time! Of course!
I am looking to have real +-10 v for my servo drives. That is the end goal. I just have this DAC kicking around, I figured it could be of good use being bi-polar and all..... I have a 3 axis mill. I and not interested in changing the drives or motors. These puppies are 10 HP. I like to cut FAST! :dry:
  • spumco
  • spumco
31 Jul 2024 03:24
Can a 'servo drive' be used to power a 3 phase AC spindle motor with encoder?
It depends on the servo drive, but generally not.
The 3p Fanuc you're referring to is an induction motor.  "AC servo" generally refers to a permanent magent synchronous motor.  Not the same thing.  And that U3K can't drive induction motors.
Of course, any motor (or actuator, really) that is controlled with a feedback loop can be considered a servo... but that's not really what you want to know.
The good news is that Fanuc can be driven with an ordinary VFD.  Depending on the amps, you can even use a 240vac 1p to 3p VFD.  You don't even need to replace the motor resolver - just leave it disconnected and run the motor open loop. My internet photo scraping indicates there's a separate encoder on the spindle... that's what LCNC will use to manage the motor speed and for threading/orientation.
But you're talking about a Conquest, not a toy lathe... so I'm guessing you're thinking about real work for real clients?  If that's the case I wouldn't trust a VFD-brake-induction motor combo to position to a tight tolerance repeatably for production work.  If you're making pipe flanges with a huge bolthole tolerance - no sweat.
Just think about how heavy the spindle is, plus the chuck, plus the work... and guesstimate the inertia ratio with a 1:1 belt drive... the whole arrangement will have a hard time stopping on a dime.  And if you fiddle the belt ratio to get some torque, you'll kill the max spindle RPM.
It's likely that the original Fanuc spindle drive could position well enough for C-axis work, but those things are big money for a reason; they're basically servo drives for induction motors.
My guess is that the minute you stick an end mill in a radial holder and try to cut a circumferential groove/feature the aftermarket VFD won't be able to handle it.  Same for polar interpolation with an axial tool (making a hex out of round with the X/C-axes).
[side note: LCNC doesn't have 'built-in' polar interpolation.  It can be done, but it's non-trivial to accomplish]
Others may have a different opinion, but mine is that for dynamic C-axis lathe work you need a separate positioning motor as well as a spindle-mounted high-res encoder.  My Emco CNC lathe uses a pneumatic cylinder to swing the C-axis positioning motor in to mesh with a large bull gear on the spindle.  I think it's about 40:1 - maybe more.  The constant air pressure keeps backlash to a minimum, but also makes it noisy and limits the C-axis top speed.
For little lathes (like the one I'm building - think HLV-H size), a big AC servo and a favorable belt ratio can work for positioning and light off-axis milling/engraving, but that's about it.  Unless the servo is massively oversized it just won't have enough torque for tight-tolerance work against unfavorable machining forces.
So to sum up - a VFD will spin that Fanuc.  And should do positioning OK (with the brake) for axial/radial drilling.  But i don't think it'll work for dynamic C-axis work, and the positioning accuracy may not meet your tolerance requirements
Just my two cents...
31 Jul 2024 03:17
It's rubbish. ChatGPT is stupid, on levels that will get we banned for even mentioning.
The config seems to a driver. That doesn't seem to be loaded. There's bits for quad encoders, spindle. It's like it's just thrown stuff together. There appears to be no consideration given to timing of signals.
What exactly do you want to do ?
If you just want to use a DAC in non real time there are so many other ways to do it without needing Linuxcnc.
  • JamesHoward
  • JamesHoward
31 Jul 2024 02:31
Is a parport fast enough? was created by JamesHoward
So heres a fun one! I was pondering..... Will a parallel port run a DAC directly?  I have an AD664-bip. It is a 4 channel 12 bit (8 pins with two words) bi-polar DAC. I had ChatGpt write up a driver for it. But before I go making up a PCB for this... What do you think??
