  • pgf
  • pgf
11 Apr 2025 21:16
Running an external program from a HAL pin
Category: HAL
Right. that's exactly what I'm trying to accomplish -- disable the spindle with EStop. The spindle is a Makita router, with an on-off switch. I'd like to simply plug it into one of my zigbee-controlled smart switches, which are trivial to control from just about anywhere. Obviously a hard-wired relay would be better, but it's only a hobby mill, and that's not going to happen anytime soon.
  • Grotius
  • Grotius's Avatar
11 Apr 2025 21:14
Replied by Grotius on topic Strange behaviour of custom component
but Grotius is on another level so what do I know.
I am on the same level as you Hakan.
Halcompile preprocess gives you bad c code. The preprocess option can be helpfull in some cases,
like reverse engineering a component.
This is a cmake project for a component called "test", i made years ago. It can be used for linuxcnc directly.
codeberg.org/skynet/hal-core/src/branch/.../test/CMakeLists.txt
  1. here should be "linuxcnchal"
  2. your relative paths to linuxcnc dirs
  3. Then this is the function to write your home sequence in.
  4. This is how you load the component in hal.
Then you can look at threads.c source code to use RTAPI ... text's inside the c code, so you can use
multiple instances of the component.
Just ask DeepSeek to add this feature to the test.c file and tell it what you want.
Do it step by step, and test so now and then. In fact it's quite easy.
If you don't succeed in 24hours, i will do it for you.
  • PCW
  • PCW's Avatar
11 Apr 2025 21:12
Category: HAL
How is the spindle controlled?
The spindle should be disabled by  EStop
  • pgf
  • pgf
11 Apr 2025 21:12
Category: HAL
Also, I'm not wedded to doing this with MDI -- I'd much rather use an interface that didn't require editing four different config files just to get it setup. ;-)
It seems like what I want should be part of halui somehow, but as far as I can tell, it's not.
  • PCW
  • PCW's Avatar
11 Apr 2025 21:09
Replied by PCW on topic 7i92 firmware issue
7i92 firmware issue
Category: Driver Boards
Here's a more complete set of utilities:
( note that you should not use Mesa's MAC in the addresses in the scripts )
freeby.mesanet.com/unixfpgainit.zip
  • wrhammer
  • wrhammer
11 Apr 2025 20:54
Remap M6 in python was created by wrhammer
Remap M6 in python
Pretty much got everything up and ready on my Biesse conversion but stuck on running the M6 tool change from auto mode in g-code. The M6 works great from the MDI and is really responsive using the self.execute command to execute the M64 and M65 motion output pins, G43 tool offsets etc. but nothing activates when I try and run an M6 in g-code. I've tried adding delays and waits on the interpreter, have messages printing to the log and the code runs but no outputs actually happen. I did see that the entire g-code is read first and it will immediately try the tool change but it doesn't actually happen. I get a successful tool change in my logs but the DRO and tool info don't update and none of the outputs actually fire to raise and lower solenoids for that bit. It seems like this is something really simple but struggling to find it! Any suggestions?
  • unknown
  • unknown
11 Apr 2025 20:38
Replied by unknown on topic 7i92 firmware issue
7i92 firmware issue
I understand now, silly me.
Ok found I had to use setname & found the Linux version here
www.forum.linuxcnc.org/27-driver-boards/...board?start=10#65737
and I can communicate.
Thanks again
  • pgf
  • pgf
11 Apr 2025 20:31
Category: HAL
I want to shut off my spindle. (A Makita router.) I certainly won't be turning it on this way. And it would be a lot safer to do this than what I have now, which is "nothing". (From the software side, that is. The hardware switch on the mill does cut power to the spindle.)
As a less dangerous sounding example -- I'd also like to control my shop vacuum dust collector automatically. That's less likely to involve e-stop, but it would certainly be nice to shut it down automatically in that case.
