07 Apr 2025 06:28
Replied by tommylight on topic Encoder on 7i95t
Encoder on 7i95t
ENCODER_SCALE = 1
This should be 4 times the encoder PPR divided by the total distance moved for one rotation.
  • Z3rni3
  • Z3rni3
07 Apr 2025 06:17
Replied by Z3rni3 on topic Encoder on 7i95t
Encoder on 7i95t
I've been following this excellent step-by-step guide, but I'm currently stuck with a problem: the DRO is off by a factor of 1000. When I move the machine by one leadscrew rotation—which should be 4 mm (since it's a 4 mm/rev leadscrew)—the DRO now shows 4000 mm instead.Previously, it correctly showed 4 mm, so something must have changed, but I can't figure out what. Could someone please take a look at my configuration files?
  • Diegot
  • Diegot's Avatar
07 Apr 2025 05:24
Latency, error finishing read, and IRQ affinity
I just discovery tuna, realtime IRQ tuning, my first impression was great.
Just test it at buster, going to bookworm now.
packages.debian.org/bookworm/tuna
  • Z3rni3
  • Z3rni3
07 Apr 2025 05:11
Encoder on 7i95t
Thanks for the tipps on tuning.
I saw that in a Talla83s Video and found it very helpful!
  • Z3rni3
  • Z3rni3
07 Apr 2025 05:10
Encoder on 7i95t
I've got a working config without Encoder input!
That link is very helpful. I'll be following it later today!
Thank you very much!
  • jenkinson8
  • jenkinson8
07 Apr 2025 02:25
Replied by jenkinson8 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Sure, when I did this, I uploaded the unmodified nvem-full-config.txt - from the Remora repo.
Reading the upload script, it looks like it makes a copy of what I feed into it and writes it to this config.txt file? Comparing the two documents showed them as identical.
Contents of the file to sense check:
    "Board": "NVEM",
    "Modules":[
    "Thread": "Base",
    "Type": "Stepgen",
        "Comment":            "X - Joint 0 step generator",
        "Joint Number":        0,
        "Step Pin":         "PE_15",
        "Direction Pin":     "PE_14"
    "Thread": "Base",
    "Type": "Stepgen",
        "Comment":            "Y - Joint 1 step generator",
        "Joint Number":        1,
        "Step Pin":         "PE_13",
        "Direction Pin":     "PE_12"
    "Thread": "Base",
    "Type": "Stepgen",
        "Comment":            "Z - Joint 2 step generator",
        "Joint Number":        2,
        "Step Pin":         "PE_11",
        "Direction Pin":     "PE_10"
    "Thread": "Base",
    "Type": "Stepgen",
        "Comment":            "A - Joint 3 step generator",
        "Joint Number":        3,
        "Step Pin":         "PE_9",
        "Direction Pin":     "PE_8"
    "Thread": "Base",
    "Type": "Stepgen",
        "Comment":            "B - Joint 4 step generator",
        "Joint Number":        4,
        "Step Pin":         "PE_7",
        "Direction Pin":     "PA_8"
    "Thread": "Base",
    "Type": "Stepgen",
        "Comment":            "C - Joint 5 step generator",
        "Joint Number":        5,
        "Step Pin":         "PA_5",
        "Direction Pin":     "PA_6"
    "Thread": "Servo",
    "Type": "Digital Pin",
        "Comment":            "FHA",
        "Pin":                "PD_12",
        "Mode":                "Input",
        "Data Bit":            0,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "FHB",
        "Pin":                "PD_13",
        "Mode":                "Input",
        "Data Bit":            1,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "SRO",
        "Pin":                "PB_14",
        "Mode":                "Input",
        "Data Bit":            2,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "SJR",
        "Pin":                "PB_15",
        "Mode":                "Input",
        "Data Bit":            3,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "STOP",
        "Pin":                "PD_8",
        "Mode":                "Input",
        "Data Bit":            4,
        "Invert":            "False"
    "Thread": "Servo",
        "Comment":            "PROBE",
        "Pin":                "PD_9",
        "Mode":                "Input",
        "Data Bit":            5,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "INP3",
        "Pin":                "PD_10",
        "Mode":                "Input",
        "Data Bit":            6,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "INP4",
        "Pin":                "PD_11",
        "Mode":                "Input",
        "Data Bit":            7,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "INP5",
        "Pin":                "PD_14",
        "Mode":                "Input",
        "Data Bit":            8,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "INP6",
        "Pin":                "PD_15",
        "Mode":                "Input",
        "Data Bit":            9,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "INP7",
        "Pin":                "PC_6",
        "Mode":                "Input",
        "Data Bit":            10,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "INP8",
        "Pin":                "PC_7",
        "Mode":                "Input",
        "Data Bit":            11,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "INP9",
        "Pin":                "PC_8",
