  • unknown
  • unknown
12 Apr 2025 23:01
Replied by unknown on topic 7i92 firmware issue
7i92 firmware issue
Category: Driver Boards
I thought EINT might be the issue, there's a 1k pullup to 3.3v, the top 8 data lines have a 1k pull down.
Might be C5 around the L1 inductor, I installed a 100nf cap instead of a 4.7uf.
I don't know if that will make a lot of difference.
I've run a config, no hardware connected to the board yet, but no errors. Tho I assume writing to the flash is more of a load. It's bound to be something stupid on my behalf.
The major difference is the WP on the flash is just held high, any chance that the circuit around the WP on the flash is causing the issue, there's no reset device connected. Tho the EPP & SPI based on the 7c81 have been the same.
  • hmearns
  • hmearns
12 Apr 2025 22:38
Yaskawa SGDH-10AE and 7i95 Not Controlling drive
Thanks for the response!
I used some of the settings from the following page:
www.centroidcnc.com/dealersupport/tech_b...tins/uploads/295.pdf
I have Pn000 at 0010H and Pn002 at 0100H PN200 isn't set as in the document, it is set for positive pulse and direction input.
I've also gone through the sigma II manual especially the trial procedure and tried to go through the settings that seemed relevant.
I'm aware of the power reset to make some settings take effect.
  • Kieran
  • Kieran
12 Apr 2025 21:34
Replied by Kieran on topic Rf45 clone glow up.
Rf45 clone glow up.
Category: Milling Machines
I'm pivoting my design since I just ordered a CSF 45 harmonic drive for the B. The 40 will be the 4th axis on the table. I put a 10ths indicator on the harmonic drive. It has no backlash, which is crazy cool, but does have maybe 0.0001 of "flex" backlash if I put lots of stress on it with a wrench. Seems pretty sweet.
  • PCW
  • PCW's Avatar
12 Apr 2025 21:15
My guess is that the drives are still in analog velocity mode and need to be set to step/dir mode.
  • hmearns
  • hmearns
12 Apr 2025 21:02
I'm retrofitting a Fryer ET-25 lathe with using a mesa 7i95 board.  The lathe has two SGDH Sigma II drives. I'm having trouble controlling them with step and direction signals from the mesa board. I have the yaskawa sigwin software connected to the drive. I have the axis moving with the jog function in the software. I have disconnected the voltage reference signals from the old controller, but haven't removed them from the drive or grounded them.  I've got the contactor coming on for the drive. The only thing that doesn't look remotely positive is that the SEN signal is off, but I have an incremental encoder and it is my understanding that it shouldn't therefore matter. I can see the pulses accumulate as information in the yaskawa software, I can see both the step and direction change when the appropriate direction is picked. I have bypassed the overtravel signals and linked the P-con signal to the power pin 40.  I feel like there has to be a simple setting I'm missing. Maybe I'm not doing something right on the ini file as well? I'm assuming its at least good enough to make some movement since i'm getting an indication on the drive software, but maybe thats not accurate. All of the similar retrofits I have found end up using voltage reference even though everyone recommends step and direction to begin with, so I haven't found anything to go by really, if there's anything I've missed on that front, please let me know that as well.   Any help would be appreciated.
Howard
  • PCW
  • PCW's Avatar
12 Apr 2025 20:50
Hydraulic Linear Motion Precision Controll
1) What is the typical following error for an axis with a linear scale of 0.001mm resolution(1 micron)? In steady state it is able to position the axis within +-0.005 accuracy. Do you think it is possible to get more from that scale resolution?
Typically, some I term is added to reduce the static error.
During acceleration and deceleration, an error jumps up to 0.1mm at 1500mm/min speed. What is a typical result for well well-tuned PID loop?
That mostly depends on the characteristics of the controlled device (delays, linearity etc)
Can you post a Halscope plot of following error and velocity?
  • aluplastvz
  • aluplastvz
12 Apr 2025 20:18
Replied by aluplastvz on topic Double Miter Saw Machine XAB Configuration
Category: Basic Configuration
I did this with PLC, it is easier and the expected result is obtained.
Greeting
  • PCW
  • PCW's Avatar
12 Apr 2025 20:17
homing with Phase Z encoder on MESA 7i96s
Can you post a plot that shows this oscillation, including the velocity and the ferror?
  • JackRay
  • JackRay
12 Apr 2025 19:50
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
but I know how to use the halscope. I know how to read the curves, but I don't know which parameter to adjust when, for example, I have oscillations in the error.
  • Niko
  • Niko
12 Apr 2025 19:46
Replied by Niko on topic NativeCAM instantly pauses
Category: NativeCAM
Selecting this button fixed my issue .
  • PCW
  • PCW's Avatar
12 Apr 2025 19:36
Mill setup troubles and questions (Speed display, at speed signal, coolant pump)
Absolute spindle speed accuracy may not be terribly important
anyway for actual machining.
  • Lampje
  • Lampje
12 Apr 2025 19:17
Unfortunately the spindle doesn't have an encoder. And adding one might proof difficult.
  • israfilcaglar
  • israfilcaglar
12 Apr 2025 19:08
Replied by israfilcaglar on topic How to homing the A-axis again with gcode?
Category: AXIS
Thank you. I will check and try.
I want to ask you a question. How can I use the M19 command with Mesa 7i96s?
Can I call the M19 gcode and position the spindle?
  • jc2ktr
  • jc2ktr
12 Apr 2025 18:20
Replied by jc2ktr on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
Is there a way to get the Header Files for the RT-Kernel installed? I've tried to install the linuxcnc-ethercat Master, because i´d like to use it with Mint. I  prefer Mint a little more over Debian.
  • Aciera
  • Aciera's Avatar
12 Apr 2025 18:11 - 12 Apr 2025 18:12
executing subroutines even during import of GCODE file
Category: O Codes (subroutines) and NGCGUI
You can use the 'task' parameter like this:
o100 if [#<_task> EQ 1]
;everything in here is only executed during actual gcode execution
o100 endif
Displaying 16756 - 16770 out of 17625 results.
Time to create page: 0.852 seconds
