  • andypugh
  • andypugh's Avatar
26 Oct 2025 18:32
5-axis Isel-based machine - Logosol to LinuxCNC?
Category: CNC Machines
My thought is to write HAL components to interface LinuxCNC pins to Logosol's LDCN protocol. The servo drives run a 51.2 microsecond update rate, so 20 servo ticks is 1.024 ms.
What bit rate is that at? 115200 bps is quite quick for RS485 (though the internet suggests that 42Mb/s is possible).
At 115200bps 51µs per packet only has space for 6 bits of data, so it either must be running unusually high bit rates or not updating as fast as suggested.
  • thanks for the help
26 Oct 2025 18:26
Replied by thanks for the help on topic Manual tool change + tool lengh touch off
Thank you,
That would make sense, the G10 would populate the tool table and the G43 would assign the tool length offset.  I guess the mystery is where to add it to this ngc file?  And how did others have success with this code without those commands?   As you can tell I am really new to all this.  Attached is the sub routine I have been trying if you feel like looking at it.
File Name: tool-chang...test.txt
File Size:11 KB
  • andypugh
  • andypugh's Avatar
26 Oct 2025 18:12
Replied by andypugh on topic Manual tool change + tool lengh touch off
You may need one of the G10 variants in your macro.
linuxcnc.org/docs/stable/html/gcode/g-code.html#gcode:g10-l0
Or possibly just a G43
  • lorenzing
  • lorenzing
26 Oct 2025 18:04
Replied by lorenzing on topic Festo CMMT-ST
Festo CMMT-ST
Category: EtherCAT
Hi andypugh, jc2ktr shared his working setup, but here is mine:
[KINS]
JOINTS = 5
KINEMATICS = trivkins coordinates=XYYZZ kinstype=BOTH
26 Oct 2025 17:47
Thank you for the response,
I am using Axis gui with version 2.9.4.  I was using this format (debug,#<5081>) which yielded ######.  Upon your suggestion I tried this format (debug, 5181) which yielded the number in the var file....a big thank you for that clarification!!!!
I think my main problem is that my tool table is not updated based on my 5063 variable.  When the probe trips the switch, I see the var file up updated, it stores tripped the z value in the 5063 variable, but that number is not populated in the tool table.  As a side note, I did have to add the 5063 variable manually to the var file.
Again, thank you for you time
  • Aciera
  • Aciera's Avatar
26 Oct 2025 17:42 - 26 Oct 2025 17:44
Replied by Aciera on topic VTK based version of Vismach
Category: Show Your Stuff
It's pretty much the same. It's actually fairly straight forward once you get the hang of it but I guess that's true for everything and I must have made a couple dozen sim models by now.
ProbeBasic has machine simulation that can be setup using a yaml file (similar to what some CAM systems have) but it is quite limited compared to vismach.
  • andypugh
  • andypugh's Avatar
26 Oct 2025 17:40
Replied by andypugh on topic Festo CMMT-ST
Festo CMMT-ST
Category: EtherCAT
Your kinematics setup seems to be wrong:
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
Should be 5 joints and probably XYYZZ
  • andypugh
  • andypugh's Avatar
26 Oct 2025 17:33
Proposal RPi Linuxcnc Image Based on Raspi OS All welcome/encoraged to comment
Category: Installing LinuxCNC
Just a reminder (it's way down the list of repos now) but we did previously use pi-gen to make LinuxCNC images.
github.com/LinuxCNC/pi-gen
Bitrot has probably set in, though.
  • andypugh
  • andypugh's Avatar
26 Oct 2025 17:22
how to get rid of the probed dumping non-probe mode error?
There is a motive. My 2.8.4 has a jitter in the range of 2000. It also uses the compiled module "curve geometry" (compensation of the position of the X coordinate depending on the position of the Y coordinate). There is no such module for 2.9.
I don't think that "curve geometery" was ever a built-in LinuxCNC component. Did you install it from a comp file?
If you have the .comp file then it will also work with 2.9.x once installed, but if you don't have the source file then you may be a bit stuck.
If you have 2000ns jitter then you may be using the RTAI kernel? It is possible to run LinuxCNC 2.9.x with RTAI, but it's been a while since I created an installer package. (they have to be built by hand, as the buildbot currently has no RTAI builders, and it needs modifications to the Makefile)
Having said that, I have a PC that gives 3-digit latency with both RTAI and Preempt-RT. it appears to be entirely random.
  • abs32
  • abs32
26 Oct 2025 17:13
  • abs32
  • abs32
26 Oct 2025 17:11
These are different questions and topics. In those topics where the authors forgot to say the main thing, I inserted the necessary pieces to make it easier for new users to search.
  • andypugh
  • andypugh's Avatar
26 Oct 2025 16:55
Replied by andypugh on topic VTK based version of Vismach
That's very pretty.
Is it any easier to comprehend than Vismach? I find using Vismach rather confusing (and I wrote the docs!)
  • andypugh
  • andypugh's Avatar
26 Oct 2025 16:54
Replied by andypugh on topic POSITION_FILE and index
I did something a bit like this using resolvers (with the difference being that resolvers are single-turn absolute)
wiki.linuxcnc.org/cgi-bin/wiki.pl?Psuedo-Absolute_Encoders
You probably need a realtime HAL component (or set of standard components) that zeros the absolute portion of your adder when the index is seen. This is because of the way that the joint position feedback is used in the home offset calcuations.
  • PCW
  • PCW's Avatar
26 Oct 2025 16:43
Replied by PCW on topic MESA 7I92 programming
Category: Driver Boards
This works for me:
Displaying 12031 - 12045 out of 12864 results.
Time to create page: 1.292 seconds
