  • Todd Zuercher
  • Todd Zuercher's Avatar
31 Jul 2026 11:02
Replied by Todd Zuercher on topic RS485 + Absolute Encoder for Homing a 4th Axis?
If the drive and motors have absolute encoders and if you are not having encoder feedback to Linuxcnc, you may be able to program the drive to move to the "home" position when Linuxcnc sends it a home command. Then have send a homed signal to Linuxcnc which Linuxcnc could see as the home switch.
Linuxcnc also supports absolute encoders and if the absolute encoder position is being fed back to Linuxcnc, then homing is not necessary at all.
  • meister
  • meister
31 Jul 2026 09:49 - 31 Jul 2026 09:57
Livestream Discussing LinuxCNC and MTConnect 27 July 2026 11:00am GMT+10
I've already found the repo, but it would be better if it were separate from the LinuxCNC source—that's what I meant by having its own repo.
It would also be cool if you could pass in additional HAL signals, like sensors or 'door-open' inputs.
EDIT:
My first AI project (A simple status page for MTConnect):
github.com/multigcs/riocore/blob/dev/rio...nect/files/stat.html
to test it, you can simply overwrite the twin.html file with it.
  • rodw
  • rodw's Avatar
31 Jul 2026 09:46
Replied by rodw on topic StepperOnline A6 Servo
Category: EtherCAT
Thanks Guys, My main problem is that Always Homed is not working, and the issue with Homing my dual Y Setup Precisely. :|
Re homing, please read this link until you understand it. Probably at least 6 times
linuxcnc.org/docs/stable/html/config/ini-config.html
  • rodw
  • rodw's Avatar
31 Jul 2026 09:40
Yes its pretty cool. His repo is here github.com/sliptonic/linuxcnc/tree/feature/mtconnect-agent
I've added this link to the video description (and installed it on my machine including a Home Assistant panel)
I have asked in another thread if anybody has a 3 axis vismach model we could use in our PR to linuxCNC
The next step is to discuss with the devs how best to package this. My thought is to have a userspace driver that you added to your Hal file something like:
loadusr -W MTconnect mtconnect.ini
Because all parameters are contained in the ini file, I think this approach will require passing the ini file name to the driver.
  • rodw
  • rodw's Avatar
31 Jul 2026 09:26
Replied by rodw on topic DIY CNC
DIY CNC
Category: Milling Machines
@logthor: The stl you posted, will be a nightmare to machine :-).
Glad someone else looked!
With some spindles, its not possible to fit an encoder (I've had a couple) but thread milling solves the thread cutting dilema on all machines and is much easier on small machines.
  • Aciera
  • Aciera's Avatar
31 Jul 2026 07:46 - 31 Jul 2026 08:20
Replied by Aciera on topic PUMA 200 Robotarm and some Hal/INI issues
could it be a problem that i change the signs on m joint 1,3 and 4 (linuxcnc joints!).. there have minus sign... please look at the ini you will see what i mean.
If you mean the 'SCALE_PWM' then that is not necessarily wrong as long as the joints rotate in the correct directions when you are jogging.
but the in Wolrd Z moves are "ok" but in x and y it makes stuff wit the hand joints and get failure
That sounds like you may be getting close to a singularity. Try setting the B joint to something that is not so close to having it point along the arm because if the wrist is collinear with the lower arm the C axis and the A axis are collinear which is a singular pose.
Sim configs CAN rapidly change the orientation of a wrist joint when approaching a singular pose, doing this with real hardware will trigger joint following errors and the kinematic will eventually fail.
for more on singularities in 6 axis manipulators:
mecademic.com/insights/academic-tutorial...es-6-axis-robot-arm/
Try it with a pose more like this:
  • meister
  • meister
31 Jul 2026 07:34
He's done a really great job with his MTconnect;
it works perfectly, so I integrated it directly into my riocore system as a plugin.
It would be nice if there were a dedicated repository for it.
  • Jugo2
  • Jugo2
31 Jul 2026 07:22 - 31 Jul 2026 07:23
Replied by Jugo2 on topic StepperOnline A6 Servo
Category: EtherCAT
  • Logthor
  • Logthor
31 Jul 2026 07:19
Replied by Logthor on topic DIY CNC
DIY CNC
For the simple stuff I'm doing with my bob, I don't think it'll be an issue. I'm well aware of what a nightmare it'll be to machine. The model needs a lot of love.
