  • Darrell
  • Darrell
17 Aug 2026 04:50
Replied by Darrell on topic For a full-fledged Press Brake GUI
Category: Other User Interfaces
We used "BendDeduction" I think it was 5x material thickness or was it radius?
17 Aug 2026 03:57
Replied by tommylight on topic Conversational CAD CAM
Category: O Codes (subroutines) and NGCGUI
yep no stress.
Yeah, not possible, and not because of this or anything here, not sure if you bumped into a post some 2 months ago where i mentioned the government literally destroyed my business (paid for china machines for whoever applied for that grant) so now i have 5 or 6 new machines collecting dust and a new shop i have no use for.
I hate to say it, but i will have to become a youtuber or start training schools, be it online or live, ... or start doing flooring as this has gone from 2-4 euro per sq meter two years ago, to 11-14 euro now! And of course, i am bloody good at it, but .... oh hell no.
5:54AM so i am off to bed, will report back whenever i get a chance to test, been preparing some stuff for 6 days ... yotuber :)
17 Aug 2026 03:41
Help needed for conversion of old ( and loved ) Mach3 MPG
Category: Basic Configuration
Whats confusing to me too, is that i cannot use
"loadusr -W hal_input Code Mercenaries KeyWarrior Combo O Commander" , that one won't work, only without " , its accepted.
As far as i know, you should always use " when there are blanks in a name / path.
Try:
loadusr -W hal_input "Code Mercenaries KeyWarrior Combo O Commander"
17 Aug 2026 03:39
Replied by tommylight on topic THC doesent work when G code is running
Category: Plasmac
Disable "mesh" mode.
  • rodw
  • rodw's Avatar
17 Aug 2026 03:22
Replied by rodw on topic THC doesent work when G code is running
Category: Plasmac
Have you enabled the THC in the GUI?
  • viewsat
  • viewsat
17 Aug 2026 01:18 - 19 Aug 2026 05:17
The problem has been resolved after adjusting the parameters of `joint` and `pid`.
I measured 0.2mm using a logic analyzer, which is not 64 steps.Tang Nano 9k riocore ,leadscwer=5mm,driver= 1600step/revScale_Out=320 ,1mm/320=0.003125mm/step0.2mm/0.003125=64step
17 Aug 2026 01:10
Replied by tommylight on topic Frage zu 7I96?
Frage zu 7I96?
Category: Deutsch
... ich meine ich hätte gelesen das die Eingänge 5volt tolerant sind und einen Pullup-Widerstand hätten.
Das ist wahr fur diese:
This is very different from the P1 expansion connector
that is only for +5V signals max and has pullup resistors.
Die normale eingange mit schraub klemen, da sind OK fuhr 36V
  • PCW
  • PCW's Avatar
16 Aug 2026 20:22
Replied by PCW on topic Frage zu 7I96?
Frage zu 7I96?
Category: Deutsch
The isolated inputs on TB3 accept 4V to 36V signals.
  • Holzwurm56
  • Holzwurm56
16 Aug 2026 19:49
Replied by Holzwurm56 on topic Frage zu 7I96?
Frage zu 7I96?
Category: Deutsch
Hallo tommylight,
vielen Dank, ich meine ich hätte gelesen das die Eingänge 5volt tolerant sind und einen Pullup-Widerstand hätten.
MfG
Hans
  • Carpio
  • Carpio
16 Aug 2026 19:21
Replied by Carpio on topic Retrofit of a Hitachi-Seike VK45 mill
Category: CNC Machines
Hi do you still have all the old boards from the VK45?
Andre 717-870-3719
16 Aug 2026 18:58
Frage zu 7I96?
Category: Deutsch
Auf die Mesa 7i96 manual (niht 7i96S):
  • Holzwurm56
  • Holzwurm56
16 Aug 2026 18:45
Frage zu 7I96?
Category: Deutsch
Hallo,
ich kann jetzt die Karte über Ethernet ansprechen und habe auch die 7I96_inmd.bit auf die Karte gespielt. Nur mal eine Frage für
die Zukunft: Gibt es eine Karte die so ähnlich wie 7I96 ist aber Eingangssignale von 24Volt verarbeiten kann?
MfG
Hans
  • GFC
  • GFC
16 Aug 2026 15:50
Category: Plasmac
while doing the first tests on my machine I noticed that THC doesnt work when the machine is running G code
I looked around and did some tests and it does work and move the z axis when I start a manual cut with f9 and jog with the arrow keys
QtplasmaC is getting arc voltage and arc ok signals
the G code im testing is the metric wrench and things from the conversational panel
the THC enabled light turns on but not the active light
it looks like the machine is getting up to the feed speed
how should i troubleshoot this and am I missing something obvious?
  • grandixximo
  • grandixximo's Avatar
16 Aug 2026 14:50
read if you have personal c or c++ components
Category: LinuxCNC Announcements
The HAL types and isolation work on master 2.10, changes how C/C++ components register and access pins and params: opaque refs with hal_get_*/hal_set_* accessors instead of direct volatile pointer dereference. The old API still builds (deprecations, not removals), so this is a migration window, if you need clarification please post here or better on
github.com/LinuxCNC/linuxcnc/discussions/4393
  • muddiver
  • muddiver
16 Aug 2026 08:57 - 17 Aug 2026 17:45
Hi folks!
i try to get my loved MPG in action in Linuxcnc, but i struggle..
when i ask lsusb i get told its a:
ID 07c0:0115 Code Mercenaries Hard- und Software GmbH KeyWarrior Combo O Commander
when i ask cat /proc/bus/input/devices i get
[code]I: Bus=0003 Vendor=07c0 Product=0115 Version=0110
N: Name="Code Mercenaries KeyWarrior Combo O Commander"
P: Phys=usb-0000:2a:00.3-3.4.4/input0
S: Sysfs=/devices/pci0000:00/0000:00:08.1/0000:2a:00.3/usb3/3-3/3-3.4/3-3.4.4/3-3.4.4:1.0/0003:07C0:0115.0004/input/input13
U: Uniq=
H: Handlers=sysrq kbd event13 leds
B: PROP=0
B: EV=120013
B: KEY=1000000000007 ff800000000007ff febeffdfffefffff fffffffffffffffe
B: MSC=10
B: LED=1f
P: Phys=usb-0000:2a:00.3-3.4.4/input1
S: Sysfs=/devices/pci0000:00/0000:00:08.1/0000:2a:00.3/usb3/3-3/3-3.4/3-3.4.4/3-3.4.4:1.1/0003:07C0:0115.0005/input/input14
U: Uniq=
H: Handlers=mouse1 event14
B: PROP=0
B: EV=17
B: KEY=70000 0 0 0 0
B: REL=3
B: MSC=10
when i run "halrun" and type in:
The keys get loaded, but they get loaded 5 times!
I am told that the name for the device is "Code Mercenaries KeyWarrior Combo O Commander" ,
but the message also shows 5 times!
What am i doing wrong?
loadusr -W hal_input "Code Mercenaries KeyWarrior Combo O Commander" , that one won't work, only without " , its accepted.
Thanks in advance, Tom
[/code]
Displaying 1291 - 1305 out of 12957 results.
Time to create page: 0.801 seconds
