  • unknown
  • unknown
31 May 2025 23:18
installing linuxCNC 2.7.14 under Hyper-V Manager
Category: Installing LinuxCNC
TBH this is not really an Linuxcnc issue but a Hyper-V Debian issue as the standard Debian installer is used.
What you can try is to install Debian bookworm from a Debian ISO with XFCE desktop then follow the instructions in the Linuxcnc docs to install the Linuxcnc packages. This is about the best suggestion I can come up with.
Personally I use VirtualBox, as it's basically flawless.
  • Lcvette
  • Lcvette's Avatar
31 May 2025 23:15
New "BIG" Probe Basic Release for Develop Branch Incoming!
Category: QtPyVCP
OK all, the latest release for develop version is up and live installable via apt update if you are currently on the develop branch! hoping for some testers to playe with the new rack atc sim and give some feedback!
Thanks for checking in!
Chris
  • PCW
  • PCW's Avatar
31 May 2025 23:04
Replied by PCW on topic LinuxCNC compatible industrial PC
Note that for Mesa Ethernet cards the latency test is not terribly useful.
What is much more important is network latency. Default Mesa driver settings
will drop (timeout) packets if the return data takes more than 80% of the
servo period. As long as you do not drop packets due to these timeouts, latency is
relatively unimportant/
if you have a mesa card, try this:
sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10
(this will run for 1 minute and print delay statistics)
Change the IP address if you use 192.168.1.121
  • PCW
  • PCW's Avatar
31 May 2025 22:56
  • PCW
  • PCW's Avatar
31 May 2025 22:54
  • clayton2ndtry
  • clayton2ndtry
31 May 2025 22:24
Replied by clayton2ndtry on topic installing linuxCNC 2.7.14 under Hyper-V Manager
latency does not matter for simulation
  • snowgoer540
  • snowgoer540's Avatar
31 May 2025 22:17 - 31 May 2025 22:32
Replied by snowgoer540 on topic M62-M68 codes not working
Category: Plasmac
I made some time to look at this tonight.  I swear this worked the first time I tried it, but there's almost no way it could have ... so my apologies.
The reason it's not working is because you turn adaptive feed (M52) off:
N30 M52 P1 (Allow paused motion)
N35 M52 P0 (Disable paused motion)
Take out line N35 and it will work.
  • juliankoenig87
  • juliankoenig87
31 May 2025 21:51 - 31 May 2025 21:52
Replied by juliankoenig87 on topic EasyProbe + PGFUN 3D probe
Ah cool. I think this is a good example for the fact that you can get quality in China if you are willing to pay for it. Looks good.
I dont have a thread for my current project. It was a fast decision thing, because the price was low. Looks smaller on the picture than in real life. Weights 500kg (machine + table). Dont have the fancy pc table :-).
Old Berger Lahr 5 phase steppers. Drives invented 1987. Machine is build in 1992. I want to safe the old drives, because I like to maintain such old hardware. I already ordered some caps for replacement (known as fault reasons).
Machine is all cast iron! But with supported round rails instead of linear rails. But I will keep them. It will be sufficient for al lot of my work. Travel is 400x400x100. Machine is only 900x800xhight (didnt meassured it yet).
  • Cooped-Up
  • Cooped-Up
31 May 2025 21:00
Replied by Cooped-Up on topic Mesa card issues Maho MH800E Retrofit Project
here is that, didnt think to look for a file, I am new to linux so the command didnt click till it wasnt doing anything lol.
  • theoneandonlyoreo
  • theoneandonlyoreo
31 May 2025 20:06
Replied by theoneandonlyoreo on topic EasyProbe + PGFUN 3D probe
It's from LY CNC, which you can find on Alibaba. This is the 3040 model. I watched Stephan Gotteswinter's video about his new micro mill, and was inspired to do something similar. It was going to be difficult to get the same epoxy-granite frame he started with, here in the states. This cast-iron frame was a similar design, so I decided to try it out. There was a fair amount of waiting involved but the machine seems fairly sound.
With the spindle half-way down, I'm getting 0.000,5 in (13 microns) deflection with 20 lbf (88 N) pressing against the spindle nose. I think those are similar numbers to Gotteswinter's thumb test.
I got out the master square to check the perpendicularity of the X and Y axes. They're very square--within a few tenths (0.000,1 inch = 3 microns) over 10 inches (250 mm). The YZ plane leans back about 0.002" over the 7 inch travel of Z. In the XZ plane, there's 0.003" deviation over the same distance. I might eventually try to correct that but the parts I'm making are fairly small, so maybe it won't be a problem.
Do you have a thread about your retrofit?
  • CallumRD1
  • CallumRD1
31 May 2025 20:05
Replied by CallumRD1 on topic Keyboard shortcut rempaping
Category: Qtvcp
Thanks! I'll give it a try tomorrow. I just got back from a wedding so I haven't tried your updated file yet.
  • SebastianM
  • SebastianM
31 May 2025 19:54
Replied by SebastianM on topic Mesa modbus and pktUart
Category: Other User Interfaces
Hello y'all!
I just received my new mesa 7i76eu, and I have a huge CNC with a durapulse GS10 vfd (until now it was runnnig with grblhal).
Does "pktUart" allow me to connect my GS10 vfd directly to the mesa without a usb dongle?
Regards!
  • cmorley
  • cmorley
31 May 2025 19:22
Replied by cmorley on topic Reading variable from ini no longer works?
Category: Qtvcp
Try removing the comments that are on the same line.
Also confirm that the right INI file is being looked at. More then one of us have edited the wrong version :)
  • cmorley
  • cmorley
31 May 2025 19:14
Replied by cmorley on topic QtDragon Customize
QtDragon Customize
Category: Qtvcp
Either change all the HAL pin names in the Hal files from qtdragon to inova or add -c qtdragon to the load line in the INI.
DISPLAY = qtvcp -d -c qtdragon inova
Displaying 2641 - 2655 out of 24938 results.
Time to create page: 0.233 seconds
