  • rodw
  • rodw's Avatar
23 Sep 2026 21:19
Amston Lake / Alder Lake-N (Atom x7433RE) with IgH EtherCAT — kernel version exp
Category: EtherCAT
I don't like using backports. Never have used them.
"I don't use it" and "I don't like it" are not substantive arguments.
The problem is that there are newer versions of the libraries in the newer release. First of all, it is about Python, in which the authors constantly change or remove something, so even relatively new programs (from a year or two ago) do not want to run, or some of their functions do not work.
However, backports repositories are optional, you can activate them, install only what you need and then turn them off again.
The reason I don't like backports is it can land you in dependency hell as you point out. That's my substantive argument.
I've been in this position needing a later kernel to support my hardware. Today, I would either compile the kernel and be done with it or use apt pinning to be very selective on what packages I obtain from unstable.
  • RMJ fabrication
  • RMJ fabrication
23 Sep 2026 21:08
Z axis torch initially going up instead of down when clicking cycle start
Category: Plasmac
Hello everyone I have a new issue with my plasma table. So after I home my machine, load the file, zero the machine, and click cycle start my z axis torch travels up into the home switch instead of going down and probing the sheet of steel. I ran an mdi comand "g0 z-.5 and when I hit enter the torch moved down -.5 like it should so I dont think anything is reversed. The gcode file I am using worked in the past so im am just at a loss. Is there a certain amount of travel the torch is supposed to go up initially that I could maybe adjust to fix this?
  • rodw
  • rodw's Avatar
23 Sep 2026 21:07
Replied by rodw on topic Spindle temperature control
Category: Driver Boards
You could use one of the Mesa 7i76e's not very accurate analog voltage input pins and a 10k resistor to form a voltage divider. at 25 deg C, and 24 volt field power, the voltge will be 12 volts. You might need to scale this with lincurve or a custom component. Accuracy of +- 2 degrees due to 8 bit conversion is probably OK for this application.
23 Sep 2026 21:06
Replied by tommylight on topic Spindle temperature control
Moved to "driver boards".
I think 7i76 has 4 low resolution analog inputs, so maybe one of those could be used, but i never used it for temperature. I did use them for servo load from the drive, and it worked perfectly fine for my case.
Did not use other two so i can not dispense info.
  • ianlowe
  • ianlowe
23 Sep 2026 20:29
Spindle temperature control was created by ianlowe
I have a Jianken 3.2kw spindle that has a NTC 103F3950 (10 kΩ, B=3950) thermistor and a Thermal fuse / PTC-type cutoff.
My controllers are Mesa 7i76e + 7i78 + 7i89.
How do I make use of these and connect them to my controllers.
  • tuxcnc
  • tuxcnc
23 Sep 2026 19:33
7i97T - Custom bitfile request (High-speed 200MHz Encoder for Linear Motors)
[code][code]my high-resolution optical scales (...) are dropping pulses during high acceleration
[/code][/code]
Acceleration has nothing to do with it.
Only maximum speed matters.
From the resolution and speed you will calculate the pulse frequency.
  • Gotrune
  • Gotrune
23 Sep 2026 19:16
Hi PCW,
Thank you so much for the incredibly fast reply!
I will add setp hm2_7i97.0.encoder.muxed-sample-frequency 20000000 to my HAL file right away and test the machine.
Just to make sure I fully understand the limits of the hardware: what are the acceptable or maximum values for this parameter with the standard 7i97T bitfile? For example, does it need to be a specific integer divisor of the base clock? Also, at what frequency would I typically need to start adjusting the muxed-skew parameter you mentioned?
Thanks again for your time and excellent support!
  • PCW
  • PCW's Avatar
23 Sep 2026 18:29
I would try setting:
to say 20 MHz
(you can probably go higher by futzing with the muxed- skew parameter)
  • Gotrune
  • Gotrune
23 Sep 2026 18:03
Hi PCW,
I am currently retrofitting a machine with a Mesa 7i97T and JAT Ecovario drives controlling permanent magnet linear motors.
My problem is that my high-resolution optical scales (1µm/step which are passed-through directly from the drives, with no hardware division possible) are dropping pulses during high acceleration, even with "filter 0" set in my HAL file. The minimum edge separation of the raw encoder signals is too tight and violates the standard MuxedQCount clock limit.
