02 Mar 2025 23:57
Replied by tommylight on topic Motion Control in the kernel
What? No swearing and cursing? :)
Very well worded, thank you Rod.
Makes me wonder, how come none of those there know about LinuxCNC???
We need some marketing, any ideas?
02 Mar 2025 23:53
Replied by tommylight on topic The dumification of humanity through internet
You are right about educated people, but at some point they stop and fight back, and if history is a frame of reference, almost always to late. :)
As for you, i do not agree at all, just your knowledge of computers sets you way above the "medium".
  • unknown
  • unknown
02 Mar 2025 22:22
Replied by unknown on topic The dumification of humanity through internet
Actually highly educated can be easily controlled as well. Would you like being told everything you've thought to be true is wrong. Would you like to be thinking in a way that would get you ridiculed .....even cancelled in this current climate ?
I don't think education is the full story, it's whether you want to take the time to look into things and question common beliefs. Being inquisitive is the key.
There's also the thing about wanting to fit in as well, many people want to fit in, I guess that comes down to human nature. Just because there's a consensus doesn't mean it's so.
By all metrics I'm classed as lowly educated.
  • unknown
  • unknown
02 Mar 2025 22:14
Replied by unknown on topic Motion Control in the kernel
It's on page 2.
Just reread the comments of the "experts".....hmmmm interesting
  • bigmactx
  • bigmactx's Avatar
02 Mar 2025 21:48
Replied by bigmactx on topic LinuxCNC 2.10 build
LinuxCNC 2.10 build
Category: Installing LinuxCNC
Thank you for your responses.
I tried the following:
DEB_BUILD_OPTIONS=nodocs dpkg-buildpackage -uc -B
DEB_BUILD_OPTIONS=nodocs dpkg-buildpackage -uc -b
and a few others but always get exactly the same result.
looking at man dpkg-buildpackage I see
-b equivalent to --build=binary or --build=any.all
-B equivalent to --build=any
nodocs isn't an option for DEB_BUILD_OPTIONS by default but it does note "that other options honored by debian/rules might be defined by distribution specific policies." So now I'm off chasing that down.
I also noted that under man dpkg-buildflags(1) there is some interesting info on fortify. I'll chase that later if that problem remains.
Could (I suspect) be distro related so I expect some settings/options will need to dialed in.
  • MaHa
  • MaHa
02 Mar 2025 21:44
G7x and profile in subroutine with parameters
Category: G&M Codes
M2 should always be outside a subroutine, so place M2 after each endsub, and your construct should work.
As you can only use 2 variables, and there is no option to enter a global variable in MDI, it will be difficult to bring the values to your code.
The contur o100sub is in the macro file. If you keep it like that, you need to modify in the macrofile anyway. how about use the default values #3 #4 #5 as this might not change often, only submit #1 and #2 as variable.
02 Mar 2025 21:38
Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Category: Deutsch
raspi-firmware: missing /boot/firmware, did you forget to mount it?
How did this get on the official ISO, again??????
Try this
forum.linuxcnc.org/9-installing-linuxcnc...error?start=0#292426
  • rodw
  • rodw's Avatar
02 Mar 2025 21:38
Category: Deutsch
Problem 1
This is an annoying bug in Debian outside of our control which we tried to work around.
Try
sudo apt update
sudo dpkg -P raspi-firmware
Problem 2
Try my installation notes (English I am sorry)
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
  • FraesPaul
  • FraesPaul
02 Mar 2025 21:19 - 02 Mar 2025 21:23
Category: Deutsch
Hallo Zusammen,
ich installiere zur Zeit einen Rechner mit der aktuellen 2.9.4 Iso
und habe ein paar Probleme.
Der Rechner hat ein Fujitsu D3220 Board mit i3 / 3,4Ghz , 16 Gb Ram und  Parallelport
1. Problem
Die Installation läuft erst einmal fehlerfrei, allerdings kommt beim Update
folgender Fehler:
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut… Fertig
Statusinformationen werden eingelesen… Fertig
Paketaktualisierung (Upgrade) wird berechnet… Fertig
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
2 nicht vollständig installiert oder entfernt.
Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
Möchten Sie fortfahren? [J/n] j
linux-image-6.1.0-31-rt-amd64 (6.1.128-1) wird eingerichtet ...
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.0-31-rt-amd64.
dkms: autoinstall for kernel: 6.1.0-31-rt-amd64.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.1.0-31-rt-amd64
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return c
ode 1
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: Fehler beim Bearbeiten des Paketes linux-image-6.1.0-31-rt-amd64 (--config
ure):
 »installiertes post-installation-Skript des Paketes linux-image-6.1.0-31-rt-amd
64«-Unterprozess gab den Fehlerwert 1 zurück
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von linux-image-rt-amd64:
 linux-image-rt-amd64 hängt ab von linux-image-6.1.0-31-rt-amd64 (= 6.1.128-1);
aber:
  Paket linux-image-6.1.0-31-rt-amd64 ist noch nicht konfiguriert.
dpkg: Fehler beim Bearbeiten des Paketes linux-image-rt-amd64 (--configure):
 Abhängigkeitsprobleme - verbleibt unkonfiguriert
Fehler traten auf beim Bearbeiten von:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Keine Ahnung was das zu bedeuten hat
und ob das vllt. die Ursache für die anderen Fehler ist
2.Problem
Der Latency Test zeigt , wie ich meine, sehr gute Werte
(Ich habe zur Sicherheit 30.000 im Stepconfig eingestellt)
aber wenn ich das Programm starte gibt es gelegentlich Ausreißer und eine Warnmeldung das der Wert
über 100.000 liegt.