Datasheet:
www.analog.com/media/en/technical-docume...ata-sheets/ad664.pdf
Here is the hal.ini
loadrt trivkins
loadrt motmod base_period=1000000 servo_period=1000000
# Load parallel port drivers
loadrt hal_parport cfg="0x378 out 0x278 out"
# Define DAC (AD664JN-BIP) control and data pins
net dac-data <= parport.0.pin-02-09
net dac-wr => parport.0.pin-10-out
net dac-cs => parport.0.pin-11-out
# Define quadrature encoders
net x-pos-a => parport.0.pin-12-in
net x-pos-b => parport.0.pin-13-in
net y-pos-a => parport.0.pin-14-in
net y-pos-b => parport.0.pin-15-in
net z-pos-a => parport.0.pin-16-in
net z-pos-b => parport.0.pin-17-in
net spindle-pos-a => parport.1.pin-10-in
net spindle-pos-b => parport.1.pin-11-in
# Define limit and home switches
net x-neg-limit => parport.1.pin-12-in
net x-pos-limit => parport.1.pin-13-in
net x-home => parport.1.pin-14-in
net y-neg-limit => parport.1.pin-15-in
net y-pos-limit => parport.1.pin-16-in
net y-home => parport.1.pin-17-in
net z-neg-limit => parport.1.pin-18-in
net z-pos-limit => parport.1.pin-19-in
net z-home => parport.1.pin-20-in
# Define global enable output
net global-enable => parport.0.pin-01-out
# Define GPIO pins
net gpio-in-00 <= parport.1.pin-02-in
net gpio-in-01 <= parport.1.pin-03-in
net gpio-in-02 <= parport.1.pin-04-in
net gpio-in-03 <= parport.1.pin-05-in
net gpio-in-04 <= parport.1.pin-06-in
net gpio-in-05 <= parport.1.pin-07-in
net gpio-out-00 => parport.1.pin-08-out
net gpio-out-01 => parport.1.pin-09-out
net gpio-out-02 => parport.1.pin-15-out
net gpio-out-03 => parport.1.pin-16-out
net gpio-out-04 => parport.1.pin-01-out
net gpio-out-05 => parport.1.pin-14-out
addf parport.1.read base-thread
addf parport.1.write base-thread
start
And here is the config:
#include "hal.h"
#include "rtapi.h"
#include "rtapi_app.h"
#include "rtapi_bitops.h"
#include "hal_parport.h"
// Define pins and parameters
static int comp_id;
static hal_float_t *x_output;
static hal_float_t *y_output;
static hal_float_t *z_output;
static hal_float_t *spindle_output;
static hal_bit_t *global_enable;
static hal_bit_t *x_home;
static hal_bit_t *y_home;
static hal_bit_t *z_home;
// Limit switches
static hal_bit_t *x_neg_limit, *x_pos_limit;
static hal_bit_t *y_neg_limit, *y_pos_limit;
static hal_bit_t *z_neg_limit, *z_pos_limit;
// Quadrature encoder positions
static hal_bit_t *x_pos_a, *x_pos_b;
static hal_bit_t *y_pos_a, *y_pos_b;
static hal_bit_t *z_pos_a, *z_pos_b;
static hal_bit_t *spindle_pos_a, *spindle_pos_b;
// GPIO pins
static hal_bit_t *gpio_in_00, *gpio_in_01, *gpio_in_02, *gpio_in_03, *gpio_in_04, *gpio_in_05;
static hal_bit_t *gpio_out_00, *gpio_out_01, *gpio_out_02, *gpio_out_03, *gpio_out_04, *gpio_out_05;
// Previous states for quadrature decoding
static int prev_x_pos = 0, prev_y_pos = 0, prev_z_pos = 0, prev_spindle_pos = 0;
// Position counters
static int x_counter = 0, y_counter = 0, z_counter = 0, spindle_counter = 0;
#define SCALE_FACTOR 204.8 // Scale factor for 12-bit DAC with ±10V range
// Lookup table for quadrature decoding
const int quad_table[16] = {
    0, -1,  1,  0,
    1,  0,  0, -1,
   -1,  0,  0,  1,
    0,  1, -1,  0
static void write_dac_value(uint8_t data)
    hal_parport_write_data(0, data);
