  • tuxcnc
  • tuxcnc
02 Aug 2026 20:34
Replied by tuxcnc on topic Chinise mesa clone vs Original vs Ethercat
Category: Driver Boards
hi,
with Pulse and direction top speed and precision calculus are clear  but
But how to calculate the bandwidth on a Ethercat servo drive and precision?
let say leadscrew pitch 0.100inch encoder servo 10000 ppr?
if bus cycle time is 1000000 and refClockSyncCycles=1
how to determine the top speed IPM and minimal resolution in  Inches (minimal cut).
In amateur machines, none of this matters.
You can count it for hours and buy a Chinese ball screw with a backlash  0.1 mm like me...
  • leexi
  • leexi
02 Aug 2026 20:20 - 02 Aug 2026 20:22
Replied by leexi on topic Chinise mesa clone vs Original vs Ethercat
hi,
  • hitchhiker
  • hitchhiker
02 Aug 2026 20:14
Replied by hitchhiker on topic PUMA 200 Robotarm and some Hal/INI issues
today.... get some stuff working...
i managed to eliminate the coupling of axis a to b axis a to c and axis b to c.
then i get it work to home on my edding marks with index signals from the encoders.
i think i am near to a working world mode?! but Z axis doesnt look ok... i upload some videos....
joint mode for handling stuff works perfect... but my world mode.. doesnt work correct... possible someone know the issue of my z axis? i double check all length and offsets for the DH parameters.... the angles are still the same (alpha).
right hand rule.. thumb as Z up.. i must doo the stuff i think... i will make some stuff from cradboard.. after this weekend..headache..
here some youtube shorts
www.youtube.com/shorts/QVSaIWWKXsQ
www.youtube.com/shorts/nbMT6QoQUbg
www.youtube.com/shorts/eSobhr9gZZ0
www.youtube.com/shorts/EBi62z3gkNc
possible i am on the wrong way with my DH parameters and rotations of each axis.. thats why i make a tool from cardboard to identify the issue
thanks
  • tuxcnc
  • tuxcnc
02 Aug 2026 19:09
interesting to know what are the step output card band with
Don't worry. In a real machine feed and acceleration are limited by mechanical parameters.
Whereas increase microstepping decreases effects. In other words there is big different for 1/2 and 1/4 and small different for 1/128 and 1/256...
  • PCW
  • PCW's Avatar
02 Aug 2026 19:05 - 02 Aug 2026 19:30
The maximum step rate will be limited by the step length and step space parameters.
In a working system, these parameters in turn are limited by the drives minimum timing values.
If the clone cards uses that same clock scheme as Mesa cards ( Stepgen base clock= 100 MHz ),
step rates to 10 MHz are possible.
  • leexi
  • leexi
02 Aug 2026 18:33 - 02 Aug 2026 19:21
Hi
test (open loop) non differential output, max step frequency output, perhaps the noise is coming from my testing probes, picture at 3Mhz this output frequency is way beyond my actual needs. and interesting to know what are the step output card band width
and At 5Mhz this is only for testing proposes my servos bandwidth are way below this output
02 Aug 2026 17:50
Replied by tommylight on topic Steuerung für Drehmaschine?
Category: Deutsch
"“linuxcnc-uspace” will also run on a standard Linux kernel for use as a simulator, but it should not be used to control hardware."
Das ist mit normaler "generic" kernel>
Mit RT kernel wir ales nutzen die LinuxCNC uspace fuhr machine steurung.
Fuhr Mesa karte, es ist besser die officiele ISO nutzen, nur wen etwas funkt nicht mit Trixie, dan nutz meine ISO.
  • Aciera
  • Aciera's Avatar
02 Aug 2026 17:35
Replied by Aciera on topic Steuerung für Drehmaschine?
Category: Deutsch
Du brauchst nur die 'Debian 13 Trixie PREEMPT-RT ISO ' runter zu laden, die hat alles was du für Mesa Karten brauchst.
  • Holzwurm56
  • Holzwurm56
02 Aug 2026 16:53 - 02 Aug 2026 17:03
Replied by Holzwurm56 on topic Steuerung für Drehmaschine?
