  • itsbrian
  • itsbrian
21 Dec 2024 22:38
Replied by itsbrian on topic linuxcnc 2.9.2 (live) on the intel n100 cpu
Did you try isolcpus=3
isolcpus 1,2,3 leaves only one CPU for non-realtime tasks so
would likely be painfully slow...
Funny enough, isolcpus=3 and all the BIOS settings disabled I mentioned in my previous post is the final setup I'm going with. It holds steady at low 20μs and am able to multitask fine.
One thing I want to mention though is I was curious what Macanix and gambaf meant in this thread about mozmck's irq affinity hack being necessary. I see what they are talking about now when I started testing the Mesa card. All the issues mentioned in mozmck's thread is what I ran into along with some other threads, but it is running great now after applying the script!
If this thing had a built in parallel port, I think this would be a great, modern LinuxCNC device!
  • itsbrian
  • itsbrian
21 Dec 2024 22:20 - 21 Dec 2024 22:24
Latency, error finishing read, and IRQ affinity
Thanks mozmck for all this info and the bash scripts! This solved the weird issues I was running with on this new N100 PC I have.
I decided to brush up on my bash skills and update the original script.
Features
  • Checks that script is being run as root/sudo.
  • Attempts to ping the common Mesa card IP addresses (192.168.1.121 and 10.10.10.10) and if it finds a unique one it will set that as the NIC variable in the irq bash scripts. If it doesn't find one it lists the possible options for the user to choose.
    • Downside of this is that it is not as dynamic as mozmck's script if there are any Mesa card interfaces changes, but I figured people rarely change that anyways.
  • Give instructions once the script is complete.
How to run
  • Rename rt_setup.sh.txt to rt_setup.sh
  • Make sure script is executable via command line:
    chmod +x /path/to/rt_setup.sh
    Replace /path/to/rt_setup.sh to where the actual file is.
  • Run script:
    sudo /path/to/rt_setup.sh
    Again replace to where the actual path of the script is
Hopefully this helps those that are not software savvy!
  • scotta
  • scotta's Avatar
21 Dec 2024 21:27
Some new Linux CNC board by Bigtreetech looks cool still trying to get more info
TMC SPI support is something I've always wanted to get up and going in Remora. My time is starting to free up with the new job being less demanding, always happy to receive hardware to work on. The SKR3 you sent is sitting next to me now with debug wires hanging off it :-)
  • scotta
  • scotta's Avatar
21 Dec 2024 21:23
Great to hear and any help is greatly appreciated. Cakeslob as also been helping out the documentation.
It would be great to document how you got the probe up and running. This seems to be the hardest part for everyone with these boards, just getting the board to flash successfully can be a challenge.
  • Guytou
  • Guytou
21 Dec 2024 20:51
Replied by Guytou on topic QtDragon
QtDragon
In this QtDragon screen, the RPM showed seems to be the spindle-speed-in. Since I am not using any encoder, I want to show the spindle-speed-out instead. Any suggestion how to do this ? I am quite new with Linuxcnc and would appreciate some help. Thanks
  • PCW
  • PCW's Avatar
21 Dec 2024 20:36
Replied by PCW on topic Timed delay
Timed delay
I would do this with two components: a oneshot component and an and2 gate:
The oneshot would be set for 0.5 seconds and triggered by the drawbar signal.
The active high output of the oneshot would drive the low pressure solenoid
(so its driven for 0.5 seconds on the rising edge of the drawbar signal)
The high pressure solenoid would be driven by the output of the and2 gate
The and2 gate inputs would be the drawbar signal and the active-low output of the
oneshot. The active low oneshot output would disable the and2 output driving
the high pressure solenoid for the first 0.5 seconds when the low pressure solenoid
is activated.
  • Sternfox
  • Sternfox
21 Dec 2024 20:12
Timed delay was created by Sternfox
Timed delay
Hi good folks :)
I'm fairly new to linuxcnc, so please go easy on me lol.
I will try to explain what I need. It's not straight forward but im sure one of you geniuses will be able to help me out.
I have a haas mini mill, running linux cnc (probebasic), im 99% finished just the atc pneumatics to do. Now the haas mills have two solenoids to operate the drawbar.
 one opens and closes for 0.5 seconds first to pre charge the cylinder with 20psi. Like a soft push.
the second dose all the hard work and takes over immediately after the first and stays open untill the button is released.
how would this be accomplished?  I have found timedelay, but not sure how to implement it.
I would also like to be able to control this action with a physical input button.
I'm on latest linuxcnc using a mesa 7i95T.
Many thanks in advance.
  • cmorley
  • cmorley
21 Dec 2024 19:58
Replied by cmorley on topic qtvismach, a axis toolpath
Category: Qtvcp
Try this modified primative.py
It adds a new function HideCollection([part],component, pinname)
used something like this:
comp.newpin("hide-chuck", hal.HAL_BIT, hal.HAL_IN)
<snip make a machine with a A axis chuck>
chuckassembly = HideCollection([chuckassembly],comp,'hide-chuck')
  • jmelson
  • jmelson
21 Dec 2024 19:51
Replied by jmelson on topic Yaskawa encoder hack
Category: Driver Boards
Yes, that is common, just use the UV and W, and don't connect the inverted ones.
  • Aciera
  • Aciera's Avatar
21 Dec 2024 19:46 - 21 Dec 2024 19:46
Replied by Aciera on topic qtvismach, a axis toolpath
Category: Qtvcp
Another way to show/hide objects is to apply a scale factor of 1/0 according to the state of a hal pin (not sure if that works for the tool trace though):
github.com/LinuxCNC/linuxcnc/blob/master.../twp_vismach.py#L210
  • Grotius
  • Grotius's Avatar
21 Dec 2024 18:55
Replied by Grotius on topic PathPilot V2 source code
Category: PathPilot
I have also been told its pretty far deviated, so it will not be a simplistic task to add it to the main.
I am curious how the source of path-pilot looks like.
  • MarkoPolo
  • MarkoPolo
21 Dec 2024 18:54
Replied by MarkoPolo on topic qtvismach, a axis toolpath
Category: Qtvcp
Hi Chris
Have you looked at my problem?
I have another idea, a request..
  • PCW
  • PCW's Avatar
21 Dec 2024 18:51
Replied by PCW on topic Another joint 0 on limit switch error
Category: Basic Configuration
To set an input to slow mode, you set the 'slow' parameter for the corresponding pin
something like:
setp hm2_7i96s.0.inm.00.input-00-slow true
The documentation is in the hostmot2 manual page, inm section.
Halshow will not catch short noise pulses as it is normally only updated
10 or 20 times per second. You can catch them with HalScope however.
  • Grotius
  • Grotius's Avatar
21 Dec 2024 18:50
Replied by Grotius on topic Running halui in real time space?
Category: HAL
Hi Roockie,
The code is :
codeberg.org/skynet/linuxcnc_websockets
Above is dedicated to what you see on the youtube video.
  • JR1050
  • JR1050's Avatar
21 Dec 2024 18:10
Replied by JR1050 on topic Yaskawa encoder hack
Thank you. I have AMC amps for this application, these ones require the communtation signals until it sees the index. The thing that threw me off was the signals were differential, I’ve never seen , and I’m not an expert in this field, dual communtation signals. I take it , that I would just pick either the u,v, w or the -u,-v and -w . The AMC amps I’ve used allow for one set of halls signals. Thank you again.
Displaying 21661 - 21675 out of 21702 results.
Time to create page: 0.357 seconds