  • unknown
  • unknown
11 Apr 2025 20:27
7i92 firmware issue
Oh the 93c46 has to be programmed separately ?
I thought the firmware did that
  • PCW
  • PCW's Avatar
11 Apr 2025 20:26
Category: HAL
It does seem a bit dangerous and contrary to the purpose of EStop
to do motion commands automatically after an EStop event.
What is the intended operation and with what kind of EStop is further motion
safe?
  • Hakan
  • Hakan
11 Apr 2025 20:18 - 11 Apr 2025 20:19
Replied by Hakan on topic Strange behaviour of custom component
You can test with "halcomp --preprocess a*.comp" and look at the a*.c code.
I would not think that is any easier, but Grotius is on another level so what do I know.
Anyways, endian, a start would be to go away from enum, it doesn't seem to work well.
Remove those four-five lines and put in here, just before the ;;
// opmode constants
variable char modeSwap;
variable char homeState;
And further down, below positionModeStatus, put in defines instead of the enums.
#define positionModeStatus                                              16
#define WRITEMODE 0
#define WAITVELOMODE 1
#define INITIAL 2
#define WORKING 3
#define WAITINGFORENABLE 4
#define HOMING 5
#define HOMETRIGGER 0
#define HOMECONFIRM 1
#define HOMESEEKING 2
At least it compiles. Feel free to butcher the code any way you like.]
  • PCW
  • PCW's Avatar
11 Apr 2025 20:17 - 11 Apr 2025 20:27
7i92 firmware issue
I'm not so much suggesting that the EEPROM is bad, but rather
that the EEPROM is empty. (never been programmed)
  • jochen91
  • jochen91
11 Apr 2025 20:16
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
So i worked the whole day with resources from the forum and ChatGPT to create this Kinematic. ChatGPT checked the math forwards and inverse and it seems to check out. I try to set up vismach asap and check it for myself.
component  xyzcb_tdr_kins "Switchable kinematics for 5 axis machine with rotary table C and B and virtual Y Axis";
description
This is a switchable kinematics module for a 5-axis milling configuration
using 3 cartesian linear joints (XYZ) and 2 rotary table joints (CB).
The module contains two kinematic models:
type0 (default) is a trivial XYZCB configuration with joints 0..4 mapped to
axes XYZCB respectively.
type1 is a XYZCB configuration with tool center point (TCP) compensation.
Additionally a virtual Y Axis was added for a Mazak Integrex 200Y
pin out s32 dummy=0"one pin needed to satisfy halcompile requirement";
license "GPL";
author "Jochen Rohm";
#include "rtapi_math.h"
#include "kinematics.h"
static struct haldata {
  // Declare hal pin pointers used for XYZCB_tdr kinematics:
  hal_float_t *tool_offset_z;
  hal_float_t *x_offset;
  hal_float_t *z_offset;
  hal_float_t *x_rot_point;
  hal_float_t *y_rot_point;
  hal_float_t *z_rot_point;
  hal_float_t *angleXX;
  //Declare hal pin pointers used for switchable kinematics
  hal_bit_t   *kinstype_is_0;
  hal_bit_t   *kinstype_is_1;
} *haldata;
static int XYZCB_tdr_setup(void) {
#define HAL_PREFIX "xyzcb_tdr_kins"
    int res=0;
    // inherit comp_id from rtapi_main()
    if (comp_id < 0) goto error;
    // set unready to allow creation of pins
    if (hal_set_unready(comp_id)) goto error;
    haldata = hal_malloc(sizeof(struct haldata));
    if (!haldata) goto error;
    // hal pins required for XYZCB_tdr kinematics:
    res += hal_pin_float_newf(HAL_IN ,&(haldata->tool_offset_z) ,comp_id,"%s.tool-offset-z" ,HAL_PREFIX);
