  • Wrightys99
  • Wrightys99
15 Nov 2024 00:18
Replied by Wrightys99 on topic linuxcnc 2.9.2 (live) on the intel n100 cpu
Hi, just been reading this post and I’m looking for a linuxcnc pc to use with my 7i95t. I kind of get the gist of what is going on, but could you provide a link to one of these pcs please.
Could you also provide steps I would need to take to turn off all the unnecessary options or settings, to make it as streamlined as the thread is indicating please.
I am a noob to this cnc hobby and I’m currently in the learning a steep curve process of cnc.
I’ve just bought a cnc of fleabay that I am planning to upgrade and learn the ropes.
The current board in their is the CPO-10V which I am going to change to the 7i95t and run linuxcnc on this new mini industrial pc.
Like many most likely before me I have great plans for this cnc, only time will tell if most of them come off :)
  • PCW
  • PCW's Avatar
15 Nov 2024 00:09 - 15 Nov 2024 00:09
Replied by PCW on topic Pi-5, NVMe and Mesa
Pi-5, NVMe and Mesa
Category: Installing LinuxCNC
if you wire the MPGs to normal encoder inputs,
you should be able to monitor the position or raw count
pins of the encoders in the "Watch" window of halshow.
something like:
hm2_7i95.0.encoder.03.rawcounts
Note that if the MPG has single ended outputs you will need
to jumper the 7I95T encoders for single-ended/TTL mode.
Note that there is an advantage to using the 7I95T isolated
inputs for MPGs in that they support a 1X mode which works
better with 100 PPR MPGs that have a detent, as it gives you exactly
one jog increment per click.
  • behai
  • behai
14 Nov 2024 23:51
Please help with Nema 23 closed loop CL57T-V41 driver Microstep Switches
Good morning tommylight, Thank you for your suggestion. I appreciate it.
Best regards,
...behai.
  • PCW
  • PCW's Avatar
14 Nov 2024 23:20 - 14 Nov 2024 23:21
Strange motion offsets in one direction on one axis
Its not clear it's just one axis with the error.
Random uncommanded moves suggest a hardware issue to me,
either in the drives (encoder feedback error?) or the step/dir
interface (cross talk? EMI? marginal levels? bad connection?)
  • PCW
  • PCW's Avatar
14 Nov 2024 22:41 - 14 Nov 2024 22:58
Replied by PCW on topic coolant mist pulses
coolant mist pulses
Category: QtPyVCP
Yes, all this will work on a parallel port.
something like this:
loadrt siggen
addf siggen.0.update servo-thread
setp siggen.0.frequency .1     # 10 second period)
loadrt oneshot
addf oneshot.0 servo-thread
setp oneshot.0.width 2           # 2 second on time
loadrt not
addf not.0 servo-thread
net cool-trigger siggen.0.clock oneshot.0.in
net coolant-out oneshot.0.out [some_parallel_port_pin]
net coolant-on not.0.in
net gate-coolant not.0.out oneshot.0.reset siggen.0.reset  # when coolant is off, reset both siggen and oneshot
  • nigelh
  • nigelh's Avatar
14 Nov 2024 22:12 - 14 Nov 2024 22:14
Replied by nigelh on topic Pi-5, NVMe and Mesa
Pi-5, NVMe and Mesa
Thank you all, it's motoring up and down et al now.
The next trick will be to cut things into my DRO but I'm worried about over loading the sensors if I
just wire it in parallel - the impedances are very low. Do I need to buffer things? Like a bunch of non-inverting gates?
Also I'm looking at an MPG wheel I have with A/B quad outputs.
Since I'm only using 3 axis and I have 6 encoder channels should I be able to wire it into one rather than use the input pins
and get numbers. I tried and got nothing on the hal scope but I don't have anything in the mesact setup
for it yet.
I'm trying to read the manual but at 1300+ pages it's a bit intimidating.
  • jtrantow
  • jtrantow
14 Nov 2024 22:10
Interface to LightBurn (is pylib a better choice).
LightBurn(Commercial Laser Software) has functionality to generate LinuxCNC gode. It also has an interface that can home, frame, jog, frame, load programs, run programs etc. This UI works very well for laser cutting and it can communicate using serial over TCP.Recently, LightBurn added a "custom g-code device" that allows you to configure much of the gcode. With some help from the LightBurn forum I have a custom gcode device that can communicate with linuxcncrsh.
