  • PCW
  • PCW's Avatar
03 May 2025 14:40 - 03 May 2025 14:48
mechanical limits switches wiring for 7i96s MESA
If you use NC limit switch contacts and sinking inputs, wiring would be:
7I96S input common (TB3 pin 12) = GND (24V common)
+24V --> Limit-Switch C --> Limit-Switch NC --> 7I96S Input (TB3 pin 1 through 11)
In hal, the input must be inverted.
You can use 5V instead of 24V but it's not as reliable long term with mechanical switches
  • Roger S
  • Roger S
03 May 2025 14:35
Replied by Roger S on topic Using POSIX realtime
Category: EtherCAT
The following results:
- ip a returns the result that the adapter is running without errors:
enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP
- the permissions are also correct:
crwxrwxrwx 1 root root 238, 0  3. Mai 16:22 /dev/EtherCAT0
nevertheless the link is DOWN and I cannot start a test configuration
Debug file information:
Note: Using POSIX realtime
Failed to reserve master: No such device
LCEC: requesting master 0 (index 0) failed
LCEC: failure, clearing config
LCEC: exiting
LCEC: returning -EINVAL
lcec: rtapi_app_main: Invalid argument (-22)
./axis_mm.hal:3: waitpid failed /usr/bin/rtapi_app lcec
./axis_mm.hal:3: /usr/bin/rtapi_app exited without becoming ready
./axis_mm.hal:3: insmod for lcec failed, returned -1
2306
Stopping realtime threads
Unloading hal components
  • PCW
  • PCW's Avatar
03 May 2025 14:33
Drive enbale active low - simple but yet it won´t do
OK, that's opposite of what the 7I77 enables do (they are on when enabled)
Probably easiest is to add a external relay, driven by a field I/O output
and wire the NC relay contacts to all drive enables.
  • xlordofpainx
  • xlordofpainx
03 May 2025 13:29 - 03 May 2025 14:33
hey i am having some trouble wiring switches to the board here is what I tried:
I am using pnc conf
I read that the inputs are opticallyisolated so I can put a lot of voltage on the input pins (haven't tried yet only 5v)
the mechanical switchers have NC NO and C
I tried connecting NC to 5V and V to pin1 doesn't stop during homing
inverting just began the turn on with an error about the switch limit
I tried connecting NC to GND and V to pin1 doesn't stop during homing
I tried connecting NO to 5V and V to pin1 doesn't stop during homing
I tried connecting NO to GNFand V to pin1 doesn't stop during homing
FInally i tried attaching NC to 5V, NO to GND and C to pin one and it worked but then the mesa card would get restarted ( apparently its shorting something when i hold the button too long
i saw some other people connecting NC to 24V and then to pin 1, but it should work with 5V as well and it doesn't. i tried pin 0 as well in case the pin was not working.
i am getting the 5V and gnd from the STEP 3 pins.
I am very interested what exactly is it that I am doing wrong.
THanks
  • SanzuiWorks
  • SanzuiWorks's Avatar
03 May 2025 13:16 - 09 May 2025 16:28
Replied by SanzuiWorks on topic Manual Toolchange + Abs Z Probe (QtDragon)
Category: Qtvcp
I created a diagram so that the offset value can be visually confirmed.
  • Groovecooper1
  • Groovecooper1's Avatar
03 May 2025 12:56 - 03 May 2025 13:48
Replied by Groovecooper1 on topic Need help with Linux 2.5 on a CNC lathe
Yes, the machine is on, it jogs and the icon for homing is grayed out, when I get to my shop next week I will upload pictures. Absolutely appreciate you guys are really awesome. Super helpful and responsive! Much appreciated! If there’s anyone in this forum that is for hire, let’s talk.
  • Rocky
  • Rocky
03 May 2025 12:30
Replied by Rocky on topic Hi everyone
Hi everyone
Got it to home but had to change the end stops to just home not home/min, I'll post up my files once I drag the pc upstairs to give it internet, I'm sure there is lots to still fix and do
  • SanzuiWorks
03 May 2025 12:05 - 16 May 2025 07:02
Manual Toolchange + Abs Z Probe (QtDragon) was created by SanzuiWorks
Category: Qtvcp
I'd like to share a structured and slightly modified version of `qt_auto_probe_tool.ngc` I'm using on my self-built 3-axis CNC with LinuxCNC 2.9.3 and the QtDragon GUI.
### ? My Goals:
- Separate tool length offset from work coordinate systems (WCS)
- Make the tool table intuitive and readable
- Ensure safe and efficient probing using machine coordinates
#### 1. Set the Probe Top:
I defined the probe top using the tip of the spindle body (with no tool/collet) as a consistent mechanical reference.
- For example, if the empty spindle is lowered to Z = -120 (machine coordinates), I input `-120` as PROBE HT in the QtDragon Probe tab.(I know this is not the intended use.)
- I do not use BLOCK HT at all.
#### 2. Define Work Coordinates:
Once a tool is mounted (e.g., Tool #1 with 30mm protrusion), I:
- Add `T1 Z30` into the tool table
- Set up the G54 (or other WCS) normally
This way, the tool length stored in the table is actual physical protrusion and independent from any WCS — much more intuitive for manual tool changers.
Use G43 to apply the offset.
- Tool table values are stable and logical (they represent actual tool lengths).