Could you please compile a custom bitfile for the 7i97T where the encoder counting module clock is bumped to 200MHz (or the maximum possible frequency for this FPGA) to handle these extremely fast edges?
I only need the standard 7i97T I/O pinout, just with the fastest possible encoder sampling.
Thank you in advance!
  • geebee
  • geebee
23 Sep 2026 17:53
Replied by geebee on topic 7i95t firmware flash
mesaboard is on 2. enp8s0 (see alsö static inet/inet6 addresses) It does show no carrier when unplugged.
eno1 (internet) has automatic connection method.
wlan has been turned off in order not to get confused.
I changed lan cables and now it behaves as it should mesact/machine finds the board and readhmid provides the information as expected.(mesact and terminal)
I wasnt aware of that since I did have acces to the internet anyhow(???).
so thank you very much for the moment This particular problem is solved.
Have nice days
geebee
  • viesturs.lacis
  • viesturs.lacis
23 Sep 2026 17:19 - 23 Sep 2026 18:18
Replied by viesturs.lacis on topic lcec_conf exited without becoming ready
Category: EtherCAT
please find attached 3 screenshots - left side are all the pins for cia402 component (they did all fit in screen) and right side is list of lcec pins in terminal. do you have any idea, which of these is "enable" pin? lcec.0.state-preop, lcec.0.state-safeop and lcec.0.state-op seem suspicious to me but then I do not understand why would 3 pins be needed. I would appreciate some hints on which pins should I try for enabling the drive and which would be most suitable candidate for making the motor spin. cia402.0.velocity-cmd would seem like most obvious candidate but is there anything else to add (so far in my experience it would have been 2 pins - one sets velocity, the other would be a bit output for "run/stop")
BTW cia402.0.controlword has value 4, which seem to match instructions in manual to set the parameter 50.04 to 4 (which means that reference is speed). does that help in any way? and since the manual says this:"Ensure the drive profile parameter 51.02 is set to CiA402 (0)" I would like to think that it's all good regarding the suspicion about needing different mode rather than cia402.
could you please share some link where I could see some cia402 templates that you mentioned?
  • geebee
  • geebee
23 Sep 2026 16:11
I just try to set the card to work.
For the beginning, I want it to get a single stepper motor to turn with nothing else connected to it. For this, I need to configure some hal and ini files. I can use mesact but not pncconf for this.Later, I will analyze and try to understand these first files according to linuxcnc docs. What i intend to do is retrofitting a lathe to cnc (two, maybe three axes) , an additional axe for an attached lathe and on for a dividing head and some encoders /DRO This is all I might need in the (far) future.
Right now, I would just be happy to get linuxcnc, mesact ,board and stepper (driver) "Talk to one another".
cheers
geebee
  • PCW
  • PCW's Avatar
23 Sep 2026 16:05
Replied by PCW on topic 7i95t firmware flash
OK so the next question is which Ethernet interface is the 7I95T connected to?
(enp8s0 or eno1)
(quick way to check is unplug the 7I95T RJ45 cable and see which interface shows "NO-CARRIER"
  • geebee
  • geebee
23 Sep 2026 15:54
copy from terminal :
eebee@debian:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp8s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 9c:53:22:48:4a:55 brd ff:ff:ff:ff:ff:ff
altname enx9c5322484a55
inet 10.10.10.1/24 brd 10.10.10.255 scope global noprefixroute enp8s0
inet6 2003:ca:745:4b0:8af0:56c3:81dc:59d1/64 scope global dynamic noprefixroute
valid_lft 172796sec preferred_lft 86396sec
inet6 fe80::1f98:abff:6d07:69fe/64 scope link noprefixroute
3: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 50:46:5d:6f:50:7c brd ff:ff:ff:ff:ff:ff
altname enp0s25
altname enx50465d6f507c
4: wlp7s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 6a:9d:f2:44:dc:7d brd ff:ff:ff:ff:ff:ff permaddr 64:70:02:18:5d:b8
altname wlx647002185db8
geebee@debian:~$
Displaying 241 - 255 out of 13210 results.
Time to create page: 0.344 seconds