I have written a small C++ program that acts as a TCP server to LightBurn and as a client to linuxcncrsh. I have the basics working where I pass the majority of gcode commands through using the "set MDI <gcode command>" and special case a few commands *M114" to run linuxcncrsh get commands to fill in responses sent back to LightBurn.
Working with linuxcncrsh I'm seeing a few problems. github.com/LinuxCNC/linuxcnc/issues/3180
This isn't a deal breaker for what I'm trying to do, but going through some of the unit tests, I noticed tests/toolchanger/test-ui.py uses python as the ui. I'm wondering if python might be a better option???
Is the python interface more complete/better supported than linuxcncrsh?
I'm assuming opening the sockets and translating some strings wouldn't be a problem?
linuxcncrsh documentation indicates it can run in conjunction with another UI. (not sure if this is true in practice?)
Can a python interface run at the same time as another(GMOCCAPY) ui?
I'm trying to decide whether to continue on with linuxcncrsh or start over with python.
  • Ismacr63
  • Ismacr63
14 Nov 2024 22:09
Replied by Ismacr63 on topic coolant mist pulses
coolant mist pulses
Category: QtPyVCP
I have read the thread and seen the post forum.linuxcnc.org/49-basic-configuratio...sher?start=10#230922
Can it be adapted to the parallel port?
I thank you very much for the help but I'm such a newbie that everything sounds like Chinese to me T_T
  • Axolito
  • Axolito's Avatar
14 Nov 2024 21:53
Replied by Axolito on topic Unwanted actions with a touch screen
Category: Gmoccapy
Oh, I'm sorry, I deleted the video while cleaning up my cloud and also didn't see your post.
I'll make another video as soon as I can and share it.
14 Nov 2024 21:52
Replied by tommylight on topic probe basic tool direction
Category: QtPyVCP
Bump. Might have been missed, although i do not know how many use the Probe Basic for 5 axis machines.
14 Nov 2024 21:49
Must be the third time i am looking at this and can not figure out what is going on, and the picture is not helping.
Can you do some more details, like where the mill is cutting and what direction it is traveling, and just to be sure, that there is no undercut as it looks in the picture.
Or am i looking at it from the wrong perspective?
14 Nov 2024 21:46
Replied by tommylight on topic LinuxCNC on Intel Clear Linux
What do Debian 12, Ubuntu 24 and Linux Mint Debian Edition 6 have in common? ... besides being all Debian, they can all have LinuxCNC installed with a single line after an update:
sudo apt install linuxcnc-uspace
So, not a single distro, but a single distro! :)
There is also Gento Linux that NTULINUX maintains and supports, and has also RTAI kernels for it and Debian.
Now, has anyone tried to compile LinuxCNC on CL? Maybe that already works.
I compile on every new version of normal Mint and use the created debs to quickly install on many PC's and laptops i use and test, so that also works.
No idea where i was headed with this, had a pizza and 2 coffees and had one of the laptops with me so i was browsing the forum and doing maintenance ... been doing a lot of installs lately as i got 5 laptops (4 used and 1 new), not counting the existing ones... send help ! :)
14 Nov 2024 21:20
Used Laptops tested with LinuxCNC and Mesa Ethernet boards
Got another Lenovo X240 and X1 Carbon Yoga laptop/tablet, will update when i get to testing them on a machine as they are installed and ready.
  • PCW
  • PCW's Avatar
14 Nov 2024 21:16
coolant mist pulses
Category: QtPyVCP
Another possibility is to use the siggen to set the rate (0.1 Hz for example)
and drive the oneshot component with the siggen clock pin, then set the on time
with the onseshot width pin.
The oneshot component has a reset input that could be used for enabling
the output with the coolant-on signal
  • Gluca
  • Gluca
14 Nov 2024 21:16
Replied by Gluca on topic Remora rp2040 compile issues.
Nothing to do.
After:
> cmake -DPICO_SDK_FETCH_FROM_GIT=on -DCMAKE_BUILD_TYPE=Release ./Remora-RP2040-W5500-main
> make
OR
> cmake -DPICO_SDK_FETCH_FROM_GIT=on -DCMAKE_BUILD_TYPE=Debug ./Remora-RP2040-W5500-main
> make
It always exits with "fatal error".
Displaying 21946 - 21960 out of 22559 results.
Time to create page: 0.570 seconds
