  • unknown
  • unknown
23 Nov 2025 16:07
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
The issue is that you need gvfs-fuse & gvfs-backends, and to setup samba as well.
  • aDm1N
  • aDm1N's Avatar
23 Nov 2025 16:06
EtherCAT + CiA402 Servo: OP state reached, but axis won’t move (only Following E
Since a servo drive is generally very well suited for use as a C-axis — because of its precise positioning capabilities, torque at low speed and built-in encoder feedback — it would be highly beneficial to find a reliable solution for the remaining PV → CSP switching behaviour.If this last issue can be solved in a practical and reproducible way, the same hardware could be used both as a high-speed spindle and as a fully functional C-axis, which would make this setup useful for many other users as well.Any insights or suggestions that could help move in this direction are therefore very welcome.
  • PCW
  • PCW's Avatar
23 Nov 2025 15:28
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
Category: Driver Boards
Yes, the lspci  list shows the only Ethernet is a Intel LM217
5 ms on Intel most likely means some power management is still enabled
maybe EEE or PCIE
Is this running on a laptop?
23 Nov 2025 14:44
Replied by tommylight on topic QtPlasmaC make the top row slightly taller?
Category: Plasmac
I have to agree, to thin even for big 24" monitors, and also add an arrow pointing down to show those are menus.
23 Nov 2025 14:42
Replied by tommylight on topic Vevor 3040 USB
Vevor 3040 USB
With that board the only option is this:
forum.linuxcnc.org/30-cnc-machines/45079...only-what-now#234532
My advice, buy 3 or 4 of new simple TB6600 drives (the smaller ones do not use the TB6600 but a much better chip, although less powerful) and wire directly to a cut down parallel port cable.
Or get a BOB, makes wiring easier and do not cost much, but some can limit step speed somewhat.
  • garulus
  • garulus
23 Nov 2025 14:06 - 23 Nov 2025 15:36
Gmoccapy Raspberry Pi 4/5 OS based on Debian Trixie Tool Table Error?
Category: Gmoccapy
Zdavim!
Doesn't seem so(I don't know). Switched from Raspberry PI to PC and Debian 12 Bookworm and I can edit tool offsets no problem.
Edit: Just tried previous version rpi-5-debian-bookworm-6.12.11-arm64-ext4-2025-01-27-0140.img.xz, and editing tools works!
  • snowgoer540
  • snowgoer540's Avatar
23 Nov 2025 13:59
Replied by snowgoer540 on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
I still stand by my removed comment.
And I'm very sorry to say but you admins are weak and spineless to allow this buffoon to carry on the way he does.
It's a shame the CoC doesn't cover giving advice to members that is completely useless, a waste of time and potentially to the point of causing harm.
But no, the main point is not to hurt anyone feelings or to cause offense.
Who is going to have the intensal fortitude and read Langdon's the riot act. I tried in the beginning to guide him in the right direction but he would appear not to care.
You admins need to take action, I'm sick to effing death in having to make his posts an issue in the hope something will be done to rectify his behaviour. Until then I will keep raising this issue, or you can just ban me. I don't care much, Ive lost faith in every single one on the Admins on this site. You aren't doing a single thing to protect other forum members, especially new ones from his nonsense. At this juncture you all disgust me.
I can only speak for myself, but I just recognize him for the bored high school student that he is. I feel bad for new people but imagine they quickly realize his replies are virtually useless and very likely the regurgitation of misguided ChatGPT responses.
I stand by my previous advice to not feed the under-bridge dwelling creatures, and ignore him until he moves on, gets himself banned, or discovers better things to do with his time. But it’s a bit pointless for us to block him as he, like you, will probably just make a new username and start over. Trust me, it’s been discussed.
You have something he does not, which is the ability to contribute meaningfully to this community (I remember the Beaglebrainz ISO’s very well). So I ask you to just ignore him, let his mindless comments stand for themselves, and don’t let it affect your integrity.
  • vre
  • vre
23 Nov 2025 13:52 - 23 Nov 2025 13:54
Replied by vre on topic Injection molding
Injection molding
Category: CNC Machines
I think i will use something like you but with better mcu like esp32-s3 or an sbc like rpi5(only for the better user interface)
  • kor
  • kor
23 Nov 2025 13:45
Replied by kor on topic First Tests with ethercat
Category: EtherCAT
That was a stupid mistake. geany did color it like I expected. and I am using a small monitor.
just for reference if someone reads this thread later here are my working files:
ethercat.hal:
 # EtherCat
loadusr -W lcec_conf /home/bf20/linuxcnc/configs/sim.axis/ethercat-conf.xml
loadrt lcec
addf lcec.read-all servo-thread
addf lcec.write-all servo-thread
net mon halui.machine.on lcec.0.EL1014.din-2
net moff halui.machine.off lcec.0.EL1014.din-3
ethercat-conf.xml:
<masters>
    <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
        <slave idx="0" type="EK1100" name="EK1100"/>
        <slave idx="1" type="EL1014" name="EL1014"/>
        <slave idx="2" type="EL2004" name="EL2004"/>
        <slave idx="3" type="EL3102" name="EL3102"/>
    </master>
</masters>
  • abs32
  • abs32
23 Nov 2025 13:42 - 23 Nov 2025 14:16
How to fix "Queue is not empty after probing"
So far, I’ve taken turns backporting to version 2.9.4 and running matrixkins + Probe tripped during non-probe move
The first attempt to use the AkkiSan forum.linuxcnc.org/38-general-linuxcnc-q...bing?start=10#333578 sentence
it showed a strange result - the signal #5070=1 and ... stopped appearing.