Im BIOS habe ich ein paar Einstellungen probiert, was aber nicht geholfen hat
3.Problem
Wenn ich die Maschine ( CNC-STEP Zero3 ) mit Stepconfig konfiguriere
so bekomme ich sie mit gmocappy zum laufen.
Wenn ich allerdings, ohne weitere Änderungen auf die schönere QTdragon Oberfläche umschalte weigert sie sich.
Die LED der Ladungspumpe geht nicht an, diese scheint nicht aktiv zu sein
4.Problem
ich wollte noch DXF2Gcode nacht dieser Anleitung
github.com/ltspicer/dxf2gcode.linux.installer
installieren
Da kommen aber auch nur, für mich, kryptische Fehlermeldungen
  • ihavenofish
  • ihavenofish
02 Mar 2025 21:16
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
ok, z motor hooked up and powered.
im basically lost at this point.
anyone want to walk me through or point me to nice simple sequential "do this then this" instructions?
as of right now i did the ethercat install, and nothing much else. if i type ethercat slaves in the terminal it shows me nothing.
here is my drive manual
www.megatech.ro/doc/590/Accurax%20G5%20w...20Users%20Manual.pdf
thanks!
  • Rilexer
  • Rilexer
02 Mar 2025 20:43
Hello,
Does anybody know how data is formatted for NVMPG to display XYZ data, etc.?
I wanted to use this mpg in another project, but I cannot make it work from source files for stm32 and linuxCNC.
If anybody has a spreadsheet of these signals or a logic analyzer to see what is going to the mpg, I would be grateful, and I could make a tutorial about using it for other stuff as a cheaper alternative to other mpg.
All I know for sure at the moment is the baudrate and button codes, but it was an easy part of it...
Thank you in advance
  • rodw
  • rodw's Avatar
02 Mar 2025 20:23
Replied by rodw on topic Motion Control in the kernel
I think it needs to be approved but there is a link that takes you through to the comments on their forum.
  • rodw
  • rodw's Avatar
02 Mar 2025 20:19
Replied by rodw on topic LinuxCNC 2.10 build
LinuxCNC 2.10 build
As Tommy said, balls screws are a poor choice as you can't get the speed out of them and they whip.
Either belts or rack and pinion (with 3:1 to 5:1 reduction)
nodocs has changed. refer the docs :)
linuxcnc.org/docs/devel/html/code/buildi...nc.html#_build_modes
  • MalteS
  • MalteS
02 Mar 2025 20:10 - 02 Mar 2025 20:10
Category: G&M Codes
If there is interest. The full code is shown below (bear with me - comments are a mixture of German and English :-):
O<g7x_macro> sub
; #1 b_Modus                            (todo)
; #2 ae - Arbeitseingriff (Zustellung)  (0.5mm)
; #3 Feed per revolution                (0.1mm/u)
; #4 Surface speed (vc)                 (50m/min)
; #5 Max RPM                            (1400)
; Set default values
O100 IF  [#2 EQ 0]
    #2 = 0.5
O100 ENDIF
O101 IF  [#3 EQ 0]
    #3 = 0.1
O101 ENDIF
O102 IF  [#4 EQ 0]
    #4 = 50
O102 ENDIF
O103 IF  [#5 EQ 0]
    #5 = 1400
O103 ENDIF
(Allgemeiner Header)
G8 ; Lathe Diameter Mode
G18 ; XZ Plane
G21 ; Metric Units
G90 ; Absolute Distance
(Spindle Steuerung)
G96 D#5 S#4 ; Constant Surface Speed Mode
M3
G95 F#3 ; Feed-Per-Rev Mode
G4 P.2        ; Wait to reach speed
(Anfangspositionen merken)
#<x_start> = #<_x>
#<z_start> = #<_z>
G71.1 Q100 D[#2 / 2] I#2
G70   Q100 D[#2 / 2]
M5
M2
O<g7x_macro> endsub
O100 SUB
  G0 X5 Z0
  G0 x5 z-11.5
  G0 x10 Z-14
O100 ENDSUB
  • rodw
  • rodw's Avatar
02 Mar 2025 20:08
Replied by rodw on topic Safety Light
Safety Light
Category: Plasmac
The attached is old hal code that Todd helped me with  which uses, red, orange and green lights. The green light flashed (via siggen) when a program was paused. red was from the estop
The Run/Step/Pause/Resume part is described in hal examples on the forum but it won't work with QTplasmac which has its own pins that achieve a similar result.
Her is and example of it running. I did eventually wire this into some stack lights like you show,
Displaying 18136 - 18150 out of 18756 results.
Time to create page: 0.414 seconds
