  • DPFlex
  • DPFlex
23 Jul 2024 03:29
EtherCAT Leadshine EL6 series - could read but not control
Category: EtherCAT
Hello,
I found the root cause. It is because of setting of 6092.
The default setting is:
Need to revise to:
Save configuration and that's all.
  • stirra
  • stirra
23 Jul 2024 02:45
Replied by stirra on topic Changing "Spindle Override" label text
Category: AXIS
The second was what I wanted. I just needed spinoverride.l rather than just spinoverride .
The foam cutter I'm working on is getting close to functionality.
Thanks again.
-- Ralph
  • kzali
  • kzali
23 Jul 2024 02:17
Very interesting! Is there a repository? And can this be used with the tangoboard or Tang Primer 20K?
Great work
  • rodw
  • rodw's Avatar
23 Jul 2024 02:09
Pi4b and Pi5 users - What should go in a 2.9.3 image
Category: Installing LinuxCNC
Becasue there is a new chipset  in the 5, there is as yet no known SPI interface. It that becomes available then one of the developers could look at it if they feel like it :)
23 Jul 2024 02:07
As i understand it, it is a RPI manufacturer issue, most probably hardware side of things, as i doubt if software issue it would have been solved by now.
As far as i recall, there are several versions of RPI5 and back then any new version would be crippled by issues for a long time, plenty of videos on youtube about that.
Chip shortage caused a lot of headaches for all manufacturers, but the way RPI owners handled it, is by far the worst way, ignoring issues and waiting for others to fix the issues while they were busy getting rich from the 180$ price tag.
Same ... well much worse, with Intel, blaming everything and everyone while knowingly selling 400-1100$ processors. Millions of it.
Personally, i blame humans for standing that kind of s#it. I do not, vigorously! :)
  • DanielWebsterCnc
  • DanielWebsterCnc
23 Jul 2024 01:15
Replied by DanielWebsterCnc on topic Pi4b and Pi5 users - What should go in a 2.9.3 image
In regards to "The 7c81 product page at Mesa states that the 7c81 will not work with the RPi5". I was wondering if the Mesa company writes the driver normally or if the missing support for the RPi5 is something that is part of the LinuxCNC 2.9.3 image?
  • cakeslob
  • cakeslob
22 Jul 2024 23:35
Replied by cakeslob on topic Changing "Spindle Override" label text
Category: AXIS
i dont think anythign you change in qtvcp will change axis.
which one are you trying to set? the one in the manual tab or the one beside the sider?
root_window.tk.call( '.pane.top.tabs.fmanual.spindlel','configure','-text','buttbutt tab')
root_window.tk.call( '.pane.top.spinoverride.l','configure','-text','buttbutt slider')
"are there good docs?"
only what Phil has made for the axis docs, otherwise it gets rather confusing because we are passing tcl/tk as strings through python, so its not tkinter, and its not just tcltk
this is the best site, as well as using plasmac2 config as an example
www.tcl.tk/man/tcl8.6/TkCmd/label.htm
github.com/LinuxCNC/linuxcnc/blob/master...plasmac2/plasmac2.py
here is my shitty one, but its got good references
github.com/cakeslob/regularmac_800
  • stirra
  • stirra
22 Jul 2024 22:21
Category: AXIS
This should be an easy thing, but my facility with tk is not great.  I want to change the text of the spindle override widget without editing the /usr/lib/python3/dist-packages/qtvcp/plugins/status_label_plugin.py file where it is set up in the first place.  I have successfully changed text of the .pane.top.tabs.fmanual.spindlel label widget using the tk call shown in the Axis documentation:
root_window.tk.call('setup_widget_accel', '.pane.top.tabs.fmanual.spindlel','Wire Voltage')
This does not work for the tkinter.Scale widget spinoverride or spinoverridef.  I'm sure I'm missing some simple step.  Is there a good set of documentation for the tcl/tk code interface for working with widgets?
Thanks again,
-- Ralph
  • Linuxcncnoob
  • Linuxcncnoob
22 Jul 2024 20:34
Replied by Linuxcncnoob on topic Linuxcnc on my machine?
I managed to install Linuxcnc on an old pc.
It seems for what I want or need.
a 7I95T + THCAD2 would be the way to go.
The thing is my machine is Router/plasma combo with rotary and laser and on top of that a probe will need to be installed.
In the future I will separate the tables.
Thanks to all!
  • Linuxcncnoob
  • Linuxcncnoob
22 Jul 2024 20:26
Replied by Linuxcncnoob on topic Height map and or points to cloud
Thank you!
some great info.
  • Philip Lydin
  • Philip Lydin
22 Jul 2024 20:25
Replied by Philip Lydin on topic Brother TC-225 / TC-229 adventure!
Category: CNC Machines
Its a three phase transformer its for the versions that run on 380/400v since the spindle drive use 220 three phase power i think. And three phase doesnt need neutral to work its the phases that have 380V between them
  • rodw
  • rodw's Avatar
22 Jul 2024 20:01
Replied by rodw on topic MESA 7i96S power supply
Category: Driver Boards
Try a Meanwelll MDR-10-5 (2 amp)
  • rodw
  • rodw's Avatar
22 Jul 2024 19:59
this code works for rpi 4 model B but not working for rpi 5
Category: HAL
My guess is gpio16 does not exist. remove it
  • cncproject2024
  • cncproject2024
22 Jul 2024 19:58
Replied by cncproject2024 on topic MESA 7i96S power supply
Would you be able to suggest a power supply to me? Thanks
  • rodw
  • rodw's Avatar
22 Jul 2024 19:55
Am I able to power the card from a usb cable from a computer?
No. even a USB plugpack isn't reliable
Displaying 24406 - 24420 out of 25505 results.
Time to create page: 0.481 seconds
