  • B1gJ1mmy
  • B1gJ1mmy
01 Apr 2025 12:32
Yet another LinuxCNC noob with a PCI card as Port1 issue.
yes the cable goes one to one for every pin. I re-tested it tonight confirmed all pins go straight through. Is this normal? As far as I know it should be? Serial cables should flip Rx to Tx as far as I'm aware.
  • Routerworks
  • Routerworks
01 Apr 2025 12:23
Replied by Routerworks on topic Need help setting up XYYZA for stepper motors
Ok, I'll try it.
Are you saying I can use 1 stepgen and connect it to 2 drivers in the HAL file?  This is different that physically wiring the one output to two drivers.  This sounds better if it will work as I can't be sure 2 stepgen signals driving the same axis are in phase with eachother.
Thanks, I'll let you know what happens.
  • unknown
  • unknown
01 Apr 2025 11:57
Replied by unknown on topic The dumification of humanity through internet
I'm going to put my hand up for dumbness.
Designed a PCB using 0603 caps & resistors........stupid me didn't change the pad size to suit hand soldering. Luckily it was only like $6 or $7 dollar mistake.
Thought about building a PnP machine......last thing I need is another side project.
  • emcPT
  • emcPT's Avatar
01 Apr 2025 11:53 - 01 Apr 2025 11:53
More economic European shipping was created by emcPT
Category: User Exchange
Good morning.
We established a cooperation with UPS for truck/road transport what hopefully will reach more destinations with a lower cost.
Unfortunately is only valid for shipments inside the Euro zone.
For outside the eurozone we currently we only offer DHL express - that works very good, but not inexpensive.
We currently have almost all Mesa boards - linuxcnc related - in stock
  • unknown
  • unknown
01 Apr 2025 11:53
No one can seem to agree on anything.
en.wikipedia.org/wiki/Billion
I suppose the lower number of zeros lets you be a billionaire quicker. hahaha
Yeah I've seen that optocoupler thing quite a few times in schematics.
  • unknown
  • unknown
01 Apr 2025 11:48
Does the cable go one to one all 25 pins, they might have sent a serial cable.
Sometimes you just have to bite the bullet and get the PC onto a workbench, no matter how much of a PITA it is.
  • SergeyHM
  • SergeyHM
01 Apr 2025 11:13
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
Hi everyoneI have a long initialization of Ethercat on a machine with 7 inovance SV660N servo drivers. I tried different Servoperiods. Sometimes some servo drivers do not initialize - they remain in PreOP. What could be the reason? Maybe someone has encountered this?
LinuxCNC 2.8.4 + ethercat-master 1.6.3
  • B1gJ1mmy
  • B1gJ1mmy
01 Apr 2025 10:45
We might have a bad cable lads.
I made up this connected to 13 12 11 directly on the card.
And using the port test app on 0xec00 with the sun1888 installed the ports go to ground when touched to the chassis
this does not happen when the same home made plug is connected at the end of the cable.
Something is screwed up with the cable for sure if it should be straight through
  • rodw
  • rodw's Avatar
01 Apr 2025 09:53
Replied by rodw on topic LinuxCNC S-Curve Accelerations
Very Good Grotius!
If you could just make a .deb file that installed the planner, you could host it here
packagecloud.io/
I had a version of the Ethercat hal driver there which the Linuxcnc ISO installer used until the etherlab guys started hosting it.
  • D Jensen
  • D Jensen
01 Apr 2025 09:36
Replied by D Jensen on topic Retrofitting a 1986 Maho MH400E
Category: Milling Machines
Hi Guys,
Finally had a try at putting stuff on YouTube so I don't mess up the LinuxCNC area so much. It's very much a novice start since i don't know much about it. Pretty raw videos, but I just wanted to see if I could explain stuff and encourage folk to resurrect the old machines. A few plugs to go to LinuxCNC in there. I don't even know how to name it in a way it might be found. If you hunt for "resurrecting a Maho MH 700 C"  you might find it. I've tried to set up a playlist so the videos can be watched in order, but it doesn't seem to work all that well. To my surprise some folk have found it and watched some of it! Ideas on how to do it better would be welcome. There are a couple of other playlists I'd like to do once on a roll. One on my "bat cave" as my great nephew calls it, and another on a rare Topolino I'm restoring that has been put aside due to Covid, then the Maho. I think there is a rule on "mens sheds" that if you make it N in area it needs to be 2 x N no matter how big N is.
Cheers,
David
  • slowpoke
  • slowpoke
01 Apr 2025 08:30
Replied by slowpoke on topic Autostart Axis
Autostart Axis
Aciera,
Thank you works like a charm.
  • Grotius
  • Grotius's Avatar
01 Apr 2025 07:28
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
@Tommy,
For your machines, you cut the steel plates for your machine's yourself and do hydraulic press bending the sheet metal too yourself?
What could be the reason  the business is quiet?
  • 电动葫芦
  • 电动葫芦
01 Apr 2025 06:09
qtplasmac M03 was created by 电动葫芦
qtplasmac M03
Category: Plasmac
"Hello! In qtplasmac, modify the M03 function to not require Z-axis descent. Thank you."
  • Hakan
  • Hakan
01 Apr 2025 05:27
Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
Category: EtherCAT
The line I have is
 EtherCAT: Master driver 1.6.3 1.6.3.g805e407-1+15.2
but the latest is the "+15.3" waiting for me to upgrade.
Overall it is linuxcnc 2.9
I fought the UNMATCHED messages for my system.
It is caused by the network interface being...not fast enough for lack of better words.
Intel network adapters have always worked well for me.
Realtek adapters are almost always an issue
and some tweaks are needed. rodw has documented some of that.
  • Finngineering
  • Finngineering
01 Apr 2025 03:26
Replied by Finngineering on topic Un-lobotomizing a Maho MH600T
Category: CNC Machines
My scales have a marking showing where the index pulse should be (Referenzmarke), you can see that in the photo below. They are all close to the end.
Regarding my own interpolators, I already made a design change that makes the crowbar less sensitive to component values. I forgot to mention the in the previous post.
Do you vre have a thread about your machine? It would be interesting to see.
I have attached most of the configuration files and the components (the lubricator component in the previous post). The main "logic" and connections are in custom.hal. The geartrain component is naturally for handling the gearbox (18 speed), and the maho_spindle mainly to handle VFD communication (and verifying that communication is working). The idea at least for the geartrain and lubricator component is to keep them so generic that they could be used for other machines without or with little modification.
File Name: MH600T.ini
File Size:5 KB
File Name: MH600T.hal
File Size:11 KB
File Name: custom.hal
File Size:9 KB
File Name: geartrain.comp
File Size:15 KB
File Name: maho_spindle.comp
File Size:3 KB
Displaying 17431 - 17445 out of 17655 results.
Time to create page: 0.407 seconds
