  • unknown
  • unknown
14 May 2025 14:42
[SOLVED] New wifi card causes second parallel port to stop working
You can jam in as many parallel port cards as you have slots. They can be at any free address you have. If the on board one is buggered leaving it enabled will only affect the ISA compatible addresses, IE those hanging off the LPC bus. For the addresses allocated on the PCIe bus different realm, different interface, different bus. Hence the reason on board lpt ports don't show up via lspci, cos they are technically on the ISA bus but physically the LPC bus.
  • langdons
  • langdons
14 May 2025 14:40
Replied by langdons on topic Combined MESA board order for Australia.
Category: Driver Boards
Not a clone, a "compatible" device.
Support comes with a 90USD shipping cost.
Plus due to timezone differences, support will probably be impaired.
  • langdons
  • langdons
14 May 2025 14:35
Please post the output of lspci -v
Did you try rearranging the cards?
Perhaps order matters.
Some computers are picky about such things.
Most computers I've seen have max 2 PCIe ports, you are fortunate to have 3, though perhaps this broken behavior explains why most PCs only have 2 ports.
  • workshop54
  • workshop54
14 May 2025 14:34
Best practice for installing custom Python packages in LinuxCNC?
Fully agreed — if LinuxCNC ever gets a proper Java API, I’ll gladly throw my Python into the chip tray
Until then, I’ll just keep pretending my Python package has structure and discipline… while knowing deep down it’s all held together by logging statements and good intentions
  • unknown
  • unknown
14 May 2025 14:32
Replied by unknown on topic Combined MESA board order for Australia.
Oh great you're activly encourage someone to buy illegally cloned hardware, hardware mind that comes from a great company that gives fantastic support.
I've been waiting for you eff up.
  • unknown
  • unknown
14 May 2025 14:29
Why do you need wi-fi?
Wi-Fi will increase latency for your CNC system.
Your CNC PC should be as minimal as possible.
Ethernet is far better than Wi-Fi anyhow.
Why do you do this, you add nothing, it's of completely no use.
Stop being an oxygen thief and find some other forum to ply your idiocy.
Does this stuff come naturally to you or do you have to work hard to be such a waste of space ?
My apologies to the OP but the user is a menace and I just couldn't put up with his complete uselessness.
  • langdons
  • langdons
14 May 2025 14:29 - 14 May 2025 14:30
Some computers have a terrible BIOS with almost no features at all.
My Dell XPS 17 has like almost no helpful options in the BIOS.
It's incredibly lame.
Most PCs are UEFI nowadays anyways.
  • langdons
  • langdons
14 May 2025 14:27
If you want to "surf the web", just get a second PC and use that for Wi-Fi.
Your CNC PC should probably be used solely for CNC stuff.
You can also potentially dual-boot (I recommend Ubuntu 22.04 LTS).
14 May 2025 14:27
In BIOS, see if there is the option to manually assign the IRQ resources and change the offending port IRQ so it is not the same as the WiFi card.
Not all PC's have that option.
  • unknown
  • unknown
14 May 2025 14:24
Hard to really diagnose without seeing any relevant dmesg output or any info regarding the address of the parallel ports before failure and when failed.
If ptest works Linuxcnc should work.
  • langdons
  • langdons
14 May 2025 14:16
Python programming is generally something of a band-aid programmed free-for-all.
Java has conventions and structure.
Python is just "whatever floats your goat".
  • langdons
  • langdons
14 May 2025 14:14
  • langdons
  • langdons
14 May 2025 14:10
See if you can buy a used MESA board from someone in Austrailia.
Or an Aisian knockoff.
Even in Canada, shipping from China/Thailand is often cheaper than shipping from USA.
(except digi-key)
  • RotarySMP
  • RotarySMP's Avatar
14 May 2025 14:06
Replied by RotarySMP on topic Bridgeport VMC760 retrofit
Category: Milling Machines
Yes, the RS-422 is their smart serial connection between the 7i97T FPGA main board and 7i73 and 7i84 daughter boards. Since there is only one RS-422 configured standard on the 7i97T (on TB4), you can only connect one of those two cards, until you reflash the 7i97T to reconfigure some of the pins of the P2 expansion port to provide a second RS-422.
Glad you are enjoying my videos. It is fun to dick around with this stuff :)
Cheers,
Mark
  • langdons
  • langdons
14 May 2025 14:02
Replied by langdons on topic LinuxCNC S-Curve Accelerations
Open source is supposed to allow people to work together; but people don't work together, they insist on doing their own thing.
How does badly recoding chmod help anyone?
Displaying 4171 - 4185 out of 24438 results.
Time to create page: 0.229 seconds
