  • Hakan
  • Hakan
14 Nov 2025 10:47 - 14 Nov 2025 11:22
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
I don't know much about cos sin. The whole processor is available for you to do all sorts of processing.
The ethercat part is the easy one I would say.
Every cycle you calculate a new encoder value, set a pdo variable and the soes library does the rest.
Edit. But I checked quickly. So you need to take in two analogue signals and calculate the phase angle.
Absolutely doable, could be a nice application.
Start a project thread and I'll give you a hand with the ethercat stuff.
Edit 2. The ADCs on STM32F4 are only 12-bit, you may need 16-bit ADC for this. Another processor?
External 16-bit ADC unit?
Edit 3. IC-NV instead of ADCs of course.
  • Jensner
  • Jensner
14 Nov 2025 10:43 - 14 Nov 2025 10:59
"error finishing read" with Mesa 7i92T on fresh install
Category: Driver Boards
I also did a fresh installation on a DELL Optiplex 3060 Micro PC (RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller)
Everything incl. IRQ-Optimizing (Latency) works fine, but i also run into this error "Error finishing read" with my MESA 7i96s.
--- 10.10.10.10 ping statistics --- 46085 packets transmitted, 46085 received, 0% packet loss, time 46101ms rtt min/avg/max/mdev = 0.050/0.062/[color=#e74c3c]3.014[/color]/0.039 ms
In my old installation (at this PC) i run the 3.6.0 rt11 Kernel and did not have this problems, so i think, last time i updated it for the same reason. Sadly i don`t know how to do this update again.
Is there an easy way only updating the kernel?
(Sorry but I`m not in the Linux-Space, so its a little hard for me)
Thanks a lot
Jens
  • viacolvento
  • viacolvento
14 Nov 2025 10:39
Funzioni pausa e resume con pulsanti esterni.
Category: HAL
Buongiorno, sono un nuovo iscritto di appena 78 anni, appassionato di elettronica e meccanica.
Ho bisogno di inserire le funzioni Pausa e Resume per poter fermare gli assi x e y mentre l'asse z si trova in un certo punto, e riprendere il loro movimento quando l'asse z raggiunge il punto successivo (tutto controllato da fotoaccoppiatori). so che è possibile, ma purtroppo la mia competenza nel linguaggio di Linuxcnc è limitata.
Grazie.
  • billykid
  • billykid's Avatar
14 Nov 2025 09:13 - 14 Nov 2025 09:47
Replied by billykid on topic ECAM 5 POST Processors
Category: Post Processors
I use ecam, as soon as I can I'll send you mine, it works well.
  • vibram
  • vibram
14 Nov 2025 08:27
Replied by vibram on topic AX58100
AX58100
Category: EtherCAT
Hello,
Thank you for your reply
Ideally, I would like to integrate the project from PedPex which is a COS SIN converter (with IC-NV chip) for heidenhain glass scale directly as an ethercat module. It would receive COS SIN signal, convert it to quadrature, read by the STM32 then sent to Ethercat.
But this is a little bit out of my league knowledge wise, even if you did most of the job regarding ethercat and Pedpex most of the job regarding COS SIN conversion
  • zoeper
  • zoeper
14 Nov 2025 07:38
Replied by zoeper on topic Avon 3000 Mill retrofit
Category: Milling Machines
I am currently running LINUXCNC - 2.9.7
6.1.0-30-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.124-1 (2025-01-12) x86_64 GNU/Linux
This was upgraded, re-installed and built from source after my initial installation. I installed Mint on another drive, but the OS took forever to boot, and just felt sluggish.
My main aim is to get something functional and stable going ASAP. I can always make it nice later.
  • rodw
  • rodw's Avatar
14 Nov 2025 07:11
LinuxCNC + Mesa 7i92TF + Gecko G540. Docs are useless. Help, Please!
Category: PnCConf Wizard
Actually when you know where to look, the documentation runs to hundreds of not thousands  of pages.
setting up a gantry machine requires joint axes and is covered in the  homing docs. linuxcnc.org/docs/stable/html/config/ini-homing.html
You usually need to read that link about 10 times before it makes sense.
Briefly you need a home switch on each joint (eg a joint is a motor). When set up right with negative  home_sequence, the first side of the gantry stops and waits for the other side to catch up before moving in unison. Gantry Squareness is adjusted by setting the home_offset in the ini file
14 Nov 2025 05:01
Yes, you do need switches for each joint for tandem axis to work properly and be able to square the gantry anytime the machine homes.
