  • robh
  • robh
18 Oct 2025 20:05 - 19 Oct 2025 16:11
Sliding Head Lathe for sale - maybe grate devlopment tool for linuxcnc ? UK
Category: User Exchange
Location UK, Cambridgeshire
For sale i have a used Citizen L16 it has 20mm upgrade guide bush for it also
,love to see it go to someone who can maybe retro to linuxcnc and get some devloment progress on dual spindle programing and multi spindle/dual path programming
 reason for sale its not being used  as i upgraded to a M20 Citizen slider in its place and no space to have both.
price - £1500
buyer picks up i can load to buyers transport with pre aranagment , or send your own machine mover as it is a pickup and go no skating needed.
the origianl control does dual path program, $1 for main, $2 for sub,$3 is for setup pramiters have made many parts of all types on it, in materials from Steels, Stainless, Titanium etc never a problem for this machine.holds grate tollerance, all axis work fine, all spindle work grate axis
programable , Z1,X1,Y1 , Z2,X2Spindles 3, Main (+indexing),
Sub & Power toolingBar feeder ready interface (was ran on Imeca magazine)
can only work on simple single bar type barfeeders also.
can run ground or non ground bar on it
Main & Sub spindle uses F25 collet type, very common to find - sorry i dont have any i can include as our new machine uses this type also.
has power tooling on the main slide,
i have the slide unit that runs 1x power tooling , also slide unit that takes 2x power tooling. these are easy to change over,
and in the control you tell the machine which unit is in use and it will adjusts all offsets etc for the slide units.
machine has dual path programing so main and sub slides can do there own things, or work together. very powerfull machine when used to true protentional.i have the manual for the machine, paper copy only includs drawings, programing and using of the machine.
Guide bush type depends on guide bush module in use (max 16 OD unit type B238 (61.002), or max 20mm OD unit type B261 (22.001))
i have a driven and static guide bush unit for the B238 types - included in price (photos now added of these)
i have a handfull of B238 Collets i will include in the sale for free , alot are odd sizes from running plastic bar & aluminium.sorry no main orCollets included now added in photosall collets are round,
Sizes are: 2x10mm, 7mm, 3/8",9/32",8.5mm,9/16", 5/8", 6mm, 13.5mm, 1/4",16.6mm,12.85mm,16mm,2x8mm
has indexing on the main spindle only, this is every 15deg with a lock peg to hold position, sorry no true C axis
power tooling holders take standard ER16 Collets.
have upgraded the old inverters to newer Mitsubishi units for the main and sub spindle upgrades aprox 3 years ago, also upgraded the old DC power tooling motor to AC servo motor so more speed & Torque than standard.
had a new encoder on Z2 motor about year ago.
also changed the old CRT to LCD screen
the machine is fully barfeed ready with a socket for the interfacing of a magazine type barfeeder,
there is no bar feed included as we used this on our new machine. but i do have a LNS magazine barfeeder that i belive could be made to work/talk to this machine that i can offer  to the buyer with machine for £500
machine is underpower but has been in storage for awhile now and has lost its pramiters, i do have these but it requires reloading due to it being in storage batterys are flat in it ,
machine is sold as seen but was fully working and making parts untill our new machine arrived.
no tool holders included sorry.
machine weight Aprox 1Tone
machine requires 3 phase 400v supply to transformer which is included for the machine 400 to 200v 3phase
any questions please contact us,
if you wish to view the machine please contact me
.questions please post here it is listed else where also.
  • Mag20011
  • Mag20011
18 Oct 2025 19:42
Replied by Mag20011 on topic Hermle UWF 700 Retrofit
Category: Milling Machines
Hallo, woher genau bist Du denn? Könnte man auch mal vorbeikommen? Oder telefonieren? 0171 4152421 Gruß Markus Scheck
  • Hakan
  • Hakan
18 Oct 2025 19:33
Replied by Hakan on topic Ohmic sensing with IPTM-60
Category: Show Your Stuff
It was the probe height setting. Increasing the probe height setting a lot made it work with one touch.
Looks ok now.
  • Hakan
  • Hakan
18 Oct 2025 15:53
But why is there a double sense always?
It should be enough with one, the first contact.
The plots are from a web csv plot tool, output from the sampler component to record longer sequences.
The following settings have been used.
  • Will_cnc
  • Will_cnc
18 Oct 2025 15:10
EL8 - Rehoming axis goes max speed ignores machine and driver limits
Category: EtherCAT
Hi Shemj
I am currently having the same issue as you when I press ref (X/Y/Z) in probe basic the machine moves to its 0 position on that axis uncontrollability ignoring the maximum velocity.
Please let me know if you have found a way to home to machine and retain the encoder values when the machine is powered off ?
cheers will
18 Oct 2025 13:52
Replied by tommylight on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
That should not be a distro issue, but a config issue, so do start a new topic and upload both configs so we can have a look.
18 Oct 2025 13:50
Proposal RPi Linuxcnc Image Based on Raspi OS All welcome/encoraged to comment
I'm happy to be helpful to the community even if it is just planting ideas into smart people's minds :)
That is quite a habit to have, so use it as much as possible.
  • unknown
  • unknown
18 Oct 2025 13:45
Saw that, but was too lazy to setup the spare RPi. In fact that was what led me to pi-gen. Tho I haven't completely ruled it out.
Tho I do seem to like with pi-gen you can stop the process at certain stages.
Luckily or maybe not so I'm in a position where time is something I have plenty of. Also a couple of PC's I can use to build different configs. Sadly only one spare RPi400 and one spare RPi5, with the RPi5 being part of a very generous gift on Father's Day from my son.
