  • chris@cnc
  • chris@cnc
08 Sep 2024 18:24
Replied by chris@cnc on topic lube - time component
Category: Basic Configuration
I noticed that the pressure drops immediately after the lubrication pump is switched off. I think it is better to check the pressure switch before lubrication time end. With 30 second lubrication time, the pressure switch has to go up after 25 seconds. And after lubrication time end, no pressure is expected.
  • Trevy3
  • Trevy3's Avatar
08 Sep 2024 18:13
Replied by Trevy3 on topic Weird Multi Axis MDI Issue in QTDragon_HD
Category: Qtvcp
I have also just tested this in the default qtdragon_hd_xyza sim setup and it does the same thing there.
  • Carsten
  • Carsten
08 Sep 2024 17:59
Replied by Carsten on topic Probe Basic in QTDragon
Category: Qtvcp
problem solved.
You can have your own qtdragon_{,hd_}handler.py in e.g. qtvcp/screens/qtdragon{,_hd} and have full control over the GUI.
Regards
Carsten
  • Aciera
  • Aciera's Avatar
08 Sep 2024 17:48
Probe Basic - startup error on new installation
Category: QtPyVCP
what does this give you:
$ python3 --version
  • spumco
  • spumco
08 Sep 2024 17:27
Category: QtPyVCP
I wonder if using Deb 13 is the problem.  Deb 12 doesn't like my nic's or wi-fi hardware.
Assuming it's a python issue, any suggestions on what to do about it?
  • spumco
  • spumco
08 Sep 2024 17:20 - 08 Sep 2024 17:24
What do you really get for a $350 desk top engraver ?
Category: Show Your Stuff
Like this one I built for a couple of plasma tables.
In these photos the motor is mocked up directly on the pinion, but we wound up using a 10:1 reducer between the motor and pinion.
Belt was T5, pinion was 15T (bought T5 15T bar stock).  Mr. Everman pointed out on CNCZone years ago that only T-series belt teeth/valleys are symmetrical - HTD and GT2/GT3 have non-meshing teeth.
  • Trevy3
  • Trevy3's Avatar
08 Sep 2024 17:20
Category: Qtvcp
I don't have any offsets set.
  • Aciera
  • Aciera's Avatar
08 Sep 2024 17:17
Category: QtPyVCP
According to this the 'imp' module has been removed with python 3.12:
stackoverflow.com/questions/77274572/mul...-no-module-named-imp
But according to this Debian 13 is on python 3.11.2:
www.debian.org/releases/trixie/release-notes/whats-new.en.html
might want to check what python version you are running.
  • spumco
  • spumco
08 Sep 2024 17:16
The Bell-Everman drive is a nice system, but you need to put any reduction upstream/ahead of the pinion.  As Tommy pointed out the 72T idlers won't reduce anything.
A low-backlash, helical gear reducer between the motor and the pinion is the way to go.
And if you've got the space for some extra carriage length, the 'Loop-track' system brom B-E is really nice.
  • machinedude
  • machinedude's Avatar
08 Sep 2024 16:58
this is why i got the 3d printer to test stuff and not spend much money on idea's :) i probably have OCD :) i have to see stuff with my own eyes before i give up on anything :) i share the good bad and the ugly regardless of outcome :)
  • spumco
  • spumco
08 Sep 2024 16:55 - 08 Sep 2024 16:57
Replied by spumco on topic Fanuc 2S AC spindle motor on Delta C2000+
Category: Milling Machines
I'm really sorry for my earlier knee-jerk post.  The newer versions of the Fanuc spindle motor are PMs, so it's possible that yours is also a PM.
  • Mr_rookie
  • Mr_rookie
08 Sep 2024 16:52
Replied by Mr_rookie on topic 7c80 no communication between rpspi 4
Category: Installing LinuxCNC
arm_64bit=1
initramfs initrd.gz followkernel
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
# camera
#start_x=1
#gpu_mem=128
# automatically load overlays for detected cameras
#camera_auto_detect=1
# automatically load overlays for detected DSI displays
#display_auto_detect=1
# uncomment to overclock: www.tomshardware.com/how-to/overclock-any-raspberry-pi
#arm_freq=
#gpu_freq=
#core_freq=
#over_voltage=
#force_turbo=1
# uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
# uncomment this to enable infrared communication.
dtoverlay=gpio-ir,gpio_pin=17
dtoverlay=gpio-ir-tx,gpio_pin=18
# additional overlays and parameters are documented /boot/overlays/README
# enable audio (loads snd_bcm2835)
dtparam=audio=on
# enable uart
enable_uart=0
# disable wifi and bluetooth
#dtoverlay=disable-wifi
#dtoverlay=disable-bt
#dtoverlay=pi3-disable-wifi
#dtoverlay=pi3-disable-bt
#dtoverlay=disable-wifi-pi5
#dtoverlay=disable-bt-pi5
# remove test rainbow
disable_splash=1
# disables the warning overlays
avoid_warnings=1
# gpio fan (headers)
#dtoverlay=gpio-fan,gpiopin=12,temp=55000,hyst=2000
[cm4]
otg_mode=1
[pi4]
dtoverlay=vc4-kms-v3d,cma-512
#dtoverlay=vc4-kms-v3d-pi4
#dtoverlay=vc4-fkms-v3d
max_framebuffers=2
arm_boost=1
#disable_fw_kms_setup=1
[pi5]
#dtoverlay=vc4-kms-v3d-pi5
max_framebuffers=0
arm_boost=1
usb_max_current_enable=1
# pwm fan
#dtparam=fan_temp0=50000
#dtparam=fan_temp0_hyst=2000
#dtparam=fan_temp0_speed=75
#dtparam=fan_temp1=55000
#dtparam=fan_temp1_hyst=2000
#dtparam=fan_temp1_speed=125
#dtparam=fan_temp2=60000
#dtparam=fan_temp2_hyst=3000
#dtparam=fan_temp2_speed=175
#dtparam=fan_temp3=65000
#dtparam=fan_temp3_hyst=3000
#dtparam=fan_temp3_speed=250
I remove the # to activate this line
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
  • Mr_rookie
  • Mr_rookie
08 Sep 2024 16:49
www.linuxcnc.org/dists/bookworm/2.9-uspa...pace_2.9.2_arm64.deb
arm64.
yes, but if you are looking get access remotely you may have slow UI.
systemctl disable lightdm that work in my case works perfectly.
  • Mr_rookie
  • Mr_rookie
08 Sep 2024 16:44
Replied by Mr_rookie on topic 5 Axis configuration on linuxcnc
you can install linuxcnc 2.9.3 and you may need to activate some option to make the /dev/sdev0.0 to get active also may have slow graphic interface if you are using virtual remote as I do. but that is something easy to fix.
I'm talking about 7c80 board, if you are looking to use a different board you may need different settings.
  • chrisfischer
  • chrisfischer
08 Sep 2024 16:35
Replied by chrisfischer on topic XHC-WH04b USB not detected in front port
I have the same problem here with the WH04B-6. Cant see the device on any ports. I checked my bios and the legacy usb is already enabled. i enabled some other usb stuff with no results. Any luck fixing this?
Displaying 23491 - 23505 out of 23569 results.
Time to create page: 0.435 seconds
