  • Todd Zuercher
  • Todd Zuercher's Avatar
31 Mar 2025 17:05
Replied by Todd Zuercher on topic Activity Light
Activity Light
Maybe the hal pin "halui.program.is-running" might be more like what he is after?
  • ErrickW
  • ErrickW
31 Mar 2025 16:58
Replied by ErrickW on topic The end of my business. Parts up for Auction
Category: User Exchange
25 Years of machinery service, retrofits and custom machinery means nothing to guys wearing suits that have a "don't you know who I am? I can do what I want" attitude. It's a long story but $4.7M in contracts canceled by a prick. If I could afford a lawyer we would be in court over it.
  • Wagon56
  • Wagon56
31 Mar 2025 16:44
Replied by Wagon56 on topic Configuring 6 axis robot arm with lcnc
Category: HAL
Hey, yeah its been an insane learning curve but im happy to say i figured it out, i have the robot arm pretty much working at the moment, got 6 tmc 5160 drivers connected to the PI5 and am using an arduino for SPI to configure the drivers (i wouldnt have enough pins for toolheads if i used the Pi's SPI interface). Right now all i need to figure out is the DH parameters of the arm itself and some scaling stuff but that shouldnt be too difficult, i had another question though, is it a good idea atall to run 6 stepper motors with step/dir controls using the pi5? im not sure if its powerful enough to do it consistently, i get movement on all the motors with no problem i just dont know how reliable thats gonna be in the long run, maybe running the tmc5160's in SPI mode would be easier if i were to let them do their own stepgen, that would be a whole other learning process too although it might be better
  • Wiesi-94
  • Wiesi-94
31 Mar 2025 16:35
Replied by Wiesi-94 on topic Read the S-Command in the HAL
Category: HAL
That works, thanks!!
  • ContinenteCNC
  • ContinenteCNC's Avatar
31 Mar 2025 16:30
Replied by ContinenteCNC on topic Parallel Port Tester
If anyone needs, these are my custom parallel port tester hal files for IN, and X modes.
  • endian
  • endian's Avatar
31 Mar 2025 16:09 - 31 Mar 2025 16:11
Replied by endian on topic LinuxCNC S-Curve Accelerations
Why Wine?
Configuration software for Kollmorgen servo drivers are only for win7 and I do not want to use more PCs or virtual stuff on my lcnc ...
Tommy what any news with the servo stuff from your workshop? do you have any new pieces?
  • snowgoer540
  • snowgoer540's Avatar
31 Mar 2025 16:02
Replied by snowgoer540 on topic Couldn't get the WARNING icon in LcncDialog
Category: Qtvcp
It might be helpful to know how you are calling it?
  • konrad
  • konrad
31 Mar 2025 14:58
Replied by konrad on topic config all good on mesa 7i96s?
Edit seems to brake the original post, ini was missing
  • konrad
  • konrad
31 Mar 2025 14:54
config all good on mesa 7i96s? was created by konrad
Hello everyone,I've recently converted a second hand CNC router from Mach3 with ESS to LinuxCNC with a Mesa 7i96s board. I've used PNCconf to generate my initial configuration, but I'd appreciate if someone could review my settings and let me know if everything looks okay.Machine Specs:
  • X460, Y750mm, Z300
  • 20mm linear rails
  • 10mm pitch ballscrews, 20mm diameter
  • Construction: aluminum profiles bolted to 12mm steel plates, welded gantry sides
  • Motors: Y-axis 6.8Nm stepper, Z + X-axis 3Nm stepper
  • Drives: DM556 V1 48v
  • Spindle: 24K RPM 2.2kW ER20
  • inductive endstops
  • good latency values mostly sub 3000ns servo
PNCconf Settings:
  • Step On-Time: 5000 nanoseconds
  • Maximum Velocity: 3000 mm/min
  • Maximum Acceleration: 400 mm/sec²
Key Config Values from INI File:
  • X travel: -2.0mm to 460.0mm (STEP_SCALE = -200.0)
  • Y travel: -2.0mm to 750.0mm (STEP_SCALE = 200.0)
  • Z travel: -300.0mm to 0.01mm (STEP_SCALE = -400.0)
  • Step timing: DIRSETUP/DIRHOLD = 10000ns, STEPLEN/STEPSPACE = 5000ns
Questions:
  1. I see a
    z-neg-limit
    signal in my HAL file that doesn't seem to be connected to anything - is this a problem?
  2. Are my velocity and acceleration values reasonable for this type of machine?
  3. Any other issues or recommendations before I start cutting?
changes/upgrades
As I am already in the process of messing with the machine, would you recommend any meaningful upgrades or changes to it? I will mostly mill soft materials like wood but also want to try aluminium.
  1. should I change the microstepping ( it is 10x at the moment)
  2. other stepper motor or drivers?
  3. switch to s curve compact fork?
I've attached HAL and INI files below for reference. Thanks in advance for any advice!
  • JL_90
  • JL_90
31 Mar 2025 14:28
Replied by JL_90 on topic Pi 4 with Pi Touch Display
Category: Installing LinuxCNC
Hello, I've the same issue on Rpi5 but your solution do not work completely.
I've on the boot the DSI display working well but after starting, Linuxcnc switch to the HDMI and I do not find anything in the configuration to display on the DSI and on the HDMI.
Do I've miss something ?
31 Mar 2025 14:09
Replied by tommylight on topic Activity Light
Activity Light
Usable hal pins
amplifier-enable
machine-is-on
e-stop-out
x-enable
something like this
x-enable hm2_7i76e.0.7i76.0.0.output-00
Replace board and pins accordingly.
  • Dedeer
  • Dedeer
31 Mar 2025 13:59
Possible retrofit of a Körner Magic550 CNC Machine
Category: CNC Machines
Today i took some pictures of the machine . This is a small machine with a footprint of 120cm x140cm x 170cm but weighs a whooping 4000Kg. Its made from epoxy granit of some sort. The last picture is how the machine used to look ,it´s the only picture i found online.
  • unknown
  • unknown
31 Mar 2025 13:53
Yet another LinuxCNC noob with a PCI card as Port1 issue.
No worries mate, you not is Sydney are you ?
There's a couple of us here.
  • shasse
  • shasse
31 Mar 2025 13:33
Video of the first cut from our LinuxCNC-controlled 500W fiber laser
Category: Plasma & Laser
The project has been on a bit of a back burner for a while. Our current prototype cantilevered gantry wobbles enough that we need to get that sorted before doing more investigation on cut "feeds and speeds", etc. Everything is basically usable though.
  • chuckp47
  • chuckp47
31 Mar 2025 13:31
Activity Light was created by chuckp47
Activity Light
We would like our LinuxCNC system to control an activity light. This would be a red light on the machine active when the motors are engaged. Does LinuxCNC already have a feature to control such a thing? Where should I look to find the interface?
We are using a Mesa board and a Raspberry Pi. Can I route a control signal through to an output pin on the Mesa board?
Thank you.
Displaying 17476 - 17490 out of 17655 results.
Time to create page: 0.412 seconds