If you do not have switches, you can just wire both Y drives to the same output on Mesa and make a new simple XYZ config.
BTW, you can make as many configs as you like, test, experiment, try things out, have a blast...
And feel free to ask as much as you like, you are always welcomed.
  • Route 66 Scott
  • Route 66 Scott
14 Nov 2025 04:31
The machine does not currently have limit switches. I have the limit switches commented out.
I recently rebuilt the machine from the ground up. As the software is an upgrade, I am trying to get it working in its most basic form before adding limit switches, a touch plate, a probe, and a tool changer.
Do I have to have hardware limit switches set up in order to get the gantry to work correctly?
Apologies if that is a dumb question. I have found the documentation incredibly lacking, which is why I’m here on this forum.
14 Nov 2025 03:39
Replied by tommylight on topic Why is there no BSDCNC?
Do you want the OS to mount a drive when plugged in or do you want to mount & umount the drive manually ?
Reminds me, i have disabled caching for USB devices as for the life of me i can not find a reason for it to exist, and any internet reasoning that it is safer = boo fakin hoo!!! How the hell is it safer when you get notified the copying is done while the coping is still ongoing in the background and you yank out the USB ending up with corrupted files. And the copy time is always wrong.
Not a huge issue with 8 or 16GB of RAM, but an absurdly annoying thing with 96GB of RAM and copying 10 Linux ISO's at once.
14 Nov 2025 03:30
Replied by tommylight on topic M03 Sub Routine File Location
Category: G&M Codes
Right now the machine fires the torch using a regular output pin, which works fine when everything is going perfectly, but when a limit is triggered or the E-stop is pressed, it doesn't quite understand that it needs to disable the torch as well.
Have not tested QtPlasmaC in quite some time, but for sure it did disable/shut off the torch on any of those, and also on program stop and program pause and when hitting ESC.
Also it would not turn on until F9 is pressed or an M3 is issued from MDI or gcode.
That is basic plasma behavior, so i doubt something was changed there.
14 Nov 2025 03:26
See the right side of PCW's screenshot, did you choose the pin/home/limit switch for Y2 axis?
More importantly, does the machine have a separate switch for each joint of the Y axis?
  • Route 66 Scott
  • Route 66 Scott
14 Nov 2025 02:26
Thank you.
This essentially gives me the HAL I created by hand. This does not bind the two Y axis motors together. Launching LinuxCNC with this HAL still shows me the 4 joints, until I home the Y axis where it sits, which is not where I need it to be homed.
I pored over the HAL and INI files created by PnCConf using your settings multiple times, and cannot see what I am doing wrong. There seems to be no difference between what it generated by selecting Y2 Tandem StepGen, and my manual HAL where I simply copied the Y axis settings, pasted them in, and changed every instance of Y to Y2, and 01 to 02.
  • Quail
  • Quail's Avatar
14 Nov 2025 01:47
Replied by Quail on topic M03 Sub Routine File Location
Category: G&M Codes
I may not be asking the right question. Is there a way to ensure that when the estop is pressed or a limit switch is triggered, to tell the torch to come off and not come back on?
I thought maybe by editing the M3 g-code, I could get it to work for my machine and also get the estop and limits to turn off the torch.
Is there any way to link the output pin 00 to the estop and limits, in such a way that it wont turn back on even when the machine is reset, and stay off until it gets a new command to turn on?
My next idea is to make my own M code that has my needs in it, but i feel that i will still run into the same issues where the estop either doesnt turn off the torch, or if it does, the machine "remembers" it was firing and immediately arc.
  • unknown
  • unknown
14 Nov 2025 01:35
Replied by unknown on topic 7i92 cnc motion controller from aliexpress?
One thing to look out for in Mesa's design of the 7i92 fet bus switches were used for translation between 3.3 to 5v. I think I can recall PCW saying that they were never intended to drive any loads directly but through at the least a buffer or more likely through a breakout board.
Another thing is, if the vendor has changed any pin assignments and have not provided a ucf file the only way to find out pin assignments would be via JTAG, the easier method of via direct probing of pins, which isn't a lot of fun with the pin spacing of the FPGA. Not knowing the in assignments would make modifying the firmware somewhat difficult at best.
So there could be some gotchas for new players.
Displaying 11101 - 11115 out of 12787 results.
Time to create page: 3.151 seconds
