  • Jensner
  • Jensner
12 Nov 2025 13:33
Nach Neuinstallation upgrade auf Kernel-Release 6.3.0-rt11-linuxcnc
Category: Deutsch
Hi Andy,
many thanks for your support.
What do you think would be the best / cleanest way?
Update or new installation with the ISO?
By the way, for my DELL Optiplex 3060 this would be the "LinuxCNC 2.9.4 Debian 12 Bookworm PREEMPT-RT ISO" ?
Best regards
Jens
  • KlausB
  • KlausB
12 Nov 2025 13:33
Replied by KlausB on topic z_level_compensation again
Hello,
Thank You for reading my post.Yes - the installation was on a formatted/clean HDD and the ISO-Image was OK. The only software I additionally use on the Machine is FreeCAD (as an App-image) to generate the g-code for my projects.
I attached a zip-file with my complete configuration.
My cnc is simple, so I did the following adjustments:
- I use a script for dynamic tool measurement. So I can use FreeCAD's g-code with different tools in a single project.
- I use a delay after starting the spindle
- I use a debounce for the probe
You will find these changes in the ini-file and hal-files. These changes does not affect the described Issue.
I’m afraid my post is in the wrong category. I should have chosen “qcvcp.” Because problem belongs to the display category.
Is it possible/necessary to change the category?
Thank you for your help
  • andypugh
  • andypugh's Avatar
12 Nov 2025 13:20
Category: Deutsch
Beide Latenzzeiten sind schrecklich.
The first image is running a realtime kernel, but the jitter is larger than is really useful. (0,4 ms in a 0,025ms thread will not work )
The second image shows a system that is not even running a realtime kernel, so the jitter is huge, 10ms or more.
You should try installing the latest realtime kernel and see if things improve after reboot.
sudo apt-cache search linux-image-rt
will give you a list of available realtime kernels. Find the newest listed and then
sudo apt-get install linux-image-rt{rest of the name}
Alternatively you could tre a fresh install from the LinuxCNC ISO image.
www.linuxcnc.org/downloads/
  • andypugh
  • andypugh's Avatar
12 Nov 2025 13:11
Replied by andypugh on topic carousel component integration
Can you describe how the setup is failing?
One thing that may be wrong is that the "width" seems very large. This is the number of encoder counts each side of the tool slot that is considered properly aligned. Normally it would be at most tens of counts.
The "scale" is meant to be the number of encoder counts between pockets. If your system has 1 servo motor revolution per pocket then your scale is probably correct, but if one servo motor revolution is one carousel revolution then you should divide the encoder full rev counts by the number of pockets.
I am aware that "carousel" has grown to the point that it ought to have a dedicated manual section. (Or maybe there should be a section on toolchangers in general. It's a big subject)
  • andypugh
  • andypugh's Avatar
12 Nov 2025 13:02
Replied by andypugh on topic HAL visualization with GraphViz
I couldn't attach the SVG files either. But I have attached bitmap reviews so that folk can understand what GraphViz is.
  • andypugh
  • andypugh's Avatar
12 Nov 2025 12:42
Replied by andypugh on topic Emco retroffit + added subspindle + bar loader
Category: Show Your Stuff
What's the GUI? It looks specialised.
  • KlausB
  • KlausB
12 Nov 2025 11:57
Replied by KlausB on topic Touch Plate
Touch Plate
Category: Qtvcp
Hello Chris,
sorry for the late reply,
After Problems with other Software I did a fresh installation a few weeks ago. With all updates the versions are: "QtDragon_hd Version 1.5 on Linuxcnc 2.9.7"
For creating g-codes I use FreeCAD as an APPImage on the same machine, so there is no other software installed on the Computer.
  • Reyes
  • Reyes
12 Nov 2025 11:22
7i92 cnc motion controller from aliexpress?