        "Mode":                "Input",
        "Data Bit":            12,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "INP10",
        "Pin":                "PC_9",
        "Mode":                "Input",
        "Data Bit":            13,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "INP11",
        "Pin":                "PA_11",
        "Mode":                "Input",
        "Data Bit":            14,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "INP12",
        "Pin":                "PA_12",
        "Mode":                "Input",
        "Data Bit":            15,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "INDEX",
        "Pin":                "PC_15",
        "Mode":                "Input",
        "Data Bit":            16,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "x100",
        "Pin":                "PA_15",
        "Mode":                "Input",
        "Data Bit":            17,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "x10",
        "Pin":                "PC_10",
        "Mode":                "Input",
        "Data Bit":            18,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "x1",
        "Pin":                "PC_11",
        "Mode":                "Input",
        "Data Bit":            19,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "ESTOP",
        "Pin":                "PC_12",
        "Mode":                "Input",
        "Data Bit":            20,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "Xin",
        "Pin":                "PD_7",
        "Mode":                "Input",
        "Data Bit":            21,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "Yin",
        "Pin":                "PD_4",
        "Mode":                "Input",
        "Data Bit":            22,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "Zin",
        "Pin":                "PD_3",
        "Mode":                "Input",
        "Data Bit":            23,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "Ain",
        "Pin":                "PD_2",
        "Mode":                "Input",
        "Data Bit":            24,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "Bin",
        "Pin":                "PD_1",
        "Mode":                "Input",
        "Data Bit":            25,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "Cin",
        "Pin":                "PD_0",
        "Mode":                "Input",
        "Data Bit":            26,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "WHA",
        "Pin":                "PB_7",
        "Mode":                "Input",
        "Data Bit":            27,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "WHB",
        "Pin":                "PB_6",
        "Mode":                "Input",
        "Data Bit":            28,
        "Invert":            "True"
    "Thread": "Servo",
        "Comment":            "OUT1",
        "Pin":                "PC_3",
        "Mode":                "Output",
        "Data Bit":            0
    "Thread": "Servo",
        "Comment":            "OUT2",
        "Pin":                "PC_2",
        "Mode":                "Output",
        "Data Bit":            1
    "Thread": "Servo",
        "Comment":            "OUT3",
        "Pin":                "PB_8",
        "Mode":                "Output",
        "Data Bit":            2
    "Thread": "Servo",
        "Comment":            "OUT4",
        "Pin":                "PB_9",
        "Mode":                "Output",
        "Data Bit":            3
    "Thread": "Servo",
        "Comment":            "OUT5",
        "Pin":                "PE_0",
        "Mode":                "Output",
        "Data Bit":            4
    "Thread": "Servo",
        "Comment":            "OUT6",
        "Pin":                "PE_1",
        "Mode":                "Output",
        "Data Bit":            5
    "Thread": "Servo",
        "Comment":            "OUT7",
        "Pin":                "PE_2",
        "Mode":                "Output",
        "Data Bit":            6
    "Thread": "Servo",
        "Comment":            "OUT8",
        "Pin":                "PE_3",
        "Mode":                "Output",
        "Data Bit":            7
    "Thread": "Servo",
        "Comment":            "OUT9",
        "Pin":                "PC_13",
        "Mode":                "Output",
        "Data Bit":            8
    "Thread": "Servo",
        "Comment":            "OUT10",
        "Pin":                "PC_14",
        "Mode":                "Output",
        "Data Bit":            9
    "Thread": "Servo",
    "Type": "Spindle PWM",
        "Comment":            "Spindle PWM",
        "SP[i]":            0
    "Thread": "Servo",
    "Type": "NVMPG",
        "Comment":            "NVMPG"
Something else worth mentioning, I had read that the 4/5/6 axis boards used the same hardware, and that Remora doesn't care which version of the board you get. I bought a 4 axis version as the others were more expensive for seemingly no value add if used with Remora. I did use my multimeter and could trace the 5 and 6 axis step/dir pins back to what looks like a buffer IC at least. Hopefully I don't have some later version of the board that has additional locks in place.