If there are specific proposals for correction github.com/LinuxCNC/linuxcnc/blob/master...4ngc/rs274ngc_pre.cc
I'm ready to test them in practice
I was not too lazy to download the source code of different versions of the program. In my (previously) main 2.8.4 this error never appeared, the records were 59,000 continuous measurement points. So the file src/emc/rs274ngc/rs274ngc_pre.cc before version 2.9.7 has not undergone any significant changes. The block of code we were interested in remained unchanged
    if (settings->probe_flag) {
    CHKS((GET_EXTERNAL_QUEUE_EMPTY() == 0),
         NCE_QUEUE_IS_NOT_EMPTY_AFTER_PROBING);
    set_probe_data(&_setup);
    settings->probe_flag = false;
  if (_setup.probe_flag) {
    _setup.probe_flag = false;
  • aDm1N
  • aDm1N's Avatar
23 Nov 2025 13:33 - 23 Nov 2025 13:38
Thanks for the hint regarding opmode-display — I verified that first.Here is the current, confirmed state of M19 and PV↔CSP mode switching:
1. M19 (verified)M19 currently does not produce any motion.
The orient component runs internally, but the LC20E does not react to the orientation command.
No errors are generated — simply no movement.This is the confirmed and reproducible behaviour.
(No assumptions about the cause.)
2. PV ↔ CSP mode switching (verified)The drive does switch modes correctly, which is confirmed via:
lcec.0.D1.opmode-display
Switching between spindle mode (PV) and axis mode (CSP) is possible.However, the switching reliability depends on the drive state after M5.
3. Behaviour after M5 (verified)After stopping the spindle:
  • actual-position
    continues to drift for some time
  • pos_fb
    and
    axis.c.eoffset
    follow this drift
  • zero-speed becomes TRUE early, but the position is still changing
  • CSP switching during this drift often causes a drive fault
This post-M5 settling is the core issue.However, switching is possible if you wait until the drift has fully settled.Once the position stops changing, CSP can be enabled without a fault.So the mode switching itself works — the problem is only the time it takes for the LC20E to reach a stable state.
4. Safety logic (current state)I currently use safety conditions that require:
  • zero-speed = TRUE
  • no position change during a short window
With these checks, switching is reliable as soon as the drift has stopped.If the safety thresholds are made more permissive (larger allowed window),
switching becomes possible earlier, even before the drift is fully gone.Therefore the switching problem is not fundamental —
it is tied to how strict the safety logic is while
actual-position
is still changing.
5. axis.c.eoffset (verified)C-axis following via external offset works as intended:
actual-position → degrees → eoffset
This avoids position jumps when switching to CSP.
The only difficulty is that eoffset must follow the drift until the drive settles.
6. Next stepsTo improve switching reliability, I am looking at:
  • refining the “stable position” detection
  • adjusting the time window or allowed variation
  • possibly applying a controlled zero-velocity ramp before switching
  • or any CiA402 hints to get the LC20E into a stable hold state sooner
Summary (facts only)
  • M19: no movement from the drive (verified)
  • Mode switching: works and the drive changes operation modes correctly
  • Switching is reliable once the post-M5 drift has stopped
  • Stricter switching rules block early switching
  • More permissive switching rules allow earlier switching
  • opmode-display confirms correct mode transitions
  • The remaining issue is the LC20E’s long settling period after stopping the spindle
Any hints or experience with LC20E behaviour after M5 or with CiA402 PV→CSP transitions would be very helpful.
  • rodw
  • rodw's Avatar
23 Nov 2025 13:30
Replied by rodw on topic Chinese Mesa 7I92 from aliexpress NEW
Are you sure its an intel NIC? Its unusual to see an INTEL NIC with a enpxxx name.
If you have 2 NICs are you configuring the right one?
  • imitheo
  • imitheo
23 Nov 2025 13:30
Replied by imitheo on topic Chinese Mesa 7I92 from aliexpress NEW
Hello can you share your e-mail, interested in knowing more about your adventure with this board.
  • andrax
  • andrax's Avatar
23 Nov 2025 13:28
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
OK, thank you. If I calculate 131,072 / 50 / 6 = 436.906, should I enter this value?
  • rodw
  • rodw's Avatar
23 Nov 2025 13:23
Replied by rodw on topic LinuxCNC Hardware Survey
Egerobotics components are based on EtherCAT. Is it possible to add such components to the LinuxCNC distribution? I know there are some licensing issues with EtherCAT. Or not?
Licencing Conditions pervents us from hosting ethercat stuff. The correct course of action ewould be to create pull requests against this rep,
github.com/linuxcnc-ethercat
the Ethercat master is configured as a dependency
The driver and devices here are synced to the iGh ethercat apt repository so that ethercat users can receive updated linuxcnc specific ethercat drivers with a simple apt upgrade
Displaying 10951 - 10965 out of 11229 results.
Time to create page: 3.044 seconds