    res += hal_pin_float_newf(HAL_IN ,&(haldata->x_offset) ,comp_id,"%s.x-offset" ,HAL_PREFIX);
    res += hal_pin_float_newf(HAL_IN ,&(haldata->z_offset) ,comp_id,"%s.z-offset" ,HAL_PREFIX);
    res += hal_pin_float_newf(HAL_IN ,&haldata->x_rot_point ,comp_id,"%s.x-rot-point" ,HAL_PREFIX);
    res += hal_pin_float_newf(HAL_IN ,&haldata->y_rot_point ,comp_id,"%s.y-rot-point" ,HAL_PREFIX);
    res += hal_pin_float_newf(HAL_IN ,&haldata->z_rot_point ,comp_id,"%s.z-rot-point" ,HAL_PREFIX);
    // hal pins required for switchable kinematics:
    res += hal_pin_bit_new("kinstype.is-0", HAL_OUT, &(haldata->kinstype_is_0), comp_id);
    res += hal_pin_bit_new("kinstype.is-1", HAL_OUT, &(haldata->kinstype_is_1), comp_id);
    // define default kinematics at startup for switchable kinematics
    *haldata->kinstype_is_0 = 1; //default at startup -> identity kinematics
    *haldata->kinstype_is_1 = 0; //-> XYZCB TCP
    if (res) goto error;
    hal_ready(comp_id);
    rtapi_print("*** %s setup ok\n",__FILE__);
    return 0;
error:
    rtapi_print("\n!!! %s setup failed res=%d\n\n",__FILE__,res);
    return -1;
#undef HAL_PREFIX
EXPORT_SYMBOL(kinematicsType);
EXPORT_SYMBOL(kinematicsSwitchable);
EXPORT_SYMBOL(kinematicsSwitch);
EXPORT_SYMBOL(kinematicsInverse);
EXPORT_SYMBOL(kinematicsForward);
static hal_u32_t switchkins_type;
int kinematicsSwitchable() {return 1;}
int kinematicsSwitch(int new_switchkins_type)
    switchkins_type = new_switchkins_type;
    rtapi_print("kinematicsSwitch(): type=%d\n",switchkins_type);
    // create case structure for switchable kinematics
    switch (switchkins_type) {
        case 0: rtapi_print_msg(RTAPI_MSG_INFO,
                "kinematicsSwitch:TYPE0\n");
                break;
        case 1: rtapi_print_msg(RTAPI_MSG_INFO,
                "kinematicsSwitch:TYPE1\n");
                *haldata->kinstype_is_0 = 0;
                *haldata->kinstype_is_1 = 1;
                break;
       default: rtapi_print_msg(RTAPI_MSG_ERR,
                "kinematicsSwitch:BAD VALUE <%d>\n",
                switchkins_type);
                return -1; // FAIL
    return 0; // ok
KINEMATICS_TYPE kinematicsType()
static bool is_setup=0;
    if (!is_setup)  XYZCB_tdr_setup();
    return KINEMATICS_BOTH; // set as required
           // Note: If kinematics are identity, using KINEMATICS_BOTH
           //       may be used in order to allow a gui to display
           //       joint values in preview prior to homing
} // kinematicsType()
int kinematicsForward(const double *j,
                      EmcPose * pos,
                      const KINEMATICS_FORWARD_FLAGS * fflags,
                      KINEMATICS_INVERSE_FLAGS * iflags)
    (void)fflags;
    (void)iflags;
    double x_rot_point = *(haldata->x_rot_point);
    double y_rot_point = *(haldata->y_rot_point);
    double z_rot_point = *(haldata->z_rot_point);
    double dz = *(haldata->z_offset);
    double dt = *(haldata->tool_offset_z);
    // substitutions as used in mathematical documentation
    // including degree -> radians angle conversion
    double       sc = sin(j[3]*TO_RAD);
    double       cc = cos(j[3]*TO_RAD);
    double       sb = sin(j[4]*TO_RAD);
    double       cb = cos(j[4]*TO_RAD);
    // used to be consistent with math in the documentation
    double       px = 0;
    double       py = 0;
    double       pz = 0;
    #define DEFAULT_ANGLE   (60.0)
    // define forward kinematic models using case structure for