    hal_parport_write_pin(0, 11, 0); // CS low
    hal_parport_write_pin(0, 10, 0); // WR low
    hal_parport_write_pin(0, 10, 1); // WR high
    hal_parport_write_pin(0, 11, 1); // CS high
static void update(void *arg, long period)
    uint16_t x_value = (uint16_t)((*x_output + 10.0) * SCALE_FACTOR); // Scaling from -10V to 10V
    uint16_t y_value = (uint16_t)((*y_output + 10.0) * SCALE_FACTOR);
    uint16_t z_value = (uint16_t)((*z_output + 10.0) * SCALE_FACTOR);
    uint16_t spindle_value = (uint16_t)((*spindle_output + 10.0) * SCALE_FACTOR);
    // Send data to DAC for each axis in sequence
    write_dac_value((x_value >> 4) & 0xFF); // Send upper 8 bits
    write_dac_value((x_value << 4) & 0xF0); // Send lower 4 bits
    write_dac_value((y_value >> 4) & 0xFF); // Send upper 8 bits
    write_dac_value((y_value << 4) & 0xF0); // Send lower 4 bits
    write_dac_value((z_value >> 4) & 0xFF); // Send upper 8 bits
    write_dac_value((z_value << 4) & 0xF0); // Send lower 4 bits
    write_dac_value((spindle_value >> 4) & 0xFF); // Send upper 8 bits
    write_dac_value((spindle_value << 4) & 0xF0); // Send lower 4 bits
    hal_parport_write_pin(0, 1, *global_enable);
    // Read limit and home switches
    *x_neg_limit = hal_parport_read_pin(1, 12);
    *x_pos_limit = hal_parport_read_pin(1, 13);
    *x_home = hal_parport_read_pin(1, 14);
    *y_neg_limit = hal_parport_read_pin(1, 15);
    *y_pos_limit = hal_parport_read_pin(1, 16);
    *y_home = hal_parport_read_pin(1, 17);
    *z_neg_limit = hal_parport_read_pin(1, 18);
    *z_pos_limit = hal_parport_read_pin(1, 19);
    *z_home = hal_parport_read_pin(1, 20);
    // Read quadrature encoder inputs
    int x_pos = hal_parport_read_pin(0, 12) | (hal_parport_read_pin(0, 13) << 1);
    int y_pos = hal_parport_read_pin(0, 14) | (hal_parport_read_pin(0, 15) << 1);
    int z_pos = hal_parport_read_pin(0, 16) | (hal_parport_read_pin(0, 17) << 1);
    int spindle_pos = hal_parport_read_pin(1, 10) | (hal_parport_read_pin(1, 11) << 1);
    // Quadrature decoding
    int x_delta = quad_table[(prev_x_pos << 2) | x_pos];
    int y_delta = quad_table[(prev_y_pos << 2) | y_pos];
    int z_delta = quad_table[(prev_z_pos << 2) | z_pos];
    int spindle_delta = quad_table[(prev_spindle_pos << 2) | spindle_pos];
    x_counter += x_delta;
    y_counter += y_delta;
    z_counter += z_delta;
    spindle_counter += spindle_delta;
    prev_x_pos = x_pos;
    prev_y_pos = y_pos;
    prev_z_pos = z_pos;
    prev_spindle_pos = spindle_pos;
    // Update GPIO output pins
    hal_parport_write_pin(1, 8, *gpio_out_00);
    hal_parport_write_pin(1, 9, *gpio_out_01);
    hal_parport_write_pin(1, 15, *gpio_out_02);
    hal_parport_write_pin(1, 16, *gpio_out_03);
    hal_parport_write_pin(1, 1, *gpio_out_04);
    hal_parport_write_pin(1, 14, *gpio_out_05);
    // Read GPIO input pins
    *gpio_in_00 = hal_parport_read_pin(1, 2);
    *gpio_in_01 = hal_parport_read_pin(1, 3);
    *gpio_in_02 = hal_parport_read_pin(1, 4);
    *gpio_in_03 = hal_parport_read_pin(1, 5);
    *gpio_in_04 = hal_parport_read_pin(1, 6);
    *gpio_in_05 = hal_parport_read_pin(1, 7);
int rtapi_app_main(void)
    comp_id = hal_init("my_driver");
    if (comp_id < 0)
