02 Dec 2024 23:50
Gentoo Image, Which Applications are in and Which are Out
Where is the ISO and does it boot in Live mode?
All my Ryzen's are gone except a R7 5700U in a laptop with a TDP of 15W including GPU, so should be worst case scenario for testing.
  • royka
  • royka
02 Dec 2024 23:01
Replied by tommylight on topic Mesa
Mesa
Category: Driver Boards
Can i have 20 of those, please? :)
  • D Jensen
  • D Jensen
02 Dec 2024 23:01
Replied by D Jensen on topic Retrofitting a 1986 Maho 400E
Category: Milling Machines
Here are the pages from my manual on how to disassemble and re-grease the spindle. Mine is NT40 so a bit bigger and with a different pull stud. But I would think much the same. I've added the page on how to adjust the claws. It's very quick and simple. The whole assembly item 2 is fitted when it's all assembled into the spindle, in my case back in the machine. It simply screws in. When the depth dimension is right ( I used the tail end on my dial calipers) you simply tighten the grub item 1. That presses the ball into the coned recess in the stud and expands the thread onto item 2. The hatched portion where item 2 points to are actually longitudinal cuts in the thread.
Your 30 size tool holder will have a different adjustment length I would think. .In the diagram you can see that as the claws are retracted they are jammed closed by the bore of the spindle. That means that it is more likely any rattle is due to damaged or worn claws I think. The claws are the finer cross hatch.
Cheers,
David
  • Benb
  • Benb's Avatar
02 Dec 2024 22:37 - 02 Dec 2024 22:56
Replied by Benb on topic Servo drive or some kind of problem
Category: HAL
Tuning?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Tuning_LinuxCNC/HAL_PID_Loops
forum.linuxcnc.org/10-advanced-configura...to-example-mesa-7i77
gnipsel.com/linuxcnc/index.html
Manufacturer name and model numbers for the servo drives, servo motors and encoders, also upload your current ini and hal files.
  • 3CHman
  • 3CHman
02 Dec 2024 21:25
Replied by 3CHman on topic 7i77D availability
7i77D availability
Thanks for the info guys. They are no longer building the 7i77D as you have all sussed out - so Ill use the 7i77 with a bit of extra logic. I need the X6 servo interface the 7i77 gives and Ive got the current 7i77D built in so Ill pursue that path for the mo . Ill check out the 'U' options though for the future
Thanks again..
  • Ricoch3T
  • Ricoch3T
02 Dec 2024 21:17
Servo drive or some kind of problem was created by Ricoch3T
Category: HAL
Working with a 7i97 board
Cmc drives and dc brushed servo motors
original drives have tac but the encoders are wired directly to the 7i97 board.
problem I’m having is I’ve only been able to jog forwards. The 7i97 board is sending either plus or minus 10v like it should be but for some reason I only get one direction.
I’ve switched the signal wires around to see if it would make a difference and the motor still only jogs forward.
I’ve switched back to the stock 7i97 hal and ini file. Only changes I’ve made to it are
ip address
Commented out the z axis since I don’t have one yet.
frequency I’ve changed to 5000 to match what the manual said.
Been working on it for a month or so with the same results. Digging through the original machine book only thing I can find that catches my eye is there’s something about uniswitching (not sure what that is) when the machine is using high speed. And h bridge when at low speed for torque.
I don’t know if that matters or not. I’m lost.
  • PCW
  • PCW's Avatar
02 Dec 2024 21:16
New project, litehm2: a hostmot2 port to linsn rv901t
There are at least three ways to generate a bipolar analog voltage from PWM
1. Using PWM/DIR (typically using an op-amp circuit that
is changed from inverting to non-inverting by a analog switch)
(this has the disadvantage of a glitch when direction changes)
2. Using the PWM generators UP/DOWN mode and summing
a positive and negative filtered voltage.
(this has the disadvantage that the filter time constant
varies with the input)
3. Using the PWM generators offset mode (so 0 = 50%) and an op-amp
filter that has a DC offset of - full scale
(This has the disadvantage that you lose 1 bit of resolution, which may not matter
if you use dithering)
  • PCW
  • PCW's Avatar
02 Dec 2024 20:56
Replied by PCW on topic Mesa
Mesa
Found one with bad I/O (pin 13)  on P1 but Tormach only uses P2:
store.mesanet.com/index.php?route=produc...t_id=411&search=7i92
  • slowpoke
  • slowpoke
02 Dec 2024 20:55 - 02 Dec 2024 21:04
Replied by slowpoke on topic Small touchscreen display 7-10' -> 14-16"
Does it have an RJ45?
Supposing it does not as none of mine have it, so get an USB to RJ45/LAN adapter, around 7 to 15$.
I have 6 of those adapters from very old 10MBit to new 1GBit ones and all work perfectly fine with Mesa.
And i have a Dock for the Y370 with all the bells and whistles, got it for 30 Euro used! :)
From some quick Google research, I think your Y370 is likely Gen2 (2017), while mine is Gen1 (2016), hopefully that won't be a problem, conflicting information about USB ports on the Gen 1, not sure if it has the fast USB-C port, I think not appears to be , 2x USB3.0 and one USB2.0.
USB3.0 is pretty fast, so will probably be okay if I get a decent Ethernet dongle.
Would like to see your USB to Ethernet dongle, I don't want that to be a bottleneck for the MESA card.
  • NTULINUX
  • NTULINUX's Avatar
02 Dec 2024 20:26
Thanks! Yeah, things are going well, just wrapping it up. Latency is a bit high for me but I ran `rtla timerlat top` and some of the spikes are coming from my Radeon GPU. Others are coming from APIC and hrtimer (CPU interrupts, can't tune these out.)
I'm on a Ryzen system and I've noticed that PREEMPT_RT has much lower latency on some Intel hardware. It'll be interesting to see how latency performs on other hardware with the image.
I just pushed a huge update to my portage configs on GitHub, almost ready to publish the updated installer and root filesystem:
github.com/NTULINUX/gentoo_backup/commit...9333804131fbc352c3d5
  • Lcvette
  • Lcvette's Avatar
02 Dec 2024 20:10
Replied by Lcvette on topic Probe Basic - ATC sim parameter question
Category: QtPyVCP
@spumco did you ever get this sorted and working?
  • RotarySMP
  • RotarySMP's Avatar
02 Dec 2024 19:53
Replied by RotarySMP on topic Retrofitting a 1986 Maho 400E
Yeah, that is the first thing I will check. I just started trying to remove the draw bar unit. I dont have a good cut away or manual for this, so will just disassemble what I can find.
  • trisa25
  • trisa25
02 Dec 2024 19:50
Replied by trisa25 on topic Ebosa 140 CNC retrofit
Category: Turning
Some slow progress lately.
I have made a new hal component for easier configuration.
The component is multiplexer logic for driving leds for examle. I am running 64 key keypad, 2 potentiometers and 30 leds with a 7i73.
More pictures and videos coming soon, still have some problems with ethercat.
  • Muecke
  • Muecke's Avatar
02 Dec 2024 19:48 - 02 Dec 2024 19:50
[OT] Frage zu Spannzangen und Eigenbau-Werkzeug
Category: Deutsch
Ich glaube, ich habe endlich ein Video gefunden, wie man die Teile zusammenbaut.
gv-vod-cdn.aliexpress-media.com/80ffc57e...d6c56241dfe52c865162
Sind die Systeme OZ und ER in Aufbau und Zusammensetzung gleich oder unterscheiden sie sich?
Displaying 22246 - 22260 out of 22275 results.
Time to create page: 0.504 seconds