  • f355
  • f355's Avatar
18 Oct 2025 13:29
first of all, thanks for the kind(-ish, lol) words, I'm happy to be helpful to the community even if it is just planting ideas into smart people's minds :)
have you seen github.com/raspberrypi/rpi-image-gen? to me it looks like a better fit for the purpose - all we need is to install some packages and configure some things, right? building the entire distro from scratch seems excessive.
  • andypugh
  • andypugh's Avatar
18 Oct 2025 13:15
Replied by andypugh on topic Axis configuration not fully working on 2.9.6
Category: AXIS
The buildbot doesn't seem to be working properly at the moment.
I have build a test .deb manually instead.
www.linuxcnc.org/temp/linuxcnc-uspace_2.9.7pre_amd64.deb
You should be able to download the file and install with
sudo apt-get install ./http://www.linuxcnc.org/temp/linuxcnc-uspace_2.9.7pre_amd64.deb
Note that this will overwrite your current linuxcnc installation (or will install linuxcnc if it is not installed on the machine). It will not alter the Linux OS and your current machine configurations should be unaffected.
  • meister
  • meister
18 Oct 2025 12:19
Raspberry PI4/5 I2C support for non realtime IO/ADC/LCD
i wrote a hal component in python to control some I2C devices
*  pcf8574 : Digital IO's
#  ads1115 : Analog input
#  lm75  : temperature sensor
#  hd44780 : LCD display
It is actually part of the RIO project, but can also run independently.
Maybe someone can use it.
It's also no problem to install additional devices. Just let me know what you need; I have almost everything here :)
Cheers Olli
Link: github.com/multigcs/riocore/blob/dev/rio...ins/rpii2c/rpii2c.py
  • unknown
  • unknown
18 Oct 2025 10:49 - 16 Nov 2025 02:58
After a bit of a discussion with forum member f355 it came to my attention that an image based on the "Raspiberry Pi Way" maybe possible. Whilst a little "terse" at first he did raise some valid point and gave me time to reconsider some things. And eat some humble pie. I would like to give thanks for this...sometimes it's needed to find a new direction.
One reason for this idea is to make using the image more familiar to those used to the RPi ecosystem. Being able to use the RPi imager and setup some defaults may be beneficial as well.
At the moment I'm experimenting with pi-gen ( github.com/RPi-Distro/pi-gen/tree/bookworm-arm64 ) target a bookworm based image, as I feel as time moves on and more familiarity is gained using the tool a working image with a RT kernel and Linuxcnc will be produced and can be compared to the existing image. Wifi seemed to be a bit of a issue from time to time.
Hopefully from this in the readme "Tool used to create Raspberry Pi OS images, and custom images based on Raspberry Pi OS, which was in turn derived from the Raspbian project." distribution should not be an issue.
So the first task is to create a basic image to get a feel for the tool.
All input whether positive or negative ( remember coming from Australia I'm somewhat hard to offend ;) ) is welcomed and encouraged. Rather than the way it has happened in the past I would like this to be more of a community effort with regards to packages. Please remember the object is not to create a daily driver OS but one that makes the entry easier to running Linuxcnc on a Pi. Whilst it may be beneficial to include CAD\CAM I feel leaving this out will create a smaller image to download, and as there are many packages available half will be happy, half wont be and the other half may not have a preference.
As a final note the final decision will have to be made by the Linuxcnc hierarchy as I dont want to go against their wishes, but for the moment I think at least a discussion is good idea, and see what the community thinks.
Yes,yes I know some our esteemed members aren't exactly keen (not recommend) on the RPi due to cost factor. ;)
Cheers
Rob
Any issues please post here
github.com/ozzyrob/pi-gen-linuxcnc
  • DerKlotz
  • DerKlotz
18 Oct 2025 09:51
Replied by DerKlotz on topic Combine Glade Togglebutton with Physical Input
Category: GladeVCP
So i disabled
#net machine-is-on halui.machine.is-on
in my machine.hal
and did this in my custom_postgui.hal
net MachineLED <= halui.machine.is-on => gladevcp.led_Startstopp
  • f355
  • f355's Avatar
18 Oct 2025 09:43
Replied by f355 on topic Update LinuxCNC 2.9.5 on debian 13
Would this be a situation where you would like to give a little more input.
Oh certainly and with pleasure! Feel free to create the new thread and shoot me a link.
  • f355
  • f355's Avatar
18 Oct 2025 09:38
1. All of this is my method. I'm not implying it is better or worse than yours, it's just mine.
2. There still is/was a patch that exposed /sys/kernel/realtime that linuxcnc required before 2.9.5, and the kernel is still built from source and baked into the image, as opposed to being installed from an apt repo. That makes the kernel update path unclear to me.
3. I could have asked, but I didn't. I never implied that "those that manage Linuxcnc allow randoms to upload untested content to their server", I'm sure the images are well tested and vetted. All I said is that it is completely non-obvious where the image builder sources are - I've just spent 10 minutes to find them again and I couldn't - and the official github has obsolete sources. That doesn't inspire much confidence in how well those images would be maintained in the future, don't you think?
5. I understand there are differences, it is obvious, I just don't want those differences. I gain nothing by learning how yet another distro is organized, it is wasted brain cycles. Now, your copyrighted branding point makes a lot of sense - I honestly did not think about that, and yes, it certainly adds a huge deal of motivation for not using RPi OS for pre-built images, but as I said even before your point, I totally get why your images exist. You've done a great job, I'm just not in the target audience for your work.
Displaying 12541 - 12555 out of 12878 results.
Time to create page: 0.618 seconds