Category: Deutsch
Es gibt wohl LinuxCNC und LinuxCNC-uspace. LCNC-uspace wäre nur zur Simulation aber nicht zur Maschinensteuerung. Die neueste Version
ist wohl Debian 13 mit LCNC 2.9.10, das ist aber mit uspace. Was soll ich jetzt am Anfang installieren? Es soll natürlich mit Mesa-Karten z. B.
7I96 zusammenarbeiten.
  • Aciera
  • Aciera's Avatar
02 Aug 2026 16:21
Category: Deutsch
habe mir aus dem Forum von Tommylight LM22.1 mit LCNC2.10 runtergeladen
Warum nicht die offizielle stabile Version 2.9.10 von hier linuxcnc.org/downloads/ statt irgend eine master version von vor einem Jahr?
  • Holzwurm56
  • Holzwurm56
02 Aug 2026 15:34 - 02 Aug 2026 15:36
Steuerung für Drehmaschine? was created by Holzwurm56
Category: Deutsch
Ich will meine Drehmaschine auf eine modernere Steuerung umrüsten. Jetzt läuft sie unter Mach3 und 2 Printerports. Ich habe aus alten
Zeiten noch eine Mesa 7I96 und habe mir aus dem Forum von Tommylight LM22.1 mit LCNC2.10 runtergeladen. Wichtig sind für mich 2 Handräder damit ich auch quasi-konventionell drehen kann. Hat jemand so etwas schonmal gebaut und kann mir ein paar Tipps geben? Oder gibt
es unter LCNC eine bessere Lösung? Die 7I92 scheint ja eben sehr aktuell und beliebt zu sein?
Ich habe die Frage im englischsprachigem Forum gestellt, weil mir das mit den Google-Übersetzer
doch etwas umständlich ist, stelle ich die Frage auch nochmal hier.
MfG
Hans
  • tuxcnc
  • tuxcnc
02 Aug 2026 13:13
Replied by tuxcnc on topic Conversational CAD CAM
Category: O Codes (subroutines) and NGCGUI
I found the solution for fanuc style tool numbers.
No changes to Becksvill's code, this will work anywhere.
1. Create settool.ngc file
o<settool> sub
O200 IF [#<t> GT 100]
    #<t> = [#<t> MOD 100]
O200 ENDIF
T#<t>
o<settool> endsub
2. Add to your ini file in [RS274NGC] section
REMAP = T argspec=t ngc=settool
Now, for example, tool 1 will be loaded even if there is T0101 in g-code and tool 101 is not present in tool table.
  • tuxcnc
  • tuxcnc
02 Aug 2026 12:01
if you want to install this i have made it as simple as i know how to.
step 1 if on a brand new install from the ISO then open the linuxcnc config picker first and open any sim.  that will make folders for linuxcnc and configs etc
step 2 copy and past this file into the normal configs directory.  and unzip or unzip before copying
open the linuxcnc config picker again and open this config.  click desktop shortcut.
For me this not works. LinuxCNC starts, but you can't homing or do any moving (following error).
In my opinion, the better way is you collect only necessary files and say what we have to change in standard sim ini.
I did some test with config copied from sample-configs/sim/gmoccapy/lathe_configs.
This is gmoccapy and I recommend for you.
The 6,5 font size is not readable for me. I suspect this is from lack of space in Axis.
In gmoccapy you can safely use 12 font size.
There is one problem to solve - "generate & load" button works partially, generate, save, but not load. Manually loaded lathe_profile.ngc works as expected. Maybe rename button to "generate" only?
For me fanuc style Tnnnn is a problem. I never used this, don't want this, and tried to remove this "advantage", but no luck.
How to change sources for use standard Tnn tools?
I tested only "OD turning", seems this is good idea and good software, and worth to test the rest.
  • tuxcnc
  • tuxcnc
02 Aug 2026 08:47
Sorry, but I can’t exactly create a sample for each of the 100,000 possibilities.
I don't ask you for all possibilities, but only for share configs you used for your tests.
  • tuxcnc
  • tuxcnc
02 Aug 2026 08:30
after some test I found the maximal output step frequency that I can get is around 100kHz, , beyond this frequency I start getting following error message, no matter what value on following error is placed at .ini
Do you know if is possible to increase this frequency?
Check max acceleration in your ini.
Low acceleration with high speed increase ferror.
Displaying 1231 - 1245 out of 13448 results.
Time to create page: 0.849 seconds