        return comp_id;
    hal_pin_float_new("my_driver.x-output", HAL_OUT, &x_output, comp_id);
    hal_pin_float_new("my_driver.y-output", HAL_OUT, &y_output, comp_id);
    hal_pin_float_new("my_driver.z-output", HAL_OUT, &z_output, comp_id);
    hal_pin_float_new("my_driver.spindle-output", HAL_OUT, &spindle_output, comp_id);
    hal_pin_bit_new("my_driver.global-enable", HAL_OUT, &global_enable, comp_id);
    hal_pin_bit_new("my_driver.x-home", HAL_IN, &x_home, comp_id);
    hal_pin_bit_new("my_driver.y-home", HAL_IN, &y_home, comp_id);
    hal_pin_bit_new("my_driver.z-home", HAL_IN, &z_home, comp_id);
    hal_pin_bit_new("my_driver.x-neg-limit", HAL_IN, &x_neg_limit, comp_id);
    hal_pin_bit_new("my_driver.x-pos-limit", HAL_IN, &x_pos_limit, comp_id);
    hal_pin_bit_new("my_driver.y-neg-limit", HAL_IN, &y_neg_limit, comp_id);
    hal_pin_bit_new("my_driver.y-pos-limit", HAL_IN, &y_pos_limit, comp_id);
    hal_pin_bit_new("my_driver.z-neg-limit", HAL_IN, &z_neg_limit, comp_id);
    hal_pin_bit_new("my_driver.z-pos-limit", HAL_IN, &z_pos_limit, comp_id);
    hal_pin_bit_new("my_driver.x-pos-a", HAL_IN, &x_pos_a, comp_id);
    hal_pin_bit_new("my_driver.x-pos-b", HAL_IN, &x_pos_b, comp_id);
    hal_pin_bit_new("my_driver.y-pos-a", HAL_IN, &y_pos_a, comp_id);
    hal_pin_bit_new("my_driver.y-pos-b", HAL_IN, &y_pos_b, comp_id);
    hal_pin_bit_new("my_driver.z-pos-a", HAL_IN, &z_pos_a, comp_id);
    hal_pin_bit_new("my_driver.z-pos-b", HAL_IN, &z_pos_b, comp_id);
    hal_pin_bit_new("my_driver.spindle-pos-a", HAL_IN, &spindle_pos_a, comp_id);
    hal_pin_bit_new("my_driver.spindle-pos-b", HAL_IN, &spindle_pos_b, comp_id);
    hal_pin_bit_new("my_driver.gpio-in-00", HAL_IN, &gpio_in_00, comp_id);
    hal_pin_bit_new("my_driver.gpio-in-01", HAL_IN, &gpio_in_01, comp_id);
    hal_pin_bit_new("my_driver.gpio-in-02", HAL_IN, &gpio_in_02, comp_id);
    hal_pin_bit_new("my_driver.gpio-in-03", HAL_IN, &gpio_in_03, comp_id);
    hal_pin_bit_new("my_driver.gpio-in-04", HAL_IN, &gpio_in_04, comp_id);
    hal_pin_bit_new("my_driver.gpio-in-05", HAL_IN, &gpio_in_05, comp_id);
    hal_pin_bit_new("my_driver.gpio-out-00", HAL_OUT, &gpio_out_00, comp_id);
    hal_pin_bit_new("my_driver.gpio-out-01", HAL_OUT, &gpio_out_01, comp_id);
    hal_pin_bit_new("my_driver.gpio-out-02", HAL_OUT, &gpio_out_02, comp_id);
    hal_pin_bit_new("my_driver.gpio-out-03", HAL_OUT, &gpio_out_03, comp_id);
    hal_pin_bit_new("my_driver.gpio-out-04", HAL_OUT, &gpio_out_04, comp_id);
    hal_pin_bit_new("my_driver.gpio-out-05", HAL_OUT, &gpio_out_05, comp_id);
    rtapi_snprintf(name, sizeof(name), "my_driver.update");
    hal_periodic_func_new(update, NULL, 1000000);
    hal_ready(comp_id);
    return 0;
void rtapi_app_exit(void)
    hal_exit(comp_id);
31 Jul 2024 02:28
industrialautomationco.com/blogs/news/th...rvo-drives-explained
Pretty basic explanation, but comes down to motor construction.
Then again it might be best to contact the distributors/manufacturers.
Linuxcnc maybe able to control the VFD and close the loop for positioning purposes. Andy would have the wisest advice regarding this.
Displaying 24226 - 24240 out of 25068 results.
Time to create page: 0.520 seconds