    // for switchable kinematics
        case 0: // ====================== IDENTITY kinematics FORWARD ====================
            double angle = *(haldata->angleXX) * PM_PI / 180.0;
            pos->tran.x =   j[0] + j[1] * cos(angle)
            pos->tran.y = - j[1] * sin(angle);
            pos->tran.z =   j[2];
            pos->c      =   j[3];
            pos->b      =   j[4];
            break;
        case 1: // ========================= TCP kinematics FORWARD ======================
            px          =    j[0] - x_rot_point + j[1] * cos(angle);
            py          = - (j[1] - y_rot_point) * sin(angle);
            pz          =    j[2] - z_rot_point - dt;
            pos->tran.x =   cb * (cc * px - sc * py) + sb * pz + x_rot_point;
            pos->tran.y =   sc * px + cc * py + y_rot_point;
            pos->tran.z =  -sb * (cc * px - sc * py) + cb * pz + z_rot_point + dz + dt;
            pos->c      = j[3];
            pos->b      = j[4];
            break;
    // unused coordinates:
    pos->a = 0;
    pos->u = 0;
    pos->v = 0;
    pos->w = 0;
    return 0;
} // kinematicsForward()
int kinematicsInverse(const EmcPose * pos,
                      double *j,
                      const KINEMATICS_INVERSE_FLAGS * iflags,
                      KINEMATICS_FORWARD_FLAGS * fflags)
    (void)iflags;
    (void)fflags;
    double dx = *(haldata->x_offset);
    double       sc = sin(pos->c*TO_RAD);
    double       cc = cos(pos->c*TO_RAD);
    double       sb = sin(pos->b*TO_RAD);
    double       cb = cos(pos->b*TO_RAD);
    double       qx = 0;
    double       qy = 0;
    double       qz = 0;
        case 0:// ====================== IDENTITY kinematics INVERSE =====================
            j[0] =   pos->tran.x + pos->tran.y / tan(angle);
            j[1] = - pos->tran.y / sin(angle);
            j[2] =   pos->tran.z;
            j[3] =   pos->c;
            j[4] =   pos->b;
            break;
        case 1: // ========================= TCP kinematics INVERSE ======================
            qx   = pos->tran.x - x_rot_point - dx;
            qy   = pos->tran.y - y_rot_point;
            qz   = pos->tran.z - z_rot_point - dz - dt;
            // Hier integrieren wir die virtuelle Achse (pos->tran.y) wie im Identity-Fall:
            double qx_virtual = qx + qy / tan(angle);
            double qy_virtual = -qy / sin(angle);
            j[0] = cc * (cb * qx_virtual - sb * qz) + sc * qy_virtual + cb * dx - sb * dz + x_rot_point;
            j[1] = -sc * (cb * qx_virtual - sb * qz) + cc * qy_virtual + y_rot_point;
            j[2] = sb * qx_virtual + cb * qz + sb * dx + cb * dz + z_rot_point + dt;
            j[3] = pos->c;
            j[4] = pos->b;
            break;
    return 0;
} // kinematicsInverse()
  • endian
  • endian's Avatar
11 Apr 2025 20:10
Replied by endian on topic Strange behaviour of custom component
Yes I have to start ... I have planty of ideas but I am aware little bit to code them over halcompile...
Yes defenetly I am interested even in all which should improve our skills ... can you provide me them please?
thanks...
  • pgf
  • pgf
11 Apr 2025 19:58
Category: HAL
Thanks. Seems like that restriction is a little too restrictive sometimes. :-/
But surely there's some other, event driven, mechanism, which wouldn't involve polling the pin every second or more?
Displaying 16831 - 16845 out of 17636 results.
Time to create page: 0.460 seconds
