  • matasbuk
  • matasbuk
24 Jun 2025 21:19
Replied by matasbuk on topic Qtdragon for lathe??
Category: Qtvcp
Thank you! Worked perfectly
  • kworm
  • kworm
24 Jun 2025 21:19
Replied by kworm on topic New with questions on LinuxCNC and Mesa
You might also want to consider servo drives from Delta, Rexroth, or others that support direct connection of the linear encoders to the servo drive for full closed loop operation.  This is combination with absolute encoders on the servos is how I think most new machines are doing it...at least the ones I have seen.   They could be controlled from either Mesa or with Ethercat.
  • kworm
  • kworm
24 Jun 2025 21:15
Replied by kworm on topic Mesa 7i95t and THCAD pncconf screen
Category: PnCConf Wizard
You can just replace the private_data.py file in /usr/lib/python3/dist-packages/pncconf with the private_data.py that is attached to my post. I would backup the original file first just in case.
Well MesaCT doesn't support QTPlasmaC at the moment. I have done some work on supporting it but haven't heard from JT if he's interested in bringing those changes in if I make a pull request.
  • phino
  • phino
24 Jun 2025 21:05
Replied by phino on topic Mesa 7i95t and THCAD pncconf screen
Nice effort! How would one apply the changes to get 7i95t support in pncconf?
What are pros/cons of using pncconf vs mesa CT? github.com/jethornton/mesact
  • kworm
  • kworm
24 Jun 2025 21:00
Sorry I should have had that in my initial post...yes I have QTPlasmaC selected as GUI.
  • Johnnysacalu
  • Johnnysacalu
24 Jun 2025 20:38 - 24 Jun 2025 20:40
Replied by Johnnysacalu on topic Como conectar mesa 7i96s
Category: Driver Boards
Si la señal es cc lo mediré por tenerlo en cuenta pero si es mas seguro con el rele ssr creo que lo pondré.
Otra pregunta crees que es necesario tener picas de tierra separadas una en la caja de controles y otra en la mesa o no hay ningún problema en estar en la misma?gracias por todas tus respuestas
El plasma es trifasico
  • PCW
  • PCW's Avatar
24 Jun 2025 20:34
Replied by PCW on topic Mesa 7i95t and THCAD pncconf screen
Did you also chose QTPlasmaC as the GUI?
(maybe that matters also)
  • MacKaye
  • MacKaye
24 Jun 2025 20:33
Replied by MacKaye on topic Weiler DZ26 Millturn Conversion
Category: Turning
when running said bitfile and using
loadrt hm2_pci config="sserial_port_0=7i77,2500000 sserial_port_1=7i84,2500000"
it doesn´t show a second sserial device when:
sudo mesaflash --device 5i25 --readhmid | grep -i sserial
Maybe i am using the wrong nomenclature or baudrate?
  • PCW
  • PCW's Avatar
24 Jun 2025 20:19
Replied by PCW on topic Como conectar mesa 7i96s
Yes, if you don't know the signal characteristics,
an external SSR would be safest.
Though if it is a DC signal, you can measure the
current with a DVM (Start at high current range and work down)
  • Johnnysacalu
  • Johnnysacalu
24 Jun 2025 20:14
No creo que pueda saber si necesita mas de 100mA lo tengo que conectar al gatillo que tenia la antorcha
  • kworm
  • kworm
24 Jun 2025 19:57 - 24 Jun 2025 22:25
I added support for the Mesa 7i95t to the pncconf wizard (private_data.py with changes attached) and it seems to work ok other than needing to rename the inm to inmux pins for the 7i95t.  However, the THCAD configuration screen doesn't appear even though I assign an encoder input to arc voltage.  I must be missing something in looking at the code but I don't find where self.d._arcvpin that is used to control the display of the THCAD screen is ever set to anything other than None.  I have QTPlasmaC selected as the gui. Any help is appreciated.
Solved:  Attached updated files with the THCAD tab working.  The pages.py and private_data.py go in /usr/lib/python3/dist-packages/pncconf and the pncconf.txt should be renamed to /usr/bin/pncconf.
  • PCW
  • PCW's Avatar
24 Jun 2025 18:50
That will likely work, but the diode in not needed unless you use a magnetic relay.
It also unnecessary for TORCH_ON as you could use one of the high isolation (OUT4,OUT5)
outputs of the 7I96S directly as long as the current required is not > 100 mA
  • Johnnysacalu
  • Johnnysacalu
24 Jun 2025 18:36
Me podrias confirmar si es correcto? Gracias
  • vitali
  • vitali
24 Jun 2025 18:24
Replied by vitali on topic How to design new driver for my own board
I am going to install Linuxcnc on Orange Pi PC Plus. OPC send to FPGA controller
Speed and Axis coordinate in steps. FPGA controller has buffer for all parameters. According my calculations USB speed is enough to work in real time.
  • PCW
  • PCW's Avatar
24 Jun 2025 17:51
Replied by PCW on topic New with questions on LinuxCNC and Mesa
In general there is no real advantage to have the local rotary feedback
returned to LinuxCNC (and some electrical disadvantages) So a 7I95T
would have sufficient Encoder channels.
Displaying 14611 - 14625 out of 15154 results.
Time to create page: 0.482 seconds