Category: Driver Boards
Any one using this card?
pleas help i bought one
New in linux cnc
  • Jensner
  • Jensner
12 Nov 2025 09:51 - 12 Nov 2025 10:45
Category: Deutsch
Hallo Leute,
nachdem ich nach ständigen Fehlermeldungen bei
sudo apt update
den Rechner nun nochmal komplett neu aufgesetzt habe, funktioniert nun alles sauber und ohne Fehlermeldungen, jedoch ist die Latency sehr viel schlechter als vorher.
Da ich von der alten und neuen Installation jeweils ein Image gezogen hatte, kann ich hier (mit etwas Zeitlichem Aufwand) schön vergleichen.
Nun ist mir im Latency Test aufgefallen, dass die alte Konfig einen aktuelleren Kernel verwendet (6.3.0), die Neuinstallation jedoch den 6.1.0. Nun wollte ich auf die Version 6.3.0 upgraden. Da ich nach wie vor kein Debian-Experte bin, Google mir hier nicht wirklich weiter hilft und ich bei diversen Versuchen über den Paketmanager Key-Errors bekomme, frage ich mal in die Runde.
Hier mal die alte Installation (Kernel 6.3.0)
Hier der frisch installierte Rechner
Vielen Dank schon mal
Gruß Jens
  • unknown
  • unknown
12 Nov 2025 05:44
Replied by unknown on topic Experimental raspios Linuxcnc Trixie images.
Category: Installing LinuxCNC
See above post to links for rc3 downloads.
Stupid things fixed:
Firefox-ESR installed
evince (pdf reader) installed
default kernel is aarch64 6.12.34+rpt-rpi-v8-rt (Raspberry Pi built RT_PREEMPT kernel)
  • nwallace
  • nwallace
12 Nov 2025 04:41
How to disable buttons in Probe Basic was created by nwallace
Category: QtPyVCP
I am trying to figure out a clean way to disable some buttons in the Probe Basic UI. We currently use an old version on our machine with a few buttons disabled. With the older version, it was as simple as adding something like "self.tool_diameter_probe_Btn.setEnabled(False)" to a properly setup custom_probebasic.py file in the config folder. On the new version installed via apt, this does not work to disable buttons. Our machine gets used by people who may or may not be trained on all aspects of it so I would like to limit some things. I am happy to go and comment out things in order to use buttons when I am working on the machine. Is there a "right" way to do this?
  • ihavenofish
  • ihavenofish
12 Nov 2025 03:48 - 12 Nov 2025 03:50
Replied by ihavenofish on topic help with ethercat and omron drives
Category: EtherCAT
Sorry, missed this.
Yes, that's where i started with the xml. I don't change much other then to make it specific to the 3 motors i have. My xml file is in my other thread here:  New ethercat / probe basic control for minimonster - Page 13 - LinuxCNC
Sadly no time to make a how too, but its on the list to go with the launch of the machine
  • unknown
  • unknown
12 Nov 2025 01:16
You didn't by chance use the new trixie image on the downloads page did you ?
  • OBi
  • OBi
12 Nov 2025 01:12
I have a newly minted Linuxcnc 2.9.7 installed on a Raspberry PI 4.
I have successfully compiled the remora.c component from cakeslob/rrw_lab
trying 'sudo halcompile --install remora-spi.c' from cakeslob/main and scottalford75 will not compile. Lots of errors.
Components/Remora-spi/rp1lib.c:94:9: error: assignment to ‘struct spi_device *’ from incompatible pointer type ‘struct spi_device **’ [-Wincompatible-pointer-types]    94 |     dev = &inst->spi_dev[spi_num];
I have also a working linuxcnc 2.9.3 that compiles remora-spi.c fine
Are there any changes in linuxcnc from version 2.9.3 to 2.9.7 that makes this happen?
I will make do with the earlier remora component...
I just wanted to inform that there is some issues
  • unknown
  • unknown
12 Nov 2025 00:56
Replied by unknown on topic [SOLVED] Backlash issues on Y-AXIS
Ok if its an os image you require I may just be able to help.
Displaying 11161 - 11175 out of 12825 results.
Time to create page: 1.441 seconds