  • Soccer Kid
  • Soccer Kid's Avatar
07 Apr 2025 02:21
Replied by Soccer Kid on topic question of Homing
question of Homing
Category: EtherCAT
In fact, with torque control, I don't think Linuxcnc is up to the task, you should choose OMRON..... PMAC controller.
  • Soccer Kid
07 Apr 2025 02:01
Replied by Soccer Kid on topic EL7041-1000 configuration question
Category: EtherCAT
Usually, the controller with a position closed-loop, the generation of following errors, and the PID controller of the upper computer, has little to do with it, because the position loop can be adjusted in the drive. At the same time, the following error = the maximum feed speed is proportional to the position loop gain
  • Soccer Kid
07 Apr 2025 01:58
Category: EtherCAT
You should get the vendor's ethercat definition, which provides the scaling function....
07 Apr 2025 01:35
Replied by tommylight on topic Spindle control not showing in Axis window...
Category: Basic Configuration
Oh so those are now all in one file?
There were 3 back then, quick start, documentation and integrator's manual.
I recall thinking "how is this software under 5MB in size while documentation is nearly 30MB???"
Good times.
  • rodw
  • rodw's Avatar
07 Apr 2025 00:46 - 07 Apr 2025 00:46
Just a heads up. Tommy's link is to Linuxcnc v 2.6 and our release version is now 2.9 so it will be obsolete in places.
The PDF files are available from the Documention page but are just a copy of the content in the HTML version which I tend to use in preference,
But none the less I too was gobsmacked when starting off to find the documentation runs to 1347 pages!
2.9 version: linuxcnc.org/docs/stable/pdf/LinuxCNC_Documentation.pdf
  • cmorley
  • cmorley
06 Apr 2025 23:43
  • cakeslob
  • cakeslob
06 Apr 2025 22:06
What part worked?
The motors will move even if the TMC doesnt configure. motor0 and motor 1 are connected to the same output buffer, if the buffer is damaged motors0 and 1 wont get the enable signal it looks like
  • B1gJ1mmy
  • B1gJ1mmy
06 Apr 2025 21:56
Yet another LinuxCNC noob with a PCI card as Port1 issue.
Hi. Thanks for your help after a new cable this is now working.
However I noticed and issue with Stepconf wizard. It will not allow you to have multiple outputs as enable. If I set pins on the second breakout board to enable those setting are not reflected in the HAL file. However If I manually create the line for port1 then enable works on the second card.
Unsure if this is correct behaviour. This may also be why I could not get the Breakout board working. Just possibly a trap for new players. It is tempting to use enable as the test for the breakout board as you have access to switch it from the main panel without running any gcode. But without manual intervention this will not work.
Thanks.
  • gmouer
  • gmouer
06 Apr 2025 21:52
Replied by gmouer on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
That last piece of the puzzle did it !!!!!!!
It now  launches, embedded.
Thanks so much for all the help !          Hopefully others will benefit from this adventure.
The Nativecam looks to be a newer version than the one I have been using.   Now I have to get current with the changes over time.
Displaying 17071 - 17085 out of 17639 results.
Time to create page: 0.721 seconds