  • hitchhiker
  • hitchhiker
31 Jul 2026 06:18
Replied by hitchhiker on topic PUMA 200 Robotarm and some Hal/INI issues
this is how it looks when i start the genserkins example
i attached 2 screenshots.. mygui is what i have after homing. i changed in the homing: homeoffset und home to 0. i move befor homeing in a extra osition.. form this position i hit home... then all 6 motors turn until the Z index of the encoder is reached.
i attached form this a picture.. pumaafterhoming.... thats the "ready position" but the in Wolrd Z moves are "ok" but in x and y it makes stuff wit the hand joints and get failure.. i attached again the used ini with editi to home and home offset 0.. to talk about the NOW situation.
i thank you!
aah befor i forget... there is a difference between puma 560 and puma 200... the shoulder of the puma 200 is of the opposite then on the puma 560. thats why i have on D1 a positiv value.. this value i got from stäubli via email. i measured.. and yes this values are correct... its from red green to green in the drawing i attached. i add then the puma560geo.png to the attached files that you see what i mean what is the difference...
pum200geo
puma560geo
puma200afterhoming
puma200gui after homing
exampleguipuma560
  • timo
  • timo
31 Jul 2026 05:26
Replied by timo on topic DIY CNC
DIY CNC
Anecdotal evidence: I had issues getting a 100ppr encoder to work reliable at 600 rpm. The cheap BOB seemed the issue, the system was loosing signals.
The Mesa Card fixed the problem and I have not the slightest interest in trying to figure out what went wrong, only point (I should have spent the money earlier)
20000 pulses (if I am correct and did not make a mistake) It would limit a 1/8th 200ppr stepper motor with my lead screw (4mm pitch) to approx. 3000mm/min. This is in my book good enough for a sherline, but some commercial machines run approx. 10x that speed.
  • Aciera
  • Aciera's Avatar
31 Jul 2026 05:08
Ah, I see what you mean, the A value being 180° because the tool coordinate frame is pointing away from the flange. You are rotating the tool frame in the kinematics. Ok that shouldn't be the problem then.
Can you post a screenshot of the situation when you start the example program?
  • GeckoWorks
  • GeckoWorks
31 Jul 2026 04:53
Replied by GeckoWorks on topic USB haas operator panel interface
Category: Other User Interfaces
I went a bit deeper into this rabbit hole and picked up some used panels. Still waiting for them to arrive. Not Haas though - I missed out on that deal.
But it turns out, sometimes (often?) these panels are a mix of both a raw matrix output and USB or PS/2. Like the Syntec and their clones as shown here . In the latter case, the "CNC'ish" buttons are all just a matrix but the keypad/numpad come out as a standard PS/2 protocol.
  • meister
  • meister
31 Jul 2026 04:49
I use ./bin/rio-flow riocore/configs/TangNano9K/config.json
The automatically generated ini and HAL files cannot output a 1kHz PWM spindle signal. Do I need to edit the HAL and ini files myself to output the spindle PWM signal?
What does your setup look like?
Which interface are you using, and where do you want the PWM output to be?
To use the spindle in LinuxCNC, you still need to configure it in the “Signals” tab.
  dty/net = spindle.0.speed-out
  enable/net = spindle.0.on
@all WARNING: Serial/USB does work, but it's really just for testing;
I wouldn't use it in a production environment.
  • GeckoWorks
  • GeckoWorks
31 Jul 2026 04:46
Replied by GeckoWorks on topic Control panel
Control panel
Category: Show Your Stuff
I was away for a bit but thanks so much Mass.
Thanks for elaborating on why you went with encoders. Syncing with display sliders and resetting to 100% on a press of the knob sounds like good ideas.
I think I read somewhere that the sliders can be made to move with the rotary switches and then if you go to make an adjustment on the slider, it overrides the physical knob. And then when you turn the knob again, that takes over and the slider follows along.
But I can imagine going back to the knob might make some abrupt speed changes. So, having full sync all the time and thus encoders sounds preferable unless one is OK with never/rarely using the sliders.
In the meantime, I picked up three used panels for a steal. They are not SKs but the arduino project and your info will still come in very handy when it's time for me to try to hook them up. If I give up on those, they were so cheap, I can grab an SK4 and make it happen faster thanks to this thread:)
Displaying 1381 - 1395 out of 13401 results.
Time to create page: 1.556 seconds
