  • Dudelbert
  • Dudelbert
16 Dec 2025 10:14 - 16 Dec 2025 10:17
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
I want to give a quick update on my work, the belt for the Spindle encoder has been replaced.
Two belts have been installed same as RotrySMP has done. But I thought about this and think it is les helpful as I originally thought.
As this belt will likely “Dye” of old age, in that case the other one will also be brittle due to age already, but now it is in there and it does not hurt anything.
With the Spindle in good shape now I could test the full machine. Everything worked fine. Interestingly most of the “extended” machine was not even conked to the controller but controlled by directly wired relays, even with a notable amount of safety by locking functions out.
This includes the full tool changer, variator and back gear.
At this point I noted down some of it and started tearing the electronics and pneumatic bay down.
I also dismounted and shortened the electronics box.Their seems to be space for everything in the former pneumatics bay. If that is the case I will use the electronics box for tool holders, chucks and that stuff, if I need more space I will use that space as needed.
Also I did make up a bit of a control panel in CAD and made a cardboard variant.
I think that is it so far.
Martin
  • PCW
  • PCW's Avatar
16 Dec 2025 09:52
I accidentally flashed the 7I98 BIT file onto a 7I92 board. Now the 7I92 can no
Category: Driver Boards
If you accidentally flashed a Mesa 7I92 with 7I98 firmware you are somewhat up the well known creek.
 The reason is that the Ethernet <--> FPGA connections are different between the 7I92 and 7I98 so you will lose
communications.
There are at least  two possible ways to recover:
1. JTAG (needs a JTAG programmer and Xilinx or generic JTAG software)
2. Trick the card into loading the fallback configuration
You do this by briefly corrupting the configuration data stream just at power up,
Typically by say shorting the DO pin of the flash EEPROM to ground
just at power up (causing a CRC error and loading of the fallback configuration).
If this succeeds, the fallback configuration will blink the init LED so you can tell
that you have loaded the fallback configuration. Once the fallback configuration
has been loaded, you can use mesaflash to re-write a valid user configuration.
16 Dec 2025 09:12
  • Ul
  • Ul
16 Dec 2025 09:04 - 16 Dec 2025 09:06
Then it's a 7i98, so change 7i92 to 7i98 in mesaflash. Or use instead --device ethernet
  • feng
  • feng
16 Dec 2025 07:13
I accidentally flashed the 7I98 BIT file onto a 7I92 board. Now the 7I92 can no longer communicate with the host. How can I recover it?
  • vibram
  • vibram
16 Dec 2025 07:12
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
This is always the issue when you know nothing and you use AI
Thank you i will try to start again from your repo and adapt the SPI. However, I also tried somehardware modification on the board, not sure it still works correctly.
  • Hakan
  • Hakan
16 Dec 2025 06:24
Category: EtherCAT
I connected up the hardware in the same way as your system. It didn't want to go to PREOP.
It seems you have been editing a lot, at least some, in lib/soes and I would say that's a big no-no. Leave that as is.
I restored lib/soes from E7000, fixed settings for SPI, removed all SPI from main.cpp, modified loop() and the card is now up and running in PREOP.
You shouldn't need to make a lot of editing in lib/soes, only to get SPI running and I think it was fine the way you did it.
All editing for SDOs PDOs etc are done through the EEPROM_generator, no manual editing is needed.
  • unknown
  • unknown
16 Dec 2025 05:43
  • unknown
  • unknown
16 Dec 2025 05:39
Advantech PCM 9362 freze when opening latency-test
That would really require delving into the data sheets regarding the gpios, and how and if the Linuxcnc kernel exposed them, they might be available via sysfs. I have doubts about whether they would be realtime capable.
May libgpiod, but not at all sure.
  • unknown
  • unknown
16 Dec 2025 05:35
I think someone may have raised suspicions many many months ago. But my memory isn't what is used........oh ok there's a monkey
  • sin-do-re
  • sin-do-re
16 Dec 2025 05:29
Replied by sin-do-re on topic 7i96s + 7i78
7i96s + 7i78
Guys
I got the cable! just found one from when i got the 7i78 previously and never used it.
Thanks a lot for the availability to ship one out :D
How about the bit file, where can i find it? do i need any special firmware editing or something?
thanks
16 Dec 2025 05:25
Use this ISO
www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
Boot the PC from it and run the tests in Live mode, meaning do not install, see if it hangs.
Literally what I said in my post before it "mysteriously" disappeared into thin air.
(no offense to you)
Sigh...
1. You literally repeated my already existing post
2. You linked the wrong ISO location for the same ISO
That can and will absolutely raise suspicion.
  • Masiwood123
  • Masiwood123's Avatar
16 Dec 2025 05:22
Replied by Masiwood123 on topic Physical buttons to 7i96s+7i77
Category: HAL
This is the only thing that works smoothly for me.
# --- FEED SPEED RAPID POTENTIOMETER'S ---
#BIT direct value
setp halui.spindle.0.override.direct-value 1
setp halui.rapid-override.direct-value 1
setp halui.feed-override.direct-value 1
# SCALE
setp halui.spindle.0.override.scale 0.01
setp halui.rapid-override.scale 0.01
setp halui.feed-override.scale 0.01
# scalemax
setp hm2_7i96s.0.7i77.0.0.analogin1-scalemax 100 # spindle
setp hm2_7i96s.0.7i77.0.0.analogin2-scalemax 100 # rapid
setp hm2_7i96s.0.7i77.0.0.analogin0-scalemax 200 # feed
loadrt conv_float_s32 count=2
addf conv-float-s32.0 servo-thread
addf conv-float-s32.1 servo-thread
addf conv-float-s32.2 servo-thread
net analogin1 conv-float-s32.0.in <= hm2_7i96s.0.7i77.0.0.analogin1
net analogin2 conv-float-s32.1.in <= hm2_7i96s.0.7i77.0.0.analogin2
net analogin0 conv-float-s32.2.in <= hm2_7i96s.0.7i77.0.0.analogin0
net analogout0 conv-float-s32.0.out => halui.spindle.0.override.counts
net analogout1 conv-float-s32.1.out => halui.rapid-override.counts
net analogout2 conv-float-s32.2.out => halui.feed-override.counts
File Name: betabeta_2...2-16.zip
File Size:22 KB
  • Muzzer
  • Muzzer
16 Dec 2025 04:17
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
Haha no problem! Yes, I know I still have a lot to learn but I think I'm getting there in my own time.
I won't bother with pics of floors, roofs or pipes but here's some metal I did earlier in 2019. I look forward to hearing where I'm going wrong!
Like a lot of people on here, I also have a day job - in my case power electronics product development that requires a fair bit of travel to Korea and Japan, in addition to time in the office each week away from home.
  • zoeper
  • zoeper
16 Dec 2025 03:26
Replied by zoeper on topic Avon 3000 Mill retrofit
Category: Milling Machines
Valuable advice NWE, I will keep this in mind going forward.
Displaying 10066 - 10080 out of 11225 results.
Time to create page: 1.614 seconds