- Easy to estimate and input values for new tools before probing.
- Tool probing uses machine coordinates, so:
  - Probe start position can be calculated from tool length
  - No dependency on current WCS
  - Safer: if tool table Z is negative by mistake, start offset is clamped to zero
- Multi-WCS workflows (G54, G55...) work seamlessly — no need to re-probe per WCS
- Tool probing is simpler and can be single-pass since start is close
Thanks,
SanzuiWorks
  • andypugh
  • andypugh's Avatar
03 May 2025 11:30
  • dannym
  • dannym
03 May 2025 11:20
Resetting A-axis was created by dannym
Resetting A-axis
Category: G&M Codes
I did some manual G-code to use a 4th axis rotary basically like a lathe.  The A axis doesn't have a homing switch.  It advances a specified number of turns as the X and Y does its thing.
Part gets changed out, repeat.
What's the correct G-code to reset the A axis?  Numerically, it's spooled up like 1000 turns in one direction.  Moves aren't relative and I don't need the thing to unspool 1000 turns to get back to the absolute A-axis value the next G-code run will start at.
  • andypugh
  • andypugh's Avatar
03 May 2025 10:20
Replied by andypugh on topic Need help with Linux 2.5 on a CNC lathe
So, does it not respond to the home button? Is the home button greyed out?
Does it jog? Are the motors locked or free?
  • andypugh
  • andypugh's Avatar
03 May 2025 10:13 - 06 May 2025 11:28
Is there a bug in the carousel component or am I doing it wrong ATC Denford
I don't think that counts mode _can_ work with a Boxford style of toolchanger as the number of steps lost when the motor stalls against the endstop is unknown.
It could be modified to work, but it might be easier to start from scratch as a single-sensor position-mode stepgen changer wasn't really considered when the component was written.
You could even consider doing all the control in the G-code subroutine:
1) Scale the stepgen so that a position shift of 1 is one pocket.
2) Connect motion.analog-in-00 to the stepgen.2.position-fb
3) Connect motion.analog-out-01 to the stepgen.2.posiiton-cmd
4) Connect the home sensor to motion.digital-in-02
(Actually, you can use any numberered analog/digital IO, you would probably use in, out and digital 00 in practice, but I made them different for clarity)
toolchange.ngc:
O<toolchange> SUB
O100 IF [#<_carousel_homed> EQ 0] ; Do we need to home?
M66 E0 L0 ; read current stepgen pos into #5399
M68 E1 Q[10 + #5399] ; set the carousel in motion, by more than the number of pockets past the current pos
M66 P2 L1 Q20 ; Wait for the home pin
O200 IF [#5399 LT 0]
(abort, home timeout)
O200 ENDIF ; end of timeout check
M66 E0 L0 ; read home pin pos into #5399
M68 E1 Q[#5399] ; goto home pin, might need an offset here
G4 P5 ; wait for stop
#<_carousel_homed> = 1 ; mark homing as done
O100 ENDIF ; end of homing
(Normal toolchange without homing)
#1 = #<_selected+pocket> - #<_current_pocket> ; calculate move distance
O300 IF [#1 LT 0] if moving to a lower number
#1 = [#1 + 8] ; for an 8-pocket changer
O300 ENDIF
M68 E1 Q[#1 + #5399] ; move the requisite number of pockets
G4 P10 ; Wait (should really wait-on-input on a stepgen-in-position signal)
M68 E1 Q[#1 + #5399 - 1] ; move back against the stop
G4 P2 ; wait to stall against the stop
M6 T<_selected_tool> G43 ; change the tool, set offsets
O<toolchange> ENDSUB ; Done
  • MakeMe12
  • MakeMe12
03 May 2025 09:01
Replied by MakeMe12 on topic Damaged 7i76
Damaged 7i76
Category: Driver Boards
I have also overpowered the 5v side of a 7i76 board for a second or so. I saw smoke at S1 and driver chips etc.
Freight is too expensive to post back and forth to USA for repairs. ( In Australia)
Can you make up a component set that would normally be damaged? I'll buy another board and the component set...... to try to recover this board for my next project.
  • Hakan
  • Hakan
03 May 2025 07:12
Replied by Hakan on topic Using POSIX realtime
Category: EtherCAT
Looks like your network adapter is not upped correctly. The master can't access ethernet.
Check "ip a", it should say UP for the adapter but I guess it won't.
Follow one of the standard debian guides to bring it up, will involve the /etc/network/interfaces file.
Can be a permission problem, check "ls  -l /dev/EtherCAT0" should say crwxrwxrwx
Try with "sudo service ethercat restart"
Also check "sudo dmesg" the last say 50 lines for anything that can help.
  • Hakan
  • Hakan
03 May 2025 07:04
Replied by Hakan on topic General Questions about using ethercat
Category: EtherCAT
Good to hear, wouldn't surprise me if you change D1 and D2 to X and Z.
That config should be enough to move the axis. Try it.
Then you need to add limit switches and other switches if you have that, spindle control, pendant or gamepad and so on.
Now when linuxcnc is up and running you can easily inspect pins' values using halshow.
The drive and motors are closed-loop I guess, then you will see actual-position change when you rotate the motor shaft, even by just a little if the motors are active.
Displaying 5476 - 5490 out of 24183 results.
Time to create page: 0.251 seconds
